m42b32 Posted February 28, 2018 Author Report Share Posted February 28, 2018 I did some more research and found that the M54B30 is probably the most likely of any m/s5x to throw the oil pump nut or shear the shaft. It experiences really bad crank harmonics above 6k rpm, likely due to the aluminum block. I figure $200 for the hardened pump shaft is cheap insurance compared to blowing up a motor and ruining all this work I've done. Decided to pull the oil pump apart to inspect it before I order anything. Oil pump nut was 'tight', but didn't take that much force to remove. It definitely took more force to remove the one on my M3 by comparison. The internals don't look bad, but I don't really know what I'm looking at so I figured I'd post some pictures and get your opinions: There was some minor scoring on the bore and the outside of the outer rotor. I can barely feel it when running my fingernail over it on both parts. There is some discoloration/wear where in places on the inner rotor, but it isn't rough to the touch or anything like that. Not much scoring on the inside of the cover or back of the housing. Are these in usable condition or should I replace them with new ones? Another note, when I pulled them apart I noticed dimples stamped into each rotor. Are these supposed to line up for assembly or do they not really matter as long as it spins smoothly? The outer rotor had the dimple facing the cover, while the inner had it on the inside. Didn't seem to be any correlation between the two. Quote Link to comment Share on other sites More sharing options...
B C Posted February 28, 2018 Report Share Posted February 28, 2018 the dimples didnt seem to have any sort of reasoning when I was dealing with mine. The rotor and that outer rotor piece are both readily available individually. I bought a new outer piece because it had a little bit of grooving, but most of all I replaced it because it had a notch in it m42b32 1 Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted February 28, 2018 Report Share Posted February 28, 2018 Run it m42b32 1 Quote Link to comment Share on other sites More sharing options...
straight6pwr Posted February 28, 2018 Report Share Posted February 28, 2018 upon scanning your photo with an electron microscope, i've found they've used steel with too much carbon content. better replace it. read: this seems nit picky. B C, Jdesign and m42b32 3 Quote Link to comment Share on other sites More sharing options...
jc43089 Posted February 28, 2018 Report Share Posted February 28, 2018 Most important thing to check is end clearance right? That is usually the spec listed in service manuals. Check it with plastigage I would think. m42b32 1 Quote Link to comment Share on other sites More sharing options...
m42b32 Posted February 28, 2018 Author Report Share Posted February 28, 2018 I google'd the sh!t out of it and there really wasn't much information on what is considered good and junk, thanks for the feedback! I'll be installing an oil pressure gauge to keep an eye on things anyway, so I'm just going to put these back in along with an Achilles pump shaft and call it good to go. Quote Link to comment Share on other sites More sharing options...
Daggerty Posted March 1, 2018 Report Share Posted March 1, 2018 m42b32 1 Quote Link to comment Share on other sites More sharing options...
m42b32 Posted March 1, 2018 Author Report Share Posted March 1, 2018 Stopped by the garage again last night and got a few more things done. Modified the windage tray and got it bolted back onto the block. All that needed to be done was cut off the rear mount for the pickup tube. Some sources online stated that you need to add a stud to mount the 728i front sump pickup tube, but that is not the case on mine. There is a threaded feature on the oil pump body itself that lines up perfectly! The stud must be needed on the early m54 or m52tu that uses a slightly different pump, but I'm not sure. I also cleaned up the power steering pump, alternator, and belt tensioner/pulleys. The alternator took a bath in ATF during the donor car's accident, so I flushed out the body with a bit of brake cleaner. I also disassembled it as far as it would go and cleaned the regulator and it's contacts, as well as all the electrical connections under the cover. The part of the rear cover that connects to the duct was broken off and isn't repairable, so I trimmed the plastic back so that it would look a little nicer until I can find a replacement cover. It is the typical Bosch 120A unit that is used on a lot of different cars, so once the engine is in and running, I'd like to find a back cover that allows me to cleanly attach a duct setup that fits the e30 chassis. Got the alternator and accessory belt parts bolted back onto the engine, but I left off the power steering pump off till I have the oil pan sealed up. Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted March 1, 2018 Report Share Posted March 1, 2018 I had to cut that entire cover off my alternator to make room for things. We’ll see how long it takes to cook one Quote Link to comment Share on other sites More sharing options...
