GunMetalGrey Posted August 24, 2015 Report Share Posted August 24, 2015 I'm conflicted. .0015 is practically nothing, but I get your concern. I would give it a pass with 600 grit to see if any high and low spots show themselves and go from there I guess. I can confirm that the head gasket that you and I use squishes a lot, so it should have no issue with a .0015 variance Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted August 24, 2015 Author Report Share Posted August 24, 2015 I'm conflicted. .0015 is practically nothing, but I get your concern. I would give it a pass with 600 grit to see if any high and low spots show themselves and go from there I guess. I can confirm that the head gasket that you and I use squishes a lot, so it should have no issue with a .0015 variance Okay. Maybe I'll do that. Save my arms!! Sent from my SM-G900V using Tapatalk Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted August 25, 2015 Author Report Share Posted August 25, 2015 -Car on jack stands -Took Echo gas powered 191mph leaf blower and cleared underneath the car after removing oily cardboard -Move some other boxes around -Almost started doing the diff swap -Left garage Sent from my SM-G900V using Tapatalk B C 1 Quote Link to comment Share on other sites More sharing options...
B C Posted August 25, 2015 Report Share Posted August 25, 2015 -Car on jack stands -Took Echo gas powered 191mph leaf blower and cleared underneath the car after removing oily cardboard -Move some other boxes around -Almost started doing the diff swap -Left garage Sent from my SM-G900V using Tapatalk I was pretty sure this was a KaiserRolls post until I quadruple checked the username KaiserRolls 1 Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted August 25, 2015 Author Report Share Posted August 25, 2015 I was pretty sure this was a KaiserRolls post until I quadruple checked the username I'm getting my motivation though. Going back to basics, just go to the garage and chip away every day. Sent from my SM-G900V using Tapatalk Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted August 25, 2015 Author Report Share Posted August 25, 2015 Making boss moves Sent from my SM-G900V using Tapatalk Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted August 29, 2015 Author Report Share Posted August 29, 2015 I did something. Wrong end of the car but actually turned a bolt.2.93LSD $150 some bearing noise but it works! I'm keeping the cover I'll hopefully get the 2.93LSD w/60% lock Wangman Diff in there today/this weekend. B C 1 Quote Link to comment Share on other sites More sharing options...
Rowleym Posted August 29, 2015 Report Share Posted August 29, 2015 Are you not going to use a dual ear diff cover? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Earl Posted August 29, 2015 Report Share Posted August 29, 2015 ? What about your diff that you had built? Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted August 29, 2015 Author Report Share Posted August 29, 2015 Are you not going to use a dual ear diff cover? Sent from my iPhone using Tapatalk I was sold an e36ti diff cover......... I will probably add a reenforcement to the other side using the diff cover mounting holes as the diff mounting points. Sent from my SM-G900V using Tapatalk Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted August 29, 2015 Author Report Share Posted August 29, 2015 ? What about your diff that you had built? It's sitting in my garage in the box that it came in. Going to pop that in after I put the cover on and fill it with fluid. Sent from my SM-G900V using Tapatalk Quote Link to comment Share on other sites More sharing options...
B C Posted August 29, 2015 Report Share Posted August 29, 2015 Between new tires and the diff im thinking you need to keep some pepto chewables in the car so peoples stomachs dont end up on the dashboard from that insane acceleration DrLeadFoot and Jeff 2 Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted August 29, 2015 Author Report Share Posted August 29, 2015 I hope so!!! Sent from my SM-G900V using Tapatalk Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted August 30, 2015 Author Report Share Posted August 30, 2015 Did some Diff stuff and cleaned the garage.Like a Gilette commercial.Took the board down the alley then put it to use. Quote Link to comment Share on other sites More sharing options...
Doorman Posted August 30, 2015 Report Share Posted August 30, 2015 Looks like we've both been busy with diff work brother!! DrLeadFoot 1 Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted September 1, 2015 Author Report Share Posted September 1, 2015 Prepared the block with a sharpening stone. I'm glad I pulled the trigger on adding this step.Need to make that go in there. Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted September 1, 2015 Report Share Posted September 1, 2015 Looks like you're running out of real estate in there. GET IT. ITS A PUN. YOU SELL REAL ESTATE. AND YOURE RUNNING OUT. Monday was rough B C, DrLeadFoot, GunMetalGrey and 1 other 4 Quote Link to comment Share on other sites More sharing options...
ClassE Posted September 1, 2015 Report Share Posted September 1, 2015 Looks like you're running out of real estate in there. GET IT. ITS A PUN. YOU SELL REAL ESTATE. AND YOURE RUNNING OUT. Monday was roughIZ FUNNY CAUSE IZ REAL ESTATE JOKE!!! andyhundley 1 Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted September 1, 2015 Author Report Share Posted September 1, 2015 I'll get the head torque process started today or Thursday. I'm driving it in 2 weeks Sent from my SM-G900V using Tapatalk Bassboy3313 1 Quote Link to comment Share on other sites More sharing options...
GunMetalGrey Posted September 3, 2015 Report Share Posted September 3, 2015 I'll get the head torque process started today or Thursday. I'm driving it in 2 weeks Sent from my SM-G900V using TapatalkThose seem to be my famous last words Quote Link to comment Share on other sites More sharing options...
YoungCR Posted September 4, 2015 Report Share Posted September 4, 2015 Snap actually has voodoo dolls of you two and your cars. He breaks them so he can keep diagnosing your Megasquirt problems. Quote Link to comment Share on other sites More sharing options...
B C Posted September 4, 2015 Report Share Posted September 4, 2015 YoungCR 1 Quote Link to comment Share on other sites More sharing options...
ClassE Posted September 5, 2015 Report Share Posted September 5, 2015 SnatchChat tells me you got more done today... DrLeadFoot 1 Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted September 5, 2015 Author Report Share Posted September 5, 2015 A little progress was made. I'll update with pics tomorrow. - Head is torqued down to 35 ft/lbs. I'll recheck and go to 65 ft/lbs if they hold at 35 for the night. - Intake manifold is tapped and drilled for multi-port meth injection. - Mounted the distribution block and ran the 6 lines to the jet fittings. - Broke one jet from over tightening it. Sometimes I'd like not to learn anything new... - Picked up my diff cover and output shafts from Snap. I'm planning on getting the new diff in tomorrow morning. Sent from my SM-G900V using Tapatalk Quote Link to comment Share on other sites More sharing options...
B C Posted September 5, 2015 Report Share Posted September 5, 2015 Sometimes I'd like not to learn anything new... Quote of the decade right here Quote Link to comment Share on other sites More sharing options...
