m42b32 Posted August 13, 2020 Report Share Posted August 13, 2020 12 hours ago, SteelBlue said: My understanding is it’s essentially the Baja craze of cars, just with bikes. Turn road cars into off-road cars. I just want to change the bars and pedals into something more “mountain bike” like and then do as wide and tall of a tire with a more knobby tread pattern. I could probably convert to discs, but I don’t think I will need them for my application. And yes, you can change the gear sets for these, but the Shimano 105 should be good enough for my needs. Nice Cannondale! Shimano 105 is great, I have it on one of my bikes and have zero complaints. Converting to discs is possible, but not worth it at all. That, and any "adapter" mounts for the rear would put a lot of stress on parts of the frame not intended to see braking forces. You would also need new hubs, so at that point the cost is getting way up there. Just slap on the biggest tires you can fit and have fun! Another bar option is bullhorns. I had some Nitto RB021 on a fixed gear I rode in college (still have the bars) and they were perfect for hilly terrain since I never used drops and were incredible for climbing. ...Not that you needed any more opinions, I just like bikes and wanted to chime in haha Quote Link to comment Share on other sites More sharing options...
SteelBlue Posted August 13, 2020 Report Share Posted August 13, 2020 10 hours ago, straight6pwr said: lookup cyclocross bikes. they are basically what you'll be building. its a sport invented for the road race guys to have something to do in the 'off season' in parts of the world that have winter. i turned an 80s hybird into a cyclocross bike for my commuting for a while. its really the best 'all-rounder' if you ask me. light enough and low rolling resistance with small tires that you dont feel like the bike is slowing you down, but capable enough to do just about any dirt trail that doesnt have jumps and logs and stuff. those calipers are awfully tight on the rims, be careful with knobby tire sizes, there isnt much room there. if the bike has 700c wheels, you could downsize to 650c and add long reach calipers, but that might be more effort/$$ than youre looking to put forth and you cant put disc brakes on any bike to fix tire clearance, either. its frame dependent. you could change the front forks to add discs, but for the back you're stuck. drop bars are actually quite comfortable if you get them in the right spot. you could get a new, longer stem, or one that has a 45deg rise to get the bars up in the air more. i'd recommend converting to STI shifters (the kind that are integrated into the brake levers) and keeping your bars. the geometry of straight bars on a road bike can be awkward. for a cheaper fix, I used thumb shifters. also, depending on what bars you use, you can run into issues with brake levers. putting mountain bike style brake levers on a road bike doesnt work that well, and visa-versa. they pull different amounts of cable. 2 hours ago, m42b32 said: Nice Cannondale! Shimano 105 is great, I have it on one of my bikes and have zero complaints. Converting to discs is possible, but not worth it at all. That, and any "adapter" mounts for the rear would put a lot of stress on parts of the frame not intended to see braking forces. You would also need new hubs, so at that point the cost is getting way up there. Just slap on the biggest tires you can fit and have fun! Another bar option is bullhorns. I had some Nitto RB021 on a fixed gear I rode in college (still have the bars) and they were perfect for hilly terrain since I never used drops and were incredible for climbing. ...Not that you needed any more opinions, I just like bikes and wanted to chime in haha This is a new avenue for me, so lots to learn. Thank you for the info. Quote Link to comment Share on other sites More sharing options...
HipMF Posted August 20, 2020 Report Share Posted August 20, 2020 On 8/12/2020 at 9:07 PM, SteelBlue said: Just what I needed, another project. 1987 Cannondale RS500. Goal is turn this into a “gravel” bike with its primary use for getting around Road America. Can’t complain for $125. Might as well throw my unsolicited pair of pennies out there, since there's not a lot going on on this site... On 8/13/2020 at 2:03 AM, straight6pwr said: lookup cyclocross bikes. ^This. Similar to the way BMX bikes developed from Schwinn Stingrays, mountain bikes evolved from bikes we would call "beach cruisers" today. Over time, both of these types of bikes have become very specialized to the type of riding that they are intended for. As you alluded to, the "gravel bike" is analogous to the "baja craze" in the car world. Taking something that was designed for one task, and applying it to almost the opposite task. You can certainly try to ride a road bike with dirt tires around at RA, and it will be a fun challenge. Road bikes are designed for high speed on smooth surfaces, so the seat is high and the bars are low to keep your torso horizontal for reduced aerodynamic drag. The trade-off is reduced balance and maneuverability at low speed. With the terrain and traffic that's typically present at RA, you'll never get up to the speeds that the bike was designed for, and will have a fun time just trying to keep your feet off the ground. You can raise the bars and lower the seat to gain control. This more relaxed posture and added maneuverability will allow you to tackle the same trails at a higher speed. However, if you happen to hit a tree root or a large rock at this higher speed you'll find that your featherweight road wheels fold like a cell phone of similar vintage, leading you down the same trail as if you were trying to build a mountain bike out of a beach cruiser... Quote Link to comment Share on other sites More sharing options...
