DrLeadFoot Posted March 23, 2015 Author Report Share Posted March 23, 2015 Were they designed to fit the old one? Quote Link to comment Share on other sites More sharing options...
Earl Posted March 23, 2015 Report Share Posted March 23, 2015 Yup Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted March 23, 2015 Author Report Share Posted March 23, 2015 Thanks for the heads up Quote Link to comment Share on other sites More sharing options...
Earl Posted March 23, 2015 Report Share Posted March 23, 2015 No problem=) Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted March 24, 2015 Author Report Share Posted March 24, 2015 All new everythingRigged upTorqued to 74 ft/lbs. UPS should be delivering the SS slave cylinder line today. I'll get that installed and bleed the system. Tomorrow the DSSR should be here. More than likely will have to sand down the selector to make it work. After that all I'll have to do is:- Drive shaft- Diff and axel- Change oil- Turbo gasket- Cut the tial BOV spring a little- Shifter gasket thing, boot and ZHP knob Quote Link to comment Share on other sites More sharing options...
jc43089 Posted March 24, 2015 Report Share Posted March 24, 2015 So close, I'm sure you are ready for boosting! Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted March 24, 2015 Author Report Share Posted March 24, 2015 So close, I'm sure you are ready for boosting! Heading back into the garage now!! jc43089 1 Quote Link to comment Share on other sites More sharing options...
Bassboy3313 Posted March 24, 2015 Report Share Posted March 24, 2015 You're flying through this thing! Keep up the awesome work Quote Link to comment Share on other sites More sharing options...
wasnt m3 Posted March 24, 2015 Report Share Posted March 24, 2015 Must be nice to sit at home all day working on your car and taking pictures! B C 1 Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted March 24, 2015 Author Report Share Posted March 24, 2015 You're flying through this thing! Keep up the awesome workThanks!!Must be nice to sit at home all day working on your car and taking pictures!Haha! The life of a Realtor. I'm taking calls, scheduling appointments and wrapping up some accepted offers. I have a rental showing in Stallis at 5:30. Anyone want a 3br 2ba house for $1400? Quote Link to comment Share on other sites More sharing options...
B C Posted March 24, 2015 Report Share Posted March 24, 2015 Stallis blows wasnt m3, DrLeadFoot and andyhundley 3 Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted March 25, 2015 Author Report Share Posted March 25, 2015 Back in the garage...Took the red/blk wire loop out of the door connector by splicing it out. Once I connected the wires something clicked in the central locking unit or interior light module. Good sign??This might be the problem. Central Locking Unit.Turned my attention to the stereo system.Got a new sub amp. 600w Kenwood to replace my old 500w Alpine.Also got new 3 new Stinger RC cables and routed them on the drivers side hopefully to eliminate the whining that matches the RPMs when they vary.Headed back into the bimmer cave now! Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted March 25, 2015 Author Report Share Posted March 25, 2015 Hooked up,the new amp and nada. Took the speaker out and tested the two coils. 2ohms a piece. First one looks good. Second one not so much. Sorry for the iPad pics. Camera battery died. Other things I got done. - Tried to bleed the slave but the pedal doesn't feel right. It doesn't sit on the floor when pressed. It's spongie feel to it. I'm using an e36 m3 slave. Any tips? Also was using a vacuum pump on the slave bleeder while having my fiancée pump and hold the pedal. - Cut a ring out of my BOV. I'll order the replacement springs tomorrow but there is no rush. The yellow spring was in there from Tial. - Replaced the passenger side fog light. The old one had a crack in it. - Cleaned up a bit. Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted March 25, 2015 Author Report Share Posted March 25, 2015 Scooped up a new sub this morning.Wired it up to 2 ohms and installed it.My next project. Installing a working glove box to hide all this.UPS just dropped of a small box! Into the garage!! Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted March 26, 2015 Author Report Share Posted March 26, 2015 Got the DSSR in the mail.Had to grind down the selector end a bit to make it fit. #EarlAt home.The final piece to finish putting the interior back together.E21 mounts and the powder coated brace. #SnapDrive shaft bolted up, CSB preloaded, tunnel cover and powder coated brace installed.Harness from the PO.My E30 M3 interior from my old car. I need to clean and condition everything.Where should I put these?? #Bassboy Quote Link to comment Share on other sites More sharing options...
patsbimmer1 Posted March 26, 2015 Report Share Posted March 26, 2015 I love that zhp shift knob! Quote Link to comment Share on other sites More sharing options...
wasnt m3 Posted March 26, 2015 Report Share Posted March 26, 2015 Where should I put these?? #BassboyNot on your car. ClassE, The Full Banana and DrLeadFoot 3 Quote Link to comment Share on other sites More sharing options...
YoungCR Posted March 26, 2015 Report Share Posted March 26, 2015 ^or under the trunk or hood Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted March 27, 2015 Author Report Share Posted March 27, 2015 I forgot to mention that I found my Valentine 1 radar detector! Super pumped about that. Update of the to do list: - Turbo T3 gasket (hopefully it will get delivered tomorrow). - Attach oil drain hose from turbo. - Add fluid to the diff and install. - Change oil. - Go over intercooler piping t-clamps to check for loose ones. - Swap trunk lids. - Take off roof rack. - Wash, wax and windows. The only thing I'm worried about is the clutch bleeding. Pedal still feels a bit soft. Quote Link to comment Share on other sites More sharing options...
wasnt m3 Posted March 27, 2015 Report Share Posted March 27, 2015 I envy your ability to make such fast progress. Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted March 27, 2015 Author Report Share Posted March 27, 2015 I envy your ability to make such fast progress. I'm trying to fly through everything while doing it right. Everything that I can get a torque wrench on is tightened to spec, blue loc-tite is almost everywhere and new parts are being used 75% of the time. I best finish soon as my hands have cuts all over them and the mechanic hand look is in full effect. Kinda sketch when I'm in a suit showing prospective buyers houses... Quote Link to comment Share on other sites More sharing options...
andyhundley Posted March 27, 2015 Report Share Posted March 27, 2015 Can you take some better pics of the rear M3 seat fitment? Ive always been curious how they fit. Quote Link to comment Share on other sites More sharing options...
wasnt m3 Posted March 27, 2015 Report Share Posted March 27, 2015 All e30 coupe chassis are the same, aren't they? I don't see why an e30 m3 rear seat would fit a 325 any different. DrLeadFoot 1 Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted March 28, 2015 Author Report Share Posted March 28, 2015 Got the ECS T3 solid gasket in the mail from @Frank_Mopar!Installed it with some copper RTV.Had to track down the Snap-On dealer to get a male 14mm allen socket for the differential fill hole. Picked this up too and it's the bee's knees.The 14mm allen lead to this. Please don't judge my washers:dontknow:The subframe diff mounting hardware. 16mm bolts and thick washers from a M-coupe if I remember correctly.Which lead to this.Oil change.I drained my crank case catch can that draws vacuum from the exhaust. Nasty...Who wants to clean this up?!!?Some more pics of the e30 M3 rear seat.Washed off the garage.Goodnight. B C 1 Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted March 28, 2015 Report Share Posted March 28, 2015 Disorganized garages drive me insane!!!! 5s that shiz homie! Dat wang is pretty snazzy B C 1 Quote Link to comment Share on other sites More sharing options...
