Jdesign Posted October 3, 2017 Author Report Share Posted October 3, 2017 With much headache and research I have discovered that the new diff I welded is for an E46. On the hunt for an E36 unit thats open in the 3.91-4.44 range. Quote Link to comment Share on other sites More sharing options...
Jdesign Posted October 4, 2017 Author Report Share Posted October 4, 2017 2 hours ago, Jdesign said: With much headache and research I have discovered that the new diff I welded is for an E46. On the hunt for an E36 unit thats open in the 3.91-4.44 range. @Daggerty to the rescue! I have another diff to weld, thanks again! Quote Link to comment Share on other sites More sharing options...
Jdesign Posted October 5, 2017 Author Report Share Posted October 5, 2017 I plumbed the hydro handbrake and mounted it last night. Bent all the lines, flared them, and was able to secure them into the oem location for the most part. Im happy with the results, I just hope they don't leak. I was unable to bleed the system as I was by myself and too lazy to use the power bleeder. I also trimmed the silicone mat I made to cover the giant hole in the tunnel where the shift comes through. I plan on welding the new diff I got today and installing it asap. On a side note; bubble flares suck. Bubble flare and adapter Double flare and adapter Hardline mocked up with grommets in the tunnel Its hard to capture how well the lines are fit to the chassis of the car underneath but there is some factory formed areas that help tuck the lines away from anything that might snag them. You can kinda see that below. Note that I also added some urethane tubing to areas of the lines that could possibly rub on surrounding parts. Final setup with the tunnel boot/mat trimmed and a joystick for a yet to be determined purpose. If anyone has and good ideas on what the joystick should do, please chime in Quote Link to comment Share on other sites More sharing options...
B C Posted October 5, 2017 Report Share Posted October 5, 2017 Rofl @ the joystick. You should connect washer nozzles on the roof that spray front/back/left/right based on the joystick position You know, zombie deterrent. Jdesign 1 Quote Link to comment Share on other sites More sharing options...
patsbimmer1 Posted October 5, 2017 Report Share Posted October 5, 2017 Your flares look pretty good! If you do it enough then i'd suggest a hydraulic flare tool. They make a huge difference! Jdesign 1 Quote Link to comment Share on other sites More sharing options...
Earl Posted October 5, 2017 Report Share Posted October 5, 2017 The trigger on the joystick should cause your headlights to flash violently and the car should make a childs laser sound=) Jdesign 1 Quote Link to comment Share on other sites More sharing options...
Jdesign Posted October 5, 2017 Author Report Share Posted October 5, 2017 9 minutes ago, Snap said: Rofl @ the joystick. You should connect washer nozzles on the roof that spray front/back/left/right based on the joystick position You know, zombie deterrent. HAHA good thinking! But thats also alot of thinking. Im not a programmer but im sure I can figure it out. I just dont know if I want to put that much time into it. 7 minutes ago, patsbimmer1 said: Your flares look pretty good! If you do it enough then i'd suggest a hydraulic flare tool. They make a huge difference! Thanks! Ive done my fair share of hard lines in the past. The hydraulic tools are awesome and I have used them at CS working on Porsche's. Way to much money for how often I do lines though. 1 minute ago, Earl said: The trigger on the joystick should cause your headlights to flash violently and the car should make a childs laser sound=) This is more in line of what I was thinking. One button is a strobe light the other is laser sounds. pew-pew-pew! Earl 1 Quote Link to comment Share on other sites More sharing options...
Jdesign Posted October 5, 2017 Author Report Share Posted October 5, 2017 Also, I was going to make large uprights for the back of the rack and wing, allowing the wing to sit atop the roof rack, but seeing it just sitting on the trunk, I am starting to think differently. I added pics of random uprights and then the original pic. Also maybe the Joystick controls strobeing LEDs inside of roof mounted cannon things? suspenceful, Bassboy3313 and cpandrewschmidt 3 Quote Link to comment Share on other sites More sharing options...
Jdesign Posted October 9, 2017 Author Report Share Posted October 9, 2017 That'll hold. Didnt make it to the event though. Other priorities and PO stupidities prevented an easy bolt in procedure. Remember the half a bolt head bolt in the diff? Yeah that's because someone drilled the diff out when they lost/stripped the original bolt. The sub frame was an easier fix and I was able to tap in new threads. Only problem I still have is that the subframe should be raised. With the 1pc driveshaft the universal joint will hit the chassis under heavy torque. GunMetalGrey 1 Quote Link to comment Share on other sites More sharing options...
jc43089 Posted October 9, 2017 Report Share Posted October 9, 2017 I broke that differential mount bolt once, it was super fun. I made a fancy bushing that is not necessary but you may have an easier time putting the bolt in the other way. I had to grind some clearance in the casting to use a 1/2" bolt. http://www.wibimmers.com/board/index.php?/topic/4778-fancy-stancy-325is/&page=3 Quote Link to comment Share on other sites More sharing options...
