Jdesign Posted March 17, 2020 Author Report Share Posted March 17, 2020 1 hour ago, REKIII said: Based on how the world is devolving, you better get this thing on the road sooner than later. 😮 Seems like the world is conforming to this thing, not the other way 'round. 🤪🙃 B C and REKIII 1 1 Quote Link to comment Share on other sites More sharing options...
B C Posted March 18, 2020 Report Share Posted March 18, 2020 You need to make at least one TP run in this thing and fill the dang roof rack. love seeing updates here 😀 Quote Link to comment Share on other sites More sharing options...
Jdesign Posted March 18, 2020 Author Report Share Posted March 18, 2020 13 hours ago, B C said: You need to make at least one TP run in this thing and fill the dang roof rack. T H I S. More progress last night. I got the AGK reinforcements welded in. It was more work than I expected, and I also had a quick panic as the fuel lines for the fuel expansion tank were still in the car and I may have had a small fire😆. Cleaned Mocked Welded Painted I also got all the rear brake lines replaced. My last challenge is to finish repainting the control arms, diff, and swap the delrin bushings from the old swing arms to the new ones. m42b32, B C, jc43089 and 1 other 4 Quote Link to comment Share on other sites More sharing options...
Jdesign Posted April 14, 2020 Author Report Share Posted April 14, 2020 So an update here is long overdue. With working from home I have had more time to work on projects at the shop but this one has got the most attention because it has been stuck on the lift. Lifting it wasn't as easy as I was expecting it to go, but it wasn't because of lifting it in general. It was more because I kept running into issues I wasn't anticipating. The steering actually worked out once the car was back on the ground, so luckily, all I needed to do up front was hammer the wheel wells back and remove the front bumper brackets. Then I ran into the axle stubs of the diff being too small. I should have known but I completely overlooked this and had to source stubs. Found some locally and the guy actually gave me a whole M3 diff for $40. Once the axles were in, and everything was in place, I went to install the brakes. Being an idiot, I forgot I had M3 brakes in a box, and I bought another set from @Sam_Holzmann Before that, I also learned that E46 brakes are not the same as the internet says. THE HARD WAY. Luckily I sold them right away and broke even. the brake shoes for the parking brake on the M3 stuff is bigger, and there is a casting tab that the shoes ride on not allowing non-M rotors to fit on the hubs. Although the caliper is the same, and the pads are the same, the carriers and spacing is also different. Another issue I ran into was the Fuel tank leak. the vent hose that goes to the expansion tank was ripped and I had to replace it. Now on the TI's and other BMW's there is an access panel. This car for some reason, does not have that, so I have to fish the hoses back through using a piece of wire and a lot of swearing. No lie, this alone took a good 4 hours. AND yes I know its not fuel hose, but I used what I had. Fumes are really only the main thing that pass through it anyways Another hiccup was the length needed for the rear shocks. Needing the extra height, I was able to find some coilover sleeves for the springs in a bin of spare parts, but that caused the length of the shocks to be way too short. I thought about how all these cheap CHYNAH coilovers use the same bodies and remembered that I had a set of brand new coilovers in a binn for the Lexus. Well suck me sideways, they worked, and added just enough length. Finally I set the car on the ground and ran into one last issue. The spacing of the tires to the mounting points of the swing arm just were not working. I cut away the rockers, and the quarters as much as I could, but it just wasn't enough. I ordered some 2" spacers and they gave me just enough clearance... and by just enough, I mean 1-2mm. Im hoping I can adjust everything a touch more so that it doesn't hit while driving, but I havent got to that step yet. I was able to seam seal the trunk after I welded in the new floors. I was also able to repurpose this access cover inside the car to cover the vent hole in the trunk that was missing. it almost looks like its was meant to be LOL. The car is on the ground now and everything is together. I still need to bleed the brakes and fix the radiator, but then it should be back in business. m42b32, B C, patsbimmer1 and 1 other 2 2 Quote Link to comment Share on other sites More sharing options...
patsbimmer1 Posted April 14, 2020 Report Share Posted April 14, 2020 #staypositivecambergang SteelBlue and Jdesign 2 Quote Link to comment Share on other sites More sharing options...
