DrLeadFoot Posted September 16, 2014 Author Report Share Posted September 16, 2014 Am I missing the windage tray? Quote Link to comment Share on other sites More sharing options...
Earl Posted September 16, 2014 Report Share Posted September 16, 2014 ...looks like it Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted September 16, 2014 Author Report Share Posted September 16, 2014 Is it nessesary? Hope not cuz the pan is on and torqued. ........ Quote Link to comment Share on other sites More sharing options...
B C Posted September 17, 2014 Report Share Posted September 17, 2014 Not necessary, MEGASQUIRT is necessary You are mostly just losing a little bit of power to parasitic losses . Without megasquirt you are losing out on lots of power Get some. DrLeadFoot and patsbimmer1 2 Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted September 17, 2014 Author Report Share Posted September 17, 2014 Might do this before getting mega. https://www.google.com/url?sa=t&source=web&cd=3&ved=0CCUQFjAC&url=http%3A%2F%2Fwww.r3vlimited.com%2Fboard%2Fshowthread.php%3Ft%3D119358&rct=j&q=irsc4%20rear%20suspension%20e30%20bmw&ei=XOcYVN2xLYvKaIqqgMAC&usg=AFQjCNG1rcp0bbqGJIl3zo3kKTjqMYNhgg&bvm=bv.75558745,d.d2s Quote Link to comment Share on other sites More sharing options...
B C Posted September 17, 2014 Report Share Posted September 17, 2014 Thats full on dragster mode Needs more broken looking launches with stock semi-trailing arm rear suspension DrLeadFoot 1 Quote Link to comment Share on other sites More sharing options...
Earl Posted September 17, 2014 Report Share Posted September 17, 2014 DrLeadFoot 1 Quote Link to comment Share on other sites More sharing options...
GunMetalGrey Posted September 17, 2014 Report Share Posted September 17, 2014 Get some wheels with a reasonable offset so you can run some real tires (your current tires are silly being 225 or 235) and go from there. Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted September 18, 2014 Author Report Share Posted September 18, 2014 I'm running 215's haha.The oil pan is on! Might do some work tonight.Update on the to do list:- Install new motor mount bolts to the passenger side. Drivers is done. DONE- Torque down transmission. DONE- Prime and paint the frame where and front subframe connect. DONE- Install subframe. DONE- Install steering rack and skid plate. DONE- Intake manifold, throttle body and hook up charge pipes. DONE- Radiator and fluid.- Add oil.- Turn motor over by hand 20 some times to pump the oil through the ant farm.- Install and bleed rear calipers. DONE- DRIVE!! Quote Link to comment Share on other sites More sharing options...
GunMetalGrey Posted September 18, 2014 Report Share Posted September 18, 2014 Your 215's make me laugh!Also, you can use the starter to prime the engine, just pull the fuel pump fuse. DrLeadFoot 1 Quote Link to comment Share on other sites More sharing options...
B C Posted September 18, 2014 Report Share Posted September 18, 2014 remove the timing chain so that the pistons will be slowed down and it will reduce ring wear while priming. Quote Link to comment Share on other sites More sharing options...
jc43089 Posted September 18, 2014 Report Share Posted September 18, 2014 In all seriousness, I usually prime an engine by removing the fuel pump fuse and pulling the spark plugs, no compression = no load on the bearings and it spins over much faster. It still takes longer than you think it would to build pressure in a new engine but yours wasn't fully disassembled. B C and DrLeadFoot 2 Quote Link to comment Share on other sites More sharing options...
B C Posted September 18, 2014 Report Share Posted September 18, 2014 Just bite down on a pillow and crank it already. Rowleym and jc43089 2 Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted September 19, 2014 Author Report Share Posted September 19, 2014 Knocking things off the list!Subframe all torqued down.Steering rack and skid plate on.On the ground!!!! #beentoolongGetting close!!! Quote Link to comment Share on other sites More sharing options...
wasnt m3 Posted September 19, 2014 Report Share Posted September 19, 2014 You need to paint your control arms! Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted September 19, 2014 Author Report Share Posted September 19, 2014 You need to paint your control arms! I know...I know... I just want to drive! Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted September 19, 2014 Author Report Share Posted September 19, 2014 Getting closer! Need to get a new brass crush ring for the boost gauge. The original hose was crimped at the nut. Then I'll be good to go.The crank torque tool should be arriving today. Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted September 23, 2014 Author Report Share Posted September 23, 2014 Rear calipers and new Hawk HPS pads on. Ready for the road!Got my Jesus bolt torqued down. New updated list:-Charge battery a little-Install radiator-Add fluids -Prime oil system-Fire it up! Quote Link to comment Share on other sites More sharing options...
jc43089 Posted September 23, 2014 Report Share Posted September 23, 2014 Almost there. I have HPS pads on our Maxima and very happy with them, excellent feeling street pad and they seem to last forever, I think they are around 40k and still over half of the material left. Not sure if it matters much but they are on Brembo slotted rotors as well. DrLeadFoot 1 Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted September 24, 2014 Author Report Share Posted September 24, 2014 Doing some more wedding planning today which means wrenching on the bimmer and sending emails with the fiancee! Quote Link to comment Share on other sites More sharing options...
YoungCR Posted September 24, 2014 Report Share Posted September 24, 2014 I hope this is your get away car and you do a nasty burn out after you tie the knot haha! #h3gon3 wasnt m3, DrLeadFoot and B C 3 Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted September 30, 2014 Author Report Share Posted September 30, 2014 On the road again!!!!!!! Quote Link to comment Share on other sites More sharing options...
Earl Posted September 30, 2014 Report Share Posted September 30, 2014 Video of a burnout or bust! Quote Link to comment Share on other sites More sharing options...
B C Posted September 30, 2014 Report Share Posted September 30, 2014 bassboy said he would do a burnout first, lets wait for him to post his burnout video. Quote Link to comment Share on other sites More sharing options...
Bassboy3313 Posted September 30, 2014 Report Share Posted September 30, 2014 BURNOUT!!!!!!!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
