The Full Banana Posted April 1, 2015 Report Share Posted April 1, 2015 Looks great--which is impressive seeing as I can't even see the car in those photos! DrLeadFoot 1 Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted April 2, 2015 Author Report Share Posted April 2, 2015 Popped in the new Spark plugs in the e30 gapped to .025Still breaking up same as before. I need to get on the dyno and have TRM flash a new chip ASAP.The old plugs were sketch. I'll get pictures soon.I emailed e30ls1@gmail.com to inquire about this:I need a different diff as the bearings are getting loud in the current 2.79lsd so I'm going through Wanganstyle Global for a new Diff. Here are some of his comments about what I'm going with:Complete blueprinted 4 disc lsd unit with 2.79 final drive + standard Ramps produces max lock of 60%; you honestly don't need more- I'm pretty well known for high power differentials; I have a few locals at 500-700rwhp with street driven cars and 1200rwhp for drag. Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted April 2, 2015 Author Report Share Posted April 2, 2015 Old NGK 8 Plugs gapped to .021 Any input is greatly apprenticed.#1 Leaky injector? This one is almost always wet.#2 Notice the curled sides of the prong thing.#3#4#5#6 Quote Link to comment Share on other sites More sharing options...
GunMetalGrey Posted April 2, 2015 Report Share Posted April 2, 2015 Stock evo 8 diff tabs bolt right to an e30 diff, found that out the other day.No luck finding an e36 cover? Quote Link to comment Share on other sites More sharing options...
B C Posted April 2, 2015 Report Share Posted April 2, 2015 Looks like moving up to heat range 9 wouldnt be a bad idea. It wont help with the breakup, but leaning it out will Inb4 "how dare you tell someone to lean out the top end on a boosted car" Quote Link to comment Share on other sites More sharing options...
Rowleym Posted April 2, 2015 Report Share Posted April 2, 2015 The tough thing about the remote tuning is that they base their tweaks off of a formula which wont necessarily get you where you need to be on the first try, it may take several iterations. I could provide you with the same tweaks they do if I had a way to write to that chip. Thats just saying that theres not a whole lot of voodoo to it. Have you re-calibrated your wideband recently?All you would need is a simple chip burner if they don't have any v Popped in the new Spark plugs in the e30 gapped to .025Still breaking up same as before. I need to get on the dyno and have TRM flash a new chip ASAP.The old plugs were sketch. I'll get pictures soon.I emailed e30ls1@gmail.com to inquire about this:I need a different diff as the bearings are getting loud in the current 2.79lsd so I'm going through Wanganstyle Global for a new Diff. Here are some of his comments about what I'm going with:Complete blueprinted 4 disc lsd unit with 2.79 final drive + standard Ramps produces max lock of 60%; you honestly don't need more- I'm pretty well known for high power differentials; I have a few locals at 500-700rwhp with street driven cars and 1200rwhp for drag.So he recommends standard ramps for drag applications? I'm looking at building the exact same diff. And is he saying the 188mm diff with upgraded clutch discs is going to hold up to 1200rwhp? I thought past 700+ you needed a 210mm?Sorry I'm just trying to build an absolutely bulletproof driveline. Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted April 3, 2015 Author Report Share Posted April 3, 2015 That would be a direct question for him as I know very little about diffs. https://www.facebook.com/globalwanganstyle?fref=ts Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted April 3, 2015 Author Report Share Posted April 3, 2015 I've been emailing back and forth with TRM and they'll take 10% of fuel out of WOT. Hopefully that will tend to the breaking up issue enough to get some quality dyno pulls and go from there. On the wideband it bounces around a little from totally bottomed out Rich to 10.5 when I'm at WOT. It is hard to see what rpm it is doing this at as I'm trying to hold on to this pissed off kraut rocket. Quote Link to comment Share on other sites More sharing options...
B C Posted April 3, 2015 Report Share Posted April 3, 2015 http://www.ms3pro.com/ms3-pro.html andyhundley, KaiserRolls and Bassboy3313 3 Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted April 3, 2015 Author Report Share Posted April 3, 2015 ^Is there a dislike button? Haha Quote Link to comment Share on other sites More sharing options...
B C Posted April 3, 2015 Report Share Posted April 3, 2015 No but ms3 pro has enough spare inputs for you to connect your own dislike button and log it in real-time!!! jc43089, GunMetalGrey, m42b32 and 3 others 6 Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted April 4, 2015 Author Report Share Posted April 4, 2015 Update:-Ordered a 2.79LSD with 4 clutch discs from Wanganstyle should be ready to ship in a little over a week.-Received a central locking unit. Super anxious to install that!! If it works I'm going to flip my lid.-TRM shipped me a new chip with 10% fuel taken out at WOT.-Going to look into my #1 injector to see if it leaking or not spraying a mist.-----Which one has an engine light on??The struggle... patsbimmer1 1 Quote Link to comment Share on other sites More sharing options...
B C Posted April 4, 2015 Report Share Posted April 4, 2015 This is how you start kaisers carAre you still pegging rich? YoungCR and KaiserRolls 2 Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted April 4, 2015 Author Report Share Posted April 4, 2015 I am. Next week the chip should be here Quote Link to comment Share on other sites More sharing options...
ClassE Posted April 4, 2015 Report Share Posted April 4, 2015 Any chance you were in Oshkosh the other day in your M3? If not - your car has a clone up here rolling around... Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted April 6, 2015 Author Report Share Posted April 6, 2015 Any chance you were in Oshkosh the other day in your M3? If not - your car has a clone up here rolling around... Wasn't me. Someone needs to track this guy down! Small update: MY CENTRAL LOCK WORKS!!!!! Drivers, passenger and trunk keys operate the locks and gas cap. Yeehaw!!! Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted April 7, 2015 Author Report Share Posted April 7, 2015 Wangan gave me an update on the diff build. Quote Link to comment Share on other sites More sharing options...
YoungCR Posted April 7, 2015 Report Share Posted April 7, 2015 I've never seen such a beautifully photographed diff mkoepp and KaiserRolls 2 Quote Link to comment Share on other sites More sharing options...
GunMetalGrey Posted April 7, 2015 Report Share Posted April 7, 2015 He photographed it on his engine, in a cool spot. Who does that?! YoungCR, mkoepp and Bassboy3313 3 Quote Link to comment Share on other sites More sharing options...
B C Posted April 7, 2015 Report Share Posted April 7, 2015 He sends those pics to everyone. Jk Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted April 7, 2015 Author Report Share Posted April 7, 2015 I couldn't believe the engine bay shot. Haha Quote Link to comment Share on other sites More sharing options...
patsbimmer1 Posted April 7, 2015 Report Share Posted April 7, 2015 It's a farewell tour for the dif! Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted April 9, 2015 Author Report Share Posted April 9, 2015 The diff is on it's way! Some pics. Quote Link to comment Share on other sites More sharing options...
B C Posted April 9, 2015 Report Share Posted April 9, 2015 PBFT!! YusssWhat % lockup is this? 60?Im interested to hear how it behaves during abrupt throttle lift Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted April 9, 2015 Author Report Share Posted April 9, 2015 Haha. I thought that was great! Yes, 60%. I'll let ya know how it feels. Quote Link to comment Share on other sites More sharing options...
