jockhater2 Posted October 19, 2014 Report Share Posted October 19, 2014 I don't really see the vw in them. I like them a lot though. Simple yet sporty, and nice and clean.my vw has them...they are vw rims fo sho Quote Link to comment Share on other sites More sharing options...
GunMetalGrey Posted October 19, 2014 Author Report Share Posted October 19, 2014 Ha, digging up some old stuff huh?Almost two years ago! Quote Link to comment Share on other sites More sharing options...
jockhater2 Posted October 19, 2014 Report Share Posted October 19, 2014 Ha, digging up some old stuff huh?Almost two years ago!lol yeah. After I replied I wanted to delete my post because of how long ago it was. But this forum doesn't let you delete your comments. Quote Link to comment Share on other sites More sharing options...
Earl Posted October 19, 2014 Report Share Posted October 19, 2014 I definitely support your decision of shaving and tucking=) Quote Link to comment Share on other sites More sharing options...
Guest 328ci Posted October 22, 2014 Report Share Posted October 22, 2014 shop looks dope Quote Link to comment Share on other sites More sharing options...
GunMetalGrey Posted October 26, 2014 Author Report Share Posted October 26, 2014 Update time, got quite a bit done in the past few days(not really) but I shall post my findings!First off, this....Turns out my wastegate never got tightened to the manifold... not sure if this was me or the guy that did my exhaust, either way I cleaned it up and it will be on tight next time! So time for a bit of backstory. I knew that this car had some sort of drivers side damage in its life, as the front drivers side fender has been replaced (by BMW) and I am finally starting to see the extent of what all happened. The bumper is new, the bumper shock on the D side is new and the sheet metal by the abs is bent from the collision. I was showering and thinking about removing my core support and needing to make new radiator mounts after removing the core support (rad mounts are part of it) and I remembered that the radiator didn't really fit because it didn't fit between the frame horns (part the bumper shock bolts too) and I got to thinking that my whole front frame work is bent. So I went to the shop and measured tims e30 and then mine, sure shit my front driver side frame horn is bent 1/4" in.... So I continue cutting the core support out, spot weld cutters are pretty cool! that is the driver side where the fender meets the frame, the other side is perfectly straight, this one is bentthe spot weld on the front of this had been drilled already and not re welded, other side was perfectlower valance mount on the drivers side, bent. I think you see the trend. Played around with the bent metal near the ABS, this is what I ended up with A bit worse than I thought, and the rust is creeping up to other parts, luckily I can get the super rusted part new for 40 bucks shipped! Rusted through on the other side too. Core support was rusty and bent so I ended up taking it out in a less than gentle manorAnd the end result is pretty cool!Now I wish I had done this sooner! Pulling the engine was so darn easy, super blurry picture of how it comes out.Leaving me with this.I started stripping seam sealer after that, which is kind of a pain! Interesting note, the frame horn moved back over almost a 1/4" after cutting the core support out, so the core support was pretty bent. So, the plans. Replace all rust in the engine bay (going to be a lot of work there), get a new core support and make tabs to bolt it in to the car, and reinforce areas that it will be bolted in to, repaint bay after shaving, stitch weld all seams (seam weld the front) and for now that is all that comes to mind. I think I am ending up a litter deeper in this than I initially thought, but I have to learn some how! Quote Link to comment Share on other sites More sharing options...
GunMetalGrey Posted October 26, 2014 Author Report Share Posted October 26, 2014 As it sits now. Another interesting note, I will be picking up an e36 328 five speed with 140k that got rear ended Prepare for 900hp engine build....Also, if you need parts from it let me know! four door, white exterior tan interior, drive line is spoken for already Quote Link to comment Share on other sites More sharing options...
GunMetalGrey Posted October 26, 2014 Author Report Share Posted October 26, 2014 Alright one more then I am done. I took the flywheel and clutch off and noticed that there was a lot of dust, and saw that the flywheel had one hot spot on the outer edge. I am glad I took the clutch off because it turns out that the flywheel is no longer straight and wasn't touching all of the clutch disc. Will have to get that taken care of ! Quote Link to comment Share on other sites More sharing options...
Earl Posted October 26, 2014 Report Share Posted October 26, 2014 Good hood struts on that car? Progress is awesome Quote Link to comment Share on other sites More sharing options...
suspenceful Posted October 26, 2014 Report Share Posted October 26, 2014 Dope as always. With all the work you're putting into this thing, you might as well hold onto it forever. Buy a 1-series, I'd love to see what you do with it Quote Link to comment Share on other sites More sharing options...
