B C Posted February 21, 2014 Report Share Posted February 21, 2014 LMT Tomorrow? Tonight? let me know, I will attend and annoy the piss out of everyone. Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted February 21, 2014 Author Report Share Posted February 21, 2014 It might be worth it just to see me get nervous as the dickens. Sent from my SCH-I535 using Tapatalk Quote Link to comment Share on other sites More sharing options...
wasnt m3 Posted February 21, 2014 Report Share Posted February 21, 2014 LMT is busy with World of Wheels this weekend fyi. DrLeadFoot 1 Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted February 26, 2014 Author Report Share Posted February 26, 2014 9:00AM this Friday I'll be on the dyno at Late Model Throttle!! #itbetternotsnowSent from my SCH-I535 using Tapatalk mkoepp and jc43089 2 Quote Link to comment Share on other sites More sharing options...
B C Posted February 26, 2014 Report Share Posted February 26, 2014 videosvideosvideosvideos Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted February 26, 2014 Author Report Share Posted February 26, 2014 I'll get the gopro all set up. Sent from my SCH-I535 using Tapatalk Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted February 28, 2014 Author Report Share Posted February 28, 2014 A very safe and strong 442whp. Not too happy but there is room for improvement and my A/F is consistent across the rpms which was my main goal with this dyno run. It looks like the TRM tune is in the 11-12s and will be safe to crank up the boost. My 1st dyno run I was below 10s due to vacuum leaks so this is a good thing. I'm at 13psi. What do you guys think I should do to up the boost? Spring by spring and inch my way up or get a boost controller? Taking the wastegate out is a pain in the butt.Sent from my SCH-I535 using Tapatalk Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted February 28, 2014 Author Report Share Posted February 28, 2014 442whp run http://www.flickr.com/photos/70254549@N06/12837574875/ 441whp run http://www.flickr.com/photos/70254549@N06/12837662095/ Quote Link to comment Share on other sites More sharing options...
B C Posted February 28, 2014 Report Share Posted February 28, 2014 AFRs are nice and smooth, assuming the dyno doesnt have a crazy smoothing factor in place. Do you have a compressor map for your turbo? otherwise what are the specs and I will try to find one Quote Link to comment Share on other sites More sharing options...
Rowleym Posted February 28, 2014 Report Share Posted February 28, 2014 440whp? Yea I would be a bit disappointed. Use a wastegate spring that's the lowest boost you want and use an electric boost controller on top of that for mad boostages. Aren't you running a 40r? Man I'm not that impressed. Turn up the boost and wake it up! You aren't even getting into the good part This thing is a beast and I can't wait to see it in person! Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted February 28, 2014 Author Report Share Posted February 28, 2014 AFRs are nice and smooth, assuming the dyno doesnt have a crazy smoothing factor in place. Do you have a compressor map for your turbo? otherwise what are the specs and I will try to find oneI have one a couple of pages back. 440whp? Yea I would be a bit disappointed. Use a wastegate spring that's the lowest boost you want and use an electric boost controller on top of that for mad boostages. Aren't you running a 40r? Man I'm not that impressed. Turn up the boost and wake it up! You aren't even getting into the good part This thing is a beast and I can't wait to see it in person!I will turn it up for sure. I might wait until this weather warms up. There are times that I spin in 5th gear with the cold and salt on the road. Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted February 28, 2014 Author Report Share Posted February 28, 2014 I'm not too good with dyno charts yet but aren't the HP and Torque lines supposed to intersect at a consistent spot at a lower rpm? Quote Link to comment Share on other sites More sharing options...
B C Posted February 28, 2014 Report Share Posted February 28, 2014 Interesting..... call them up and ask why they dont intersect at 5252 RPM. EDIT: It looks like the Y-axis on the left and right sides is unequal. If you equated them, it would probably intersect at 5252 DrLeadFoot 1 Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted February 28, 2014 Author Report Share Posted February 28, 2014 I guess the computer auto-scales the graph to make it more "readable". Quote Link to comment Share on other sites More sharing options...
B C Posted February 28, 2014 Report Share Posted February 28, 2014 Just watched the videosGoodness, that thing squats down pretty hard on the rollers there O__OEveryone knows it and has said it, but you have put together a pretty serious machine!also your coat reminded me of this. Thanks for the footage!! DrLeadFoot 1 Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted February 28, 2014 Author Report Share Posted February 28, 2014 It's cold out there, son! Thanks, Snap! Maybe next winter I'll upgrade the fuel system and go megasquirt. I'll be calling you hourly when I cross that bridge. Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted February 28, 2014 Author Report Share Posted February 28, 2014 I'll wrap this day up with a couple of words: From my last dyno run to today I basically got my sparkplugs right, added a full 3in exhaust, fixed a couple vacuum leaks and added CCV. I thought the vacuum leaks would hinder HP more than it did or maybe the exhaust is way more restrictive now than it was coming straight out of the hood. In the end I'm in a good spot with only more to gain. Now who wants to pull out my wastegate for me?? Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted February 28, 2014 Author Report Share Posted February 28, 2014 The face of 442whp Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted February 28, 2014 Report Share Posted February 28, 2014 This thing is sweet as gold shoes! DrLeadFoot 1 Quote Link to comment Share on other sites More sharing options...
Rowleym Posted February 28, 2014 Report Share Posted February 28, 2014 It's cold out there, son! Thanks, Snap! Maybe next winter I'll upgrade the fuel system and go megasquirt. I'll be calling you hourly when I cross that bridge. E85 surge tank setup and megasquirt go go go go!!!!!!! Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted February 28, 2014 Report Share Posted February 28, 2014 It just loaded for me... But in post 443. That second pic of the front of the car. Is too freakin' cool. Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted February 28, 2014 Author Report Share Posted February 28, 2014 I had the good camera out today! Thanks! Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted March 4, 2014 Author Report Share Posted March 4, 2014 List of things I need.-Fuel pressure regulator adapter for a M50. -PLX Devices power plug for the wideband. -Bigger I.D. vacuum line for my wastegate and the fittings to go with it.The vacuum line should raise the boost up but I don't want to do that until I get my wideband working (again). Then I can dial it in with the FPR. I'm also going to have Kummrow fix my oil leak. Messed my arm up and wrenching probably shouldn't be happening. Sent from my SCH-I535 using Tapatalk Quote Link to comment Share on other sites More sharing options...
RamRod E28 Posted March 5, 2014 Report Share Posted March 5, 2014 List of things I need.-Fuel pressure regulator adapter for a M50. -PLX Devices power plug for the wideband. -Bigger I.D. vacuum line for my wastegate and the fittings to go with it.The vacuum line should raise the boost up but I don't want to do that until I get my wideband working (again). Then I can dial it in with the FPR. I'm also going to have Kummrow fix my oil leak. Messed my arm up and wrenching probably shouldn't be happening. Sent from my SCH-I535 using TapatalkWe got ourselves another earl ladies and gents Rowleym 1 Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted March 6, 2014 Author Report Share Posted March 6, 2014 Ordered the PLX power cord. Waiting for I.E. to call me back with a price for the M5X/S5X fuel rail plug and will be ordering that today. Also got this coming http://www.crutchfield.com/p_500HD149BT/Alpine-CDE-HD149BT.html?tp=5684 Let the Alpine BLAST! Quote Link to comment Share on other sites More sharing options...