Jdesign Posted April 14, 2020 Author Report Share Posted April 14, 2020 2 hours ago, patsbimmer1 said: #staypositivecambergang I have yet to actually adjust the lower control arms, which is funny, because before there was negative camber (only like 1-2 degrees) but that just shows you how much the geometry changes in the travel of the suspension. Im also afraid that as I add camber it might make my rubbing/ interference issue with 31" tires worse. Fingers crossed for "self clearancing" videos. Quote Link to comment Share on other sites More sharing options...
patsbimmer1 Posted April 15, 2020 Report Share Posted April 15, 2020 In all honesty positive camber is probably a better driving experience in that car with those tires on it to make it a little less effort to turn. It just looks like an 80's pick up truck alignment lol. Quote Link to comment Share on other sites More sharing options...
jc43089 Posted April 15, 2020 Report Share Posted April 15, 2020 Love it! Also just saw your stickers, very appropriate. Jdesign 1 Quote Link to comment Share on other sites More sharing options...
HipMF Posted April 15, 2020 Report Share Posted April 15, 2020 This is the kind of stupidity I can really get behind. Well done.Can't wait to see what's next. Flares? Jdesign 1 Quote Link to comment Share on other sites More sharing options...
HipMF Posted April 15, 2020 Report Share Posted April 15, 2020 Or, on a more serious note: Jdesign, SteelBlue, m42b32 and 1 other 1 3 Quote Link to comment Share on other sites More sharing options...
SteelBlue Posted April 15, 2020 Report Share Posted April 15, 2020 Your spacers reminded me of something: suspenceful, HipMF and Jdesign 3 Quote Link to comment Share on other sites More sharing options...
Jdesign Posted November 27, 2020 Author Report Share Posted November 27, 2020 I havent posted on this site in awhile but I did manage to go out and about with this thing. It drives really well surprisingly with the big wheels and welded diff. I even managed to (painfully) drive it to Milwaukee and back. I will need to add some clearance to the rear quarters yet again as it rubs when the suspension is compressed hard in the rear. I would also like to add that it still does massive burnouts with the big wheels. HipMF, P_Roloff, Rekpoint and 2 others 5 Quote Link to comment Share on other sites More sharing options...
YoungCR Posted November 27, 2020 Report Share Posted November 27, 2020 love it! sports the wheel poke better than a bro truck Jdesign 1 Quote Link to comment Share on other sites More sharing options...
HipMF Posted November 29, 2020 Report Share Posted November 29, 2020 Can't imagine the number of strange looks/people taking picture while driving something like that to Milwaukee. On 11/27/2020 at 1:48 PM, Jdesign said: I even managed to (painfully) drive it to Milwaukee and back. Curious... what's the painful part? Rub? Steering wobble? What's this thing like to drive? Jdesign 1 Quote Link to comment Share on other sites More sharing options...
Jdesign Posted November 30, 2020 Author Report Share Posted November 30, 2020 On 11/28/2020 at 9:09 PM, HipMF said: Can't imagine the number of strange looks/people taking picture while driving something like that to Milwaukee. Curious... what's the painful part? Rub? Steering wobble? What's this thing like to drive? Surprisingly it drives straight and true with no noticeable shaking. I got it up to 90+ and it was fine. The painful part is that although it’s lifted, the suspension is very stiff and the race seat that’s in it is not comfortable for long journeys as half the padding is missing. Better seats would make it much more enjoyable to drive. Quote Link to comment Share on other sites More sharing options...
