SteelBlue Posted October 16, 2018 Report Share Posted October 16, 2018 5 hours ago, Jdesign said: Work VSXX Didn’t know they made these in 4x100 Quote Link to comment Share on other sites More sharing options...
Jdesign Posted October 16, 2018 Report Share Posted October 16, 2018 15 hours ago, SteelBlue said: Didn’t know they made these in 4x100 They do, they are just not as common, or rare if you will.. Quote Link to comment Share on other sites More sharing options...
patsbimmer1 Posted October 20, 2018 Report Share Posted October 20, 2018 450whp... holy fuck! That thing's gotta move! Quote Link to comment Share on other sites More sharing options...
Earl Posted October 20, 2018 Report Share Posted October 20, 2018 1 hour ago, patsbimmer1 said: 450whp... holy fuck! That thing's gotta move! It is definitely a riot riding in the passenger seat. Especially when it's sideways=) patsbimmer1 1 Quote Link to comment Share on other sites More sharing options...
SamHolzmann Posted October 23, 2018 Author Report Share Posted October 23, 2018 On 10/16/2018 at 12:15 PM, Jdesign said: They do, they are just not as common, or rare if you will.. Id love to find another pair of them to use for drift spares, but until then Jdesign 1 Quote Link to comment Share on other sites More sharing options...
SamHolzmann Posted October 23, 2018 Author Report Share Posted October 23, 2018 It also makes more low end torque than max whp.... Starting standstill burnouts in 3rd gear has been a reoccurring thing throughout the year. nick.e46.330i., patsbimmer1 and Jdesign 3 Quote Link to comment Share on other sites More sharing options...
SamHolzmann Posted February 25, 2019 Author Report Share Posted February 25, 2019 Picked up the paint gun for the first time in about a year. Turned out pretty alright. Jdesign and HipMF 2 Quote Link to comment Share on other sites More sharing options...
SamHolzmann Posted April 15, 2019 Author Report Share Posted April 15, 2019 Ahhhh the good ole build thread. Been a very tame winter I wasnt planning to rewrap the whole car but after a few panels we noticed my car has seemed to turn and orange color. So a whole re wrap began. Not sure exactly why is changed, but i imagine the level of heat the rear tires gave off, the dirt build up after drift days, and the fact the I never took that great care of the outside are definitely factors. Next, after burning up a ton of coil packing wires last year, @Tkuhn rerouted a couple things and make everything quick disconnect so if they burn up I can just plug a new set in instead of rewiring. Currently designing some clips to hold the connectors down. Still fighting cooling issues, i finally decided to install an oil cooler with the s54 oil filter housing @DrLeadFoot sold me like a year ago. Putting the cooler in the brake duct/fog should provide the freshest air possible. Getting into 3D printing awhile back I designed and printed some custom ducting to get all the air flow possible. Pictures are of the V1.2 duct, V1.3 (last ducting picture) has been printed with small changes to make fit up to valance perfect. I have some plans for 3D printed radiator ducting, but those plans are on the back burner till the car is up and running. Lastly, the whole kit on the car got fixed and freshened up along with ditching the IS side skirts I had on the car for something that a little lower. 99% of the car will be white this year rather than the white with black lower ascents. Boris3, P_Roloff, B C and 4 others 7 Quote Link to comment Share on other sites More sharing options...
YoungCR Posted April 16, 2019 Report Share Posted April 16, 2019 Great job on the brake ducts. Quote Link to comment Share on other sites More sharing options...
SamHolzmann Posted June 8, 2020 Author Report Share Posted June 8, 2020 Finally a build update: I cut the front of my car off, built a tube front, and then everything decided to snowball. With the tube front done, I decided to do some wheel tubes to keep water/dirt out. I've always wanted to experiment with composites and saw this as an opportunity. After modeling the entire tube front, I created the wheel tub in solidworks, 3d printed the molds, and created carbon fiber wheel tubs/liners. Also, a special resin was used and the passenger side tube was post heated allowing to withstands 500+ deg temperatures. The tube front moved the position of the oil cooler, therefore a new ducting system had to be designed. Made up some bumper brackets to adapt the factory crash bar. Once everything critical was mocked up the bay was painted, finally assembly has started and is beginning to start to look like a car again. I still have to finish painting a few of the brackets and reclear all of the carbon pieces. I know I have missed a lot of small details, hopefully they make it here sooner than later. suspenceful, HipMF, patsbimmer1 and 5 others 8 Quote Link to comment Share on other sites More sharing options...
SamHolzmann Posted August 20, 2021 Author Report Share Posted August 20, 2021 About that time of the year to throw together a build update. Going to start with a photo dump, will go into detail eventually. Ill get to everything eventually, but let me know what you would like to hear about. 🙂 Boris3, m42b32 and Rekpoint 3 Quote Link to comment Share on other sites More sharing options...
GunMetalGrey Posted August 20, 2021 Report Share Posted August 20, 2021 4 hours ago, SamHolzmann said: let me know what you would like to hear about Does it go Brrrr? Quote Link to comment Share on other sites More sharing options...