Bassboy3313 Posted August 20, 2020 Report Share Posted August 20, 2020 Ode to the old e21 back in action. Rekpoint, P_Roloff, straight6pwr and 3 others 6 Quote Link to comment Share on other sites More sharing options...
straight6pwr Posted August 21, 2020 Report Share Posted August 21, 2020 Yes! Quote Link to comment Share on other sites More sharing options...
YoungCR Posted August 21, 2020 Report Share Posted August 21, 2020 Looks like you had fun hanging it 🤣 I have a few hoods I've saved just for this purpose someday. Such a cool idea, looks great. Quote Link to comment Share on other sites More sharing options...
Bassboy3313 Posted August 22, 2020 Report Share Posted August 22, 2020 9 hours ago, YoungCR said: Looks like you had fun hanging it 🤣 I have a few hoods I've saved just for this purpose someday. Such a cool idea, looks great. Haha it was not easy thats for sure! 😅 Previous owners left some paint in basement. Hopefully one of them is the right color and a quick touch up will take care of it. Let me know if you want the decals for your hood projects. I love doing stuff like this. I thought about buying up some hoods to do livery designs and selling them. m42b32 and SteelBlue 2 Quote Link to comment Share on other sites More sharing options...
straight6pwr Posted August 22, 2020 Report Share Posted August 22, 2020 the minute i get my hands on another e30 hood, youll be gettin a call from me the question is: tictac, bastos, or fina visian and Bassboy3313 2 Quote Link to comment Share on other sites More sharing options...
visian Posted August 22, 2020 Report Share Posted August 22, 2020 Question, this may be a silly question to ask in a BMW forum, but y’all are smart and know people. I’m looking for a SAAB fanatic for a friend who has an 87 900 turbo (awesome) in need of some TLC. Anyone out there know of someone who is a SAAB expert? It’s a little niche, I know. Quote Link to comment Share on other sites More sharing options...
visian Posted August 22, 2020 Report Share Posted August 22, 2020 On 5/23/2020 at 6:45 PM, The Full Banana said: If my count is correct, it was over 10 years ago that I sold my previous e30 to @visian , so it was time to pick up another. It’s a 1987 325i 5 speed in schwarz over cardinal. My friend’s parents owned it for the last 10 years but only put 3,000 miles on it during that time, and it’s been stored out of the elements. We’ll see if this gets a thread or not. I’m not planning on going crazy with this car. This will be the simple, carefree summer cruiser to serve as a counterpart to the angry, money pit Volvo. Congrats @thefullbanana just saw this! Enjoy the vert Quote Link to comment Share on other sites More sharing options...
Bassboy3313 Posted August 23, 2020 Report Share Posted August 23, 2020 10 hours ago, visian said: Question, this may be a silly question to ask in a BMW forum, but y’all are smart and know people. I’m looking for a SAAB fanatic for a friend who has an 87 900 turbo (awesome) in need of some TLC. Anyone out there know of someone who is a SAAB expert? It’s a little niche, I know. He want to sell it? Quote Link to comment Share on other sites More sharing options...
patsbimmer1 Posted August 23, 2020 Report Share Posted August 23, 2020 13 hours ago, visian said: Question, this may be a silly question to ask in a BMW forum, but y’all are smart and know people. I’m looking for a SAAB fanatic for a friend who has an 87 900 turbo (awesome) in need of some TLC. Anyone out there know of someone who is a SAAB expert? It’s a little niche, I know. I actually do know a guy. Can you send me info. visian 1 Quote Link to comment Share on other sites More sharing options...
m42b32 Posted August 23, 2020 Report Share Posted August 23, 2020 On 8/22/2020 at 11:07 AM, visian said: Question, this may be a silly question to ask in a BMW forum, but y’all are smart and know people. I’m looking for a SAAB fanatic for a friend who has an 87 900 turbo (awesome) in need of some TLC. Anyone out there know of someone who is a SAAB expert? It’s a little niche, I know. SAABcentral.com is a pretty useful forum that has a lot of 900 content! I had a '91 900 for a bit a few years back (not in this area unfortunately so I don't know of anyone local), I miss looking at and driving that car but I really don't really miss the endless hunting for parts... visian 1 Quote Link to comment Share on other sites More sharing options...