Jdesign Posted November 30, 2020 Author Report Share Posted November 30, 2020 Im still chasing the heat issue. Originally I replaced the cabin filter which had 10lbs of leaves and debris smashed into it. That somewhat fixed the heat, but I still have weak heat to the dash vents. I have a new heater valve in hopes that fixes my problem. The other thing it might be is the heater core which I plan to flush when I do the valve. Quote Link to comment Share on other sites More sharing options...
Jdesign Posted December 1, 2020 Author Report Share Posted December 1, 2020 Replaced the heater valve and flushed the heater core last night. It really needed it. It took a few buckets to finally get some clear water. After all this work, it seems like the heat is much better, but the flap door for the dash vents must be the issue. I get strong defrost and floor air, but not mid level. It sounds like the air is hitting something rather than flowing through. Might have to pull the dash apart. One last thing is I painted the wheels. It’s been bothering me because they looked so trashy. I must say the black isn’t dirty enough yet, but it looks a lot better. HipMF, P_Roloff, patsbimmer1 and 1 other 4 Quote Link to comment Share on other sites More sharing options...
jc43089 Posted December 2, 2020 Report Share Posted December 2, 2020 The flaps are operated by stepper motors. On my '93 I have had issues with intermittently the mid level ones won't open. The sound changes to a sound like the fan is blocked and whistling. I haven't tried fixing it though, but I imagine either the stepper has an issue or linkage is sticking. Quote Link to comment Share on other sites More sharing options...
Jdesign Posted December 4, 2020 Author Report Share Posted December 4, 2020 On 12/2/2020 at 10:06 AM, jc43089 said: The flaps are operated by stepper motors. On my '93 I have had issues with intermittently the mid level ones won't open. The sound changes to a sound like the fan is blocked and whistling. I haven't tried fixing it though, but I imagine either the stepper has an issue or linkage is sticking. YUP that's exactly what's going on. Ive watched the linkage and it all seems to move as its intended to. At this point im not sure what's the best (cheapest) option. I might just replace the steppers with manual levers or something stupid. I just want to fix it quick and easy. Quote Link to comment Share on other sites More sharing options...
Jdesign Posted December 20, 2020 Author Report Share Posted December 20, 2020 Welp I removed the steppers and just fixed the doors into my desired location. I officially have heat. I can still control the temp and all the vents so it might just stay this way. Driving it around nice and toasty. P_Roloff and B C 2 Quote Link to comment Share on other sites More sharing options...
YoungCR Posted December 20, 2020 Report Share Posted December 20, 2020 seeing that in a apartment basement garage makes me smile Jdesign 1 Quote Link to comment Share on other sites More sharing options...
B C Posted December 20, 2020 Report Share Posted December 20, 2020 Please tell me this is the winter daily driver. i’d love to see some old-timer get utterly confused about what kind of car it is by the sensory overload they would receive. Jdesign 1 Quote Link to comment Share on other sites More sharing options...
Jdesign Posted December 22, 2020 Author Report Share Posted December 22, 2020 On 12/20/2020 at 12:55 PM, B C said: Please tell me this is the winter daily driver. i’d love to see some old-timer get utterly confused about what kind of car it is by the sensory overload they would receive. The looks I get are hilarious. I will daily it as much as I can, although its kind a pain in the ass getting in and out of a fixed back race seat. Maneuvering around the target parking lot is also very obnoxious. KaiserRolls 1 Quote Link to comment Share on other sites More sharing options...
Jdesign Posted January 2, 2021 Author Report Share Posted January 2, 2021 White knuckle riot in the snow. Traction is limited with these old mud tires, and a welded diff makes almost any throttle input spin the tires. I will be sure to post here when I end up stuck in a ditch 🤣. jc43089, patsbimmer1 and P_Roloff 1 2 Quote Link to comment Share on other sites More sharing options...
Nick_08 Posted January 2, 2021 Report Share Posted January 2, 2021 This is a badass machine you've built here. It's gotta be fun to drive around. Can't imagine the looks/comments you get. 😆 Quote Link to comment Share on other sites More sharing options...