m42b32 Posted March 5, 2018 Author Report Share Posted March 5, 2018 Started working on cleaning up the e39 530i engine wire harnesses. Everything is sleeved in the ribbed plastic tubing and it has worn through or cracked in a lot of places so I am redoing the entire harness in this braided harness wrap. Looks much nicer, but it is super tedious. Just waiting on the vanos oil feed line and the oil pump parts and I should be able to seal it up and start wiring. Quote Link to comment Share on other sites More sharing options...
Earl Posted March 5, 2018 Report Share Posted March 5, 2018 Are you using split loom or are you depinning all of the connectors and sliding in normal loom? Quote Link to comment Share on other sites More sharing options...
m42b32 Posted March 5, 2018 Author Report Share Posted March 5, 2018 6 hours ago, Earl said: Are you using split loom or are you depinning all of the connectors and sliding in normal loom? Split loom, I got the amazon link from KaiserRolls' thread, I'm pretty pleased with it so far. KaiserRolls and Earl 2 Quote Link to comment Share on other sites More sharing options...
B C Posted March 5, 2018 Report Share Posted March 5, 2018 They also have it at Pegasus Racing if you don't mind waiting a half hour while they ring up the 2 customers ahead of you. Jdesign and m42b32 2 Quote Link to comment Share on other sites More sharing options...
Jdesign Posted March 5, 2018 Report Share Posted March 5, 2018 2 hours ago, m42b32 said: Split loom, I got the amazon link from KaiserRolls' thread, I'm pretty pleased with it so far. I didn't realize they made that stuff in split loom! Quote Link to comment Share on other sites More sharing options...
m42b32 Posted March 12, 2018 Author Report Share Posted March 12, 2018 Moving along slowly, but progress is progress. Installed a new VANOS oil feed line, bolted the front sump oil pickup tube to the pump, and started working on fitting the e46 oil level sensor to the e34 oil pan. I scraped the old seal out and replaced it with a new o-ring, but it turns out the studs on the pan are too short so I'll have to replace them with longer ones. Cleaned up and painted a few more brackets as well, but didn't get any pictures. I also got the m42 ready to pull. Everything is drained and disconnected, motor mounts unbolted, only thing left is to unbolt the trans mounts and hoist it out. Hoping to get it out by mid-week so I can start on the ABS delete/booster swap/etc. jc43089, Jdesign, P_Roloff and 1 other 4 Quote Link to comment Share on other sites More sharing options...
B C Posted March 12, 2018 Report Share Posted March 12, 2018 Why cant the E34 level sensor be used?What booster are you going to use? Quote Link to comment Share on other sites More sharing options...
m42b32 Posted March 12, 2018 Author Report Share Posted March 12, 2018 6 hours ago, snap said: Why cant the E34 level sensor be used? What booster are you going to use? The plug on the e46 harness is different than the e34, and since I don't have a pigtail for the e34 sensor my initial plan was to delete it with a delete plate. Once I found that the e46 sensor is a direct bolt in to the e34 pan with longer studs I figured why not. I compared the two, and the oil level measuring points are pretty similar so it should be somewhat accurate. Initially, it won't have any functionality as the signal comes from the ECU and is communicated through CAN bus (that and I don't have a check panel), but there is a module than can convert the CAN signals to usable outputs. I'm pretty much just setting myself up for future projects. For the booster I'll be using one from an e21 that I got from DrLeadFoot Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted March 12, 2018 Report Share Posted March 12, 2018 I use an old school device called a “dipstick” to check my oil level. All I get out of the deal is a light that’s always glowing on the check panel m42b32 and Jdesign 2 Quote Link to comment Share on other sites More sharing options...