Rowleym Posted October 26, 2014 Report Share Posted October 26, 2014 900hp you say? I have a hookup for a couple borg warner turbos. Both of them are .91 exhaust side t4, and either 2.8" intake or 2.5". They are s4xx turbo's. Thats about all I got on them though haha. My name is on one of the 2.8", which i will be using in my m50 e30, and I will be building the twin scroll exhaust manifold. I actually bought a whole bunch of sch 10 1 1/4 stainless to build a bunch of them. Plan on making a jig. No one produces twin scroll m5x e30 swap manifolds, So i plan to fill that void. Quote Link to comment Share on other sites More sharing options...
Guest 328ci Posted October 29, 2014 Report Share Posted October 29, 2014 Keeps getting better Quote Link to comment Share on other sites More sharing options...
GunMetalGrey Posted November 18, 2014 Author Report Share Posted November 18, 2014 Life is difficult. Decisions are hard. What todo?! Side note, the e36 that I got as a parts car is mint except for the fact it got hit. Playing body shop to see what I can make of it! Haven't done much with the E30 lately, started thinning out the engine bay harness and continuing stripping seam sealer. Put some Bosch projectors in the e46 with a new set of bulbs/ballasts and did the yellow high buckets. Looks good bro. Also yellow fogs. And snow tires. That is all. Quote Link to comment Share on other sites More sharing options...
B C Posted November 19, 2014 Report Share Posted November 19, 2014 Life becomes less difficult when you sell your setup to kaiser for $2500 Pics of e36 or gtfo Quote Link to comment Share on other sites More sharing options...
GunMetalGrey Posted November 20, 2014 Author Report Share Posted November 20, 2014 $2500 is a comical amount. Pics of e36 tomorrow? Quote Link to comment Share on other sites More sharing options...
Jdesign Posted November 20, 2014 Report Share Posted November 20, 2014 I need to wonder around these members build threads more often. Hats off to you sir. I have pulled core supports before and its a fair amount of work getting the new one in. Welding it in straight and lined up proves to be quite the challenge when everything is tweaked a little. Luck for you, you have a car to take measurements of off. Quote Link to comment Share on other sites More sharing options...
GunMetalGrey Posted November 20, 2014 Author Report Share Posted November 20, 2014 It sprung back straight after I cut the core support out. New core support will have a tubular frame built into it and will be bolted in! Quote Link to comment Share on other sites More sharing options...
GunMetalGrey Posted November 24, 2014 Author Report Share Posted November 24, 2014 Things to look at, yellow inner headlights, angel eyes, projectors, yellow fogs. Good upgrades!I like. And pictures of the e36 You may think that I didn't do too much to it, but this is how it was when I got it.That's all for now folks! DrLeadFoot and patsbimmer1 2 Quote Link to comment Share on other sites More sharing options...
patsbimmer1 Posted November 24, 2014 Report Share Posted November 24, 2014 Does the e36 have any rust? I can't tell from the pictures but it looks clean! Even interior doesn't show the usual dirt stains that you get on that tan. Quote Link to comment Share on other sites More sharing options...
GunMetalGrey Posted November 24, 2014 Author Report Share Posted November 24, 2014 There is a small spot of rust on the passenger door right on the bottom edge. It is an 98 328i five speed with 144k miles, first owner had it for 124k miles and has all of the service records in the car and all of the original paperwork. i bought it to use the driveline but it is way too clean to just turn into a pile of parts. Quote Link to comment Share on other sites More sharing options...
YoungCR Posted November 24, 2014 Report Share Posted November 24, 2014 Looks like it'll be a great example when finished Quote Link to comment Share on other sites More sharing options...
GunMetalGrey Posted December 8, 2014 Author Report Share Posted December 8, 2014 StuffThingsWorked on fully deleting the ABS wiring and put the fuse box back together. I like angle grinders lately, and flap discs Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted December 10, 2014 Report Share Posted December 10, 2014 Does the e36 have any rust? I can't tell from the pictures but it looks clean! Even interior doesn't show the usual dirt stains that you get on that tan. You missing your white knight?? Quote Link to comment Share on other sites More sharing options...
patsbimmer1 Posted December 10, 2014 Report Share Posted December 10, 2014 You missing your white knight??I do! I love my 335i but Lola was a different kind of girl! I'll have another e36 one day and make a nice project out of her. Quote Link to comment Share on other sites More sharing options...
GunMetalGrey Posted December 27, 2014 Author Report Share Posted December 27, 2014 This thread needs an update! Not a whole lot going on with the car with the holidays and finals going on, but I did get out there tonight and get a few things done! Cut back more rust :/Got a piece made up to fit in there and started tacking/grinding that smooth. It's going nicely in my opinion!I finally did something that I have been thinking about doing/wanted to do for a while now. I REALLY like the way it turned out!Did all four, and man was that a lot of work! I am oddly excited about how good that will look, and look forward to adding a touch more low.I am happy with progression, and how things have been shaping up as of late, been having more people over to the shop to help, and a few guys that are actually sheet metal fab guys. To say the least they are good with suggestions and pointers for sheet metal work! Quote Link to comment Share on other sites More sharing options...