visian Posted August 23, 2020 Report Share Posted August 23, 2020 3 hours ago, m42b32 said: SAABcentral.com is a pretty useful forum that has a lot of 900 content! I had a '91 900 for a bit a few years back (not in this area unfortunately so I don't know of anyone local), I miss looking at and driving that car but I really don't really miss the endless hunting for parts... Love it! What locality was it? We are actually in the Chicago area and don’t mind a bit of a trip for the right expert. I’ll check out SAAB central too, thanks for the tip! Quote Link to comment Share on other sites More sharing options...
visian Posted August 23, 2020 Report Share Posted August 23, 2020 14 hours ago, patsbimmer1 said: I actually do know a guy. Can you send me info. PM’d Quote Link to comment Share on other sites More sharing options...
m42b32 Posted August 23, 2020 Report Share Posted August 23, 2020 1 hour ago, visian said: Love it! What locality was it? We are actually in the Chicago area and don’t mind a bit of a trip for the right expert. I’ll check out SAAB central too, thanks for the tip! Out in PA near Lancaster, I can't remember the shop exactly but it was recommended by a friend out there, would be quite the drive! I never had anything done by them so I can't comment on that part, just called them looking for parts and they seemed very knowledgeable. visian 1 Quote Link to comment Share on other sites More sharing options...
HipMF Posted August 28, 2020 Report Share Posted August 28, 2020 Took almost 2 years, but I finally filled a McMaster bag with McMaster bags.I got into the electrical engineering department at work a couple weeks ago. Not sure if I can start calling myself an engineer just yet, but I'm on the right path. I'll still be doing fixtures and ordering more stuff from McMaster, but probably not at the same rate that I have been for the past few years. Jdesign, B C, m42b32 and 2 others 2 3 Quote Link to comment Share on other sites More sharing options...
B C Posted August 28, 2020 Author Report Share Posted August 28, 2020 You will earn an honorary degree from the New Berlin Institute of Black BMWs if you can get a 3D model of a McBastard bag. They have a 3D model of everything else..... Quote Link to comment Share on other sites More sharing options...
Nick_F Posted August 31, 2020 Report Share Posted August 31, 2020 well it has finally set in that my 335 is gone and the 528 is just not doing it for me. Now to decide on a "project car" or a new daily that is a little more fun Rekpoint 1 Quote Link to comment Share on other sites More sharing options...
B C Posted September 1, 2020 Author Report Share Posted September 1, 2020 23 hours ago, Nick_F said: well it has finally set in that my 335 is gone and the 528 is just not doing it for me. Now to decide on a "project car" or a new daily that is a little more fun Spoiler alert: nothing ever fully itches the scratch. The N54/N55 torque delivery can ruin your expectations for anything that isnt a V8/turbo 6. I say LS swap an E36. Quote Link to comment Share on other sites More sharing options...
patsbimmer1 Posted September 1, 2020 Report Share Posted September 1, 2020 1 hour ago, B C said: Spoiler alert: nothing ever fully itches the scratch. The N54/N55 torque delivery can ruin your expectations for anything that isnt a V8/turbo 6. I say LS swap an E36. I would like to respectfully disagree and say that torque is overrated. S65 FTW. HipMF 1 Quote Link to comment Share on other sites More sharing options...
Nick_F Posted September 1, 2020 Report Share Posted September 1, 2020 I have been looking at a 340 but I would love to find a manual one which doesnt seem like it will be easy. I hate to say it but a golf r is seeming like a good idea.... and an e46 project Quote Link to comment Share on other sites More sharing options...
YoungCR Posted September 2, 2020 Report Share Posted September 2, 2020 12 hours ago, patsbimmer1 said: I would like to respectfully disagree and say that torque is overrated. S65 FTW. S65 is the exception. S85 not so much in my book because there isn't much in the mid range. Kinda related, FB memory from driving the first F10 M5 Concours got in. Fun part and what I'll never understand is the M5 didn't have a valet mode on like the E92 335is did. Sure was fun experiencng 500ft/lbs of torque right out of the gate 😎 patsbimmer1 1 Quote Link to comment Share on other sites More sharing options...
patsbimmer1 Posted September 2, 2020 Report Share Posted September 2, 2020 9 hours ago, YoungCR said: S65 is the exception. S85 not so much in my book because there isn't much in the mid range. Kinda related, FB memory from driving the first F10 M5 Concours got in. Fun part and what I'll never understand is the M5 didn't have a valet mode on like the E92 335is did. Sure was fun experiencng 500ft/lbs of torque right out of the gate 😎 I love the F10 M5. I wish that engine was more reliable or at least less expensive to repair. Quote Link to comment Share on other sites More sharing options...
REKIII Posted September 2, 2020 Report Share Posted September 2, 2020 Manual F10 M5 would be a great daily driver. So rare though. Quote Link to comment Share on other sites More sharing options...