m42b32 Posted March 16, 2018 Author Report Share Posted March 16, 2018 Got some things done this week. I swapped the oil pump inner rotor over to the Achilles harneded oil pump shaft, just waiting on a new pressure relief spring and o-ring and I can get the oil pump buttoned up. Ebay had a sale so I picked up some VDO vision gauges to keep a closer eye on the new engine. Oil temp, oil pressure, and water temp gauges. I've had a console mounting plate sitting around for a while so I did a quick mock-up, should look fairly factory! I may color the cluster needles orange to make everything match, but that'll be a project for some other time. Biggest progress is the m42 is now sitting on the floor of my garage. So much room for activities! Boris3, P_Roloff and Earl 3 Quote Link to comment Share on other sites More sharing options...
B C Posted March 16, 2018 Report Share Posted March 16, 2018 What else needs to be done on the engine/trans to be ready to install it? What trans are you using anyhow? Keep up the great work! Perhaps you will find more deer blood at this level of disassembly Quote Link to comment Share on other sites More sharing options...
m42b32 Posted March 16, 2018 Author Report Share Posted March 16, 2018 4 minutes ago, snap said: What else needs to be done on the engine/trans to be ready to install it? What trans are you using anyhow? Keep up the great work! Perhaps you will find more deer blood at this level of disassembly I have definitely found some hair, there was A LOT so I'll probably keep finding it forever... hoping to keep the fluids at a minimum haha. Trans is a ZF 5-speed. Things I can think of remaining on the engine before I install it: - Rear main seal - Reassemble and prime oil pump - Acquire/Install oil pan baffle (debating this one still) - Reinstall oil pan - Reinstall P/S pump and serpentine belt - Modify oil filter housing (just filing down a rib) and install oil distribution block for pressure/temp gauge senders - Clean and paint harmonic balancer, its a little crusty - Modify driver's side engine mount arm so I can get the 4th bolt in (or get a later arm with the slotted hole that works) - Install main/secondary engine harness (Remove auto-trans wiring from secondary harness) - Clean up starter - Clean trans (it's filthy) and replace shift shaft seal/selector rod joint - Replace shift detent pins - Resurface flywheel and pressure plate - Probably a million other things Probably going to have to re-adjust my picnic goal as I'll be out of town for at least 2 weekends between now and then, but I'd rather do that than cut corners to get it done. It'll be on the road this summer for sure! Jdesign, P_Roloff and Bassboy3313 3 Quote Link to comment Share on other sites More sharing options...
Earl Posted March 16, 2018 Report Share Posted March 16, 2018 I know the feeling with still finding deer hairs haha Super stoked on the progress you're making with this though=) m42b32 1 Quote Link to comment Share on other sites More sharing options...
Bassboy3313 Posted March 16, 2018 Report Share Posted March 16, 2018 3 hours ago, m42b32 said: Probably going to have to re-adjust my picnic goal as I'll be out of town for at least 2 weekends between now and then, but I'd rather do that than cut corners to get it done. It'll be on the road this summer for sure! My thoughts exactly. I hate rushing things and having to revisit them later. Do it right the first time I always say. m42b32 1 Quote Link to comment Share on other sites More sharing options...
m42b32 Posted March 16, 2018 Author Report Share Posted March 16, 2018 40 minutes ago, Bassboy3313 said: My thoughts exactly. I hate rushing things and having to revisit them later. Do it right the first time I always say. Agreed. I did a bit of rushing on some things last winter since I was hell bent on making it there, but now I'd like to take the time to fix those things and do it all right. Like last year I wired the electronic fan to be on with the ignition all the time as a quick 'get it done', which was annoying all summer, so now I'm going to re-wire it to a temp switch with a manual override like I should've in the first place. Quote Link to comment Share on other sites More sharing options...
B C Posted March 16, 2018 Report Share Posted March 16, 2018 interested in seeing how your manual override works. My plan is just to not overheat. m42b32 1 Quote Link to comment Share on other sites More sharing options...