Jdesign Posted October 10, 2017 Author Report Share Posted October 10, 2017 16 hours ago, jc43089 said: I broke that differential mount bolt once, it was super fun. I made a fancy bushing that is not necessary but you may have an easier time putting the bolt in the other way. I had to grind some clearance in the casting to use a 1/2" bolt. http://www.wibimmers.com/board/index.php?/topic/4778-fancy-stancy-325is/&page=3 LOL yup. That one. I bought a new Grade 10 bolt for the new diff that still has the threads in it. Worked like a charm and its driving again. Drove the car around the block and the brake fluid light came on after a few hard stabs of the brakes. Totally still have air in the lines. I never installed a hydro brake before so I made a mistake. Apparently you are supposed to push the pedal and pull the lever when bleeding the brakes. Back on the lift it goes! Quote Link to comment Share on other sites More sharing options...
Jdesign Posted October 17, 2017 Author Report Share Posted October 17, 2017 Well more GREAT (sarcastic) news. I managed to re-bleed everything, this time with a pressure bleeder and the eBay special hydro-brake I have is not only the wrong size for the rear calipers, it also now has "cylinder drift." This means the cylinder seal is failing internally as I have 100% no air in the lines, the brakes are firm and so is the level, but with enough force, the following happens: (*also note the quality creaking) IMG_4849.MOV <---------video Quote Link to comment Share on other sites More sharing options...
jc43089 Posted October 17, 2017 Report Share Posted October 17, 2017 Yea looks like the piston seals are junk. Awesome ebay parts... Quote Link to comment Share on other sites More sharing options...
Jdesign Posted October 17, 2017 Author Report Share Posted October 17, 2017 27 minutes ago, jc43089 said: Yea looks like the piston seals are junk. Awesome ebay parts... Thanks! bought em myself. Quote Link to comment Share on other sites More sharing options...
Jdesign Posted October 18, 2017 Author Report Share Posted October 18, 2017 @KaiserRolls Is going to sell and ship me the hydro brake he claims he wont need. In the meantime I finally rearranged the cars in the shop and moved some of the spare wheels to the roof of the E36. I plan on building a large rack on the wall to hold all of the wheels and tires I have just sitting on the ground to free up some floor space. I was hoping I could fit more wheels on the roof, but depending on diameter, width, and the spacing of the bars on the rack it only holds about 3 rows. Quote Link to comment Share on other sites More sharing options...
Daggerty Posted October 18, 2017 Report Share Posted October 18, 2017 On 10/17/2017 at 1:00 PM, jc43089 said: Yea looks like the piston seals are junk. Awesome ebay parts... Quick scrolling through and saw this and thought the classic wibimmers compression test. At least it's nothing major. B C 1 Quote Link to comment Share on other sites More sharing options...
YoungCR Posted October 19, 2017 Report Share Posted October 19, 2017 3 hours ago, Daggerty said: Quick scrolling through and saw this and thought the classic wibimmers compression test. At least it's nothing major. My first reaction also lol. GunMetalGrey, KaiserRolls and Jdesign 3 Quote Link to comment Share on other sites More sharing options...
Jdesign Posted October 19, 2017 Author Report Share Posted October 19, 2017 15 hours ago, Daggerty said: Quick scrolling through and saw this and thought the classic wibimmers compression test. At least it's nothing major. "not yet" Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted October 19, 2017 Report Share Posted October 19, 2017 I promise I won’t need it lol Quote Link to comment Share on other sites More sharing options...
Jdesign Posted October 19, 2017 Author Report Share Posted October 19, 2017 If I blow up said motor, I buy another for $300. Cheap motor, cheap fun. I dont see a problem with that. Earl 1 Quote Link to comment Share on other sites More sharing options...
Jdesign Posted October 23, 2017 Author Report Share Posted October 23, 2017 Finally painted the roof rack after a few drinky poos at about 3am on Friday night, outside, in the dark. It turned out okay but I obviously missed a few spots. Changed the whole appearance of the car though. Its crazy how many people have mixed opinions on the roof rack. It makes the car a total conversation piece now. I also installed the ASD handbrake from @KaiserRolls and what a difference!! Compared to the ebay lever it locks up the wheels perfectly even with the sticky Potenzas on there. KaiserRolls 1 Quote Link to comment Share on other sites More sharing options...
Jdesign Posted November 7, 2017 Author Report Share Posted November 7, 2017 Thinking about graphics or livery to make the car appear more "phuturistic" and this is what I was thinking, black on black or something similar. Do you guys have any thoughts or suggestions? The Full Banana and suspenceful 2 Quote Link to comment Share on other sites More sharing options...
jc43089 Posted November 7, 2017 Report Share Posted November 7, 2017 Sweet action! I like it. Quote Link to comment Share on other sites More sharing options...
m42b32 Posted November 7, 2017 Report Share Posted November 7, 2017 That looks fantastic! Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted November 7, 2017 Report Share Posted November 7, 2017 Needs more fender exit exhaust on a cut out Quote Link to comment Share on other sites More sharing options...
