CMart Posted December 17, 2014 Report Share Posted December 17, 2014 I love this build. Can't wait to get mine running and check out your tail lights. Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted December 17, 2014 Author Report Share Posted December 17, 2014 I love this build. Can't wait to get mine running and check out your tail lights. Thanks! Waiting on you!! Let's run 'em. Quote Link to comment Share on other sites More sharing options...
CMart Posted December 17, 2014 Report Share Posted December 17, 2014 My old timeline was wait until spring then start the build again, but I've actually been making good progress in the cold. New goal is to have everything buttoned up by spring and get it on the road as soon as the salt is gone. I've been spending too much time parting the E39, but once its gone I will be able to work on the E30 much more efficiently with the extra room. Thanks!Waiting on you!! Let's run 'em. DrLeadFoot 1 Quote Link to comment Share on other sites More sharing options...
CMart Posted December 17, 2014 Report Share Posted December 17, 2014 Also what are you putting down? Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted December 17, 2014 Author Report Share Posted December 17, 2014 Also what are you putting down? Last time I dyno'd it it was 442whp at 13psi. I'm now at 18psi with a slipping clutch... I just want to break the 500whp mark. I also have to pop in a new t3 turbo gasket. Mine currently is venting to atmosphere. Quote Link to comment Share on other sites More sharing options...
CMart Posted December 17, 2014 Report Share Posted December 17, 2014 Definitely viewing tail lights. B C 1 Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted December 31, 2014 Author Report Share Posted December 31, 2014 Got around to doing a little work on the car while in my basement. Popped of the foamy thing. It was all oil mush. Gently pry a bit. Off she comes! New vs. Old Oiled up the gasket, took a 15mm socket and tapped it home. After cleaning up the tar-ish residue on the rod popped on the new foamy thing on with the dowel held in by the snap ring. Waiting for more small parts from pelican. They're getting a call tomorrow... Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted January 12, 2015 Author Report Share Posted January 12, 2015 Meanwhile while still waiting for parts from pelican this happened. Condor Speed Shop's 2015 calendar! B C and patsbimmer1 2 Quote Link to comment Share on other sites More sharing options...
Earl Posted January 12, 2015 Report Share Posted January 12, 2015 Congrats=) DrLeadFoot 1 Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted January 21, 2015 Author Report Share Posted January 21, 2015 Stopped out by Dan THE Exhaust Man's place. The wing is in the works!! Dominic540, Bassboy3313, Rowleym and 1 other 4 Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted January 22, 2015 Author Report Share Posted January 22, 2015 Got the driveshaft and trans out. Now let's go Marquette Warriors!!! Quote Link to comment Share on other sites More sharing options...
B C Posted January 22, 2015 Report Share Posted January 22, 2015 What are you selling the g260 for? I read that as Now let's go Megasquirt!!! Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted January 22, 2015 Author Report Share Posted January 22, 2015 What are you selling the g260 for? I read that as Now let's go Megasquirt!!! $175 with the short shifter and linkage. Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted January 22, 2015 Author Report Share Posted January 22, 2015 Got the clutch and flywheel out. Gotta love zipties! A little slipping going on there. The pressure plate is a Sachs, clutch is a Southbend stage 4 and JB racing flywheel. Couldn't handle around 400ft/lbs. Quote Link to comment Share on other sites More sharing options...
Rowleym Posted January 22, 2015 Report Share Posted January 22, 2015 stock pressure plate or 618 Pp? Just the southbend stage 4 disc? Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted January 22, 2015 Author Report Share Posted January 22, 2015 Not sure. Bought the whole thing off of a guy on bimmerforums. I think it's just the disc. Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted January 23, 2015 Author Report Share Posted January 23, 2015 What are you selling the g260 for? I read that as Now let's go Megasquirt!!! $75 just for the trans. Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted January 29, 2015 Author Report Share Posted January 29, 2015 Finally! Trans time. Quote Link to comment Share on other sites More sharing options...
B C Posted January 29, 2015 Report Share Posted January 29, 2015 Had to wait on your Duck + VW Beetle sticker, eh? Quote Link to comment Share on other sites More sharing options...
Earl Posted January 29, 2015 Report Share Posted January 29, 2015 I'll be joining in the same escapade shortly=) Quote Link to comment Share on other sites More sharing options...
YoungCR Posted January 29, 2015 Report Share Posted January 29, 2015 I'll be joining in the same escapade shortly=)As will I! Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted January 29, 2015 Author Report Share Posted January 29, 2015 We're in this together, guys!! Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted January 31, 2015 Author Report Share Posted January 31, 2015 Shift pin time. Love the ice pick. Slide hammer the caps out. Ready to pull out the pins. I used a J-hook screw to extract them out. (The thicker screw hook to hang flower pots or decorations. Not pictured.) Once the pins are out drive in the Teflon collar with the correct punch. Make sure the gap in the collar points out to the right or left of the trans. All at home. Drop some gear oil in the hole and install the pins and springs. Drive the caps home with the correct punch. All done! Quote Link to comment Share on other sites More sharing options...
jc43089 Posted February 1, 2015 Report Share Posted February 1, 2015 This is a zf trans? What is the issue that you need to do this? Sent from my potato phone Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted February 1, 2015 Author Report Share Posted February 1, 2015 This is a zf trans? What is the issue that you need to do this? Sent from my potato phone Just doing some preventive maintenance before I pop it in. Got to do the reverse and 5th gear maintenance too. Quote Link to comment Share on other sites More sharing options...
