DrLeadFoot Posted September 14, 2013 Author Report Share Posted September 14, 2013 those rear tires on the tube-frame car are absurd! Did you cut out any of the rear 1/4 panel for the flare fitment? I may be doing this as well I cut, pop riveted and glued them. Then sprayed rubberized coating all over. Sent from my SCH-I535 using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
E36M3#215 Posted September 14, 2013 Report Share Posted September 14, 2013 Looking good, can't wait to see this roll up to the shop instead of the e46 lol Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted September 14, 2013 Author Report Share Posted September 14, 2013 Looking good, can't wait to see this roll up to the shop instead of the e46 lol Soon! After I get back from Denver it should be done in a couple of days. Meanwhile, while I'm drive back from Boulder I see these bro braaahs. Got the bimmer thoughts boiling! #mpower? Sent from my SCH-I535 using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted September 14, 2013 Author Report Share Posted September 14, 2013 Sent from my SCH-I535 using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted September 15, 2013 Report Share Posted September 15, 2013 holy balls. one, semi-massive update. I like it, nice work Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted September 15, 2013 Author Report Share Posted September 15, 2013 holy balls. one, semi-massive update. I like it, nice work Thanks! I've been trying to do some work! Can't wait to have this buttoned up. The winter clock is ticking. Sent from my SCH-I535 using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted September 15, 2013 Author Report Share Posted September 15, 2013 Custom ground wires. Sent from my SCH-I535 using Tapatalk 2 colorowley 1 Quote Link to comment Share on other sites More sharing options...
Earl Posted September 15, 2013 Report Share Posted September 15, 2013 Did you make those handles? I have seen a set like that before and theyre pretty rad. Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted September 15, 2013 Author Report Share Posted September 15, 2013 @earl Condorspeedshop made them. The would be easy to make with a drill press. Sent from my SCH-I535 using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted September 22, 2013 Author Report Share Posted September 22, 2013 Intake manifold on!Sent from my SCH-I535 using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted September 22, 2013 Author Report Share Posted September 22, 2013 Sent from my SCH-I535 using Tapatalk 2 colorowley and StewCrew 2 Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted September 23, 2013 Author Report Share Posted September 23, 2013 I have done some more work after this pic. Passenger side intercooler/pre-turbo piping tightened down. The driver side piping is cut and ready to be clamped down. First I need to get some vacuum lines/hardware in order before that is finished as well as some cutting to the body(Should be done tomorrow).The vac/boost, AF ratio and oil pressure gauges need to be wired up. They're all are mounted. Should take 2 hours max...>_>Tomorrow my daily travels will take me to Concours for some coolant and an o-ring for the oil level sensor. Water wetter is waiting!Bleed the brakes and slave. I need to find an e30 driveshaft with good u-joints. My rear joint is junk. Friday I might order a one piece aluminum shaft. Other than that the suspension is ready. Also, solid transmission mounts are in my head. My 3in stainless steal stock is in my exhaust guy's possession. $500 labor for the full exhaust! I'll see how long I can take the shorty exhaust coming out of the hood before I drive it out to dude's shop for the full thing.As for boost, I'm running my smallest spring, 2.9psi, while I break in my motor for 1000 miles. I'll try not to see any boost during that time.CCV will be ran off of the soon to be 3/4in NPT fitting on the valve cover->catch can-> exhaust to pull vacuum. Maybe start it tomorrow night?? #shootingforthemoonTic toc. Sent from my SCH-I535 using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
m42b32 Posted September 23, 2013 Report Share Posted September 23, 2013 Holy crap that exhaust is going to be nuts, awesome build by the way Quote Link to comment Share on other sites More sharing options...
Bassboy3313 Posted September 23, 2013 Report Share Posted September 23, 2013 This thing is just frightening!!! But sooooo sweet! Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted September 23, 2013 Author Report Share Posted September 23, 2013 Holy crap that exhaust is going to be nuts, awesome build by the wayThanks!! I hope it works! This thing is just frightening!!! But sooooo sweet!The monster should awaken tomorrow if all goes to plan.Sent from my SCH-I535 using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted September 23, 2013 Report Share Posted September 23, 2013 that exhaust!!! Quote Link to comment Share on other sites More sharing options...
GunMetalGrey Posted September 24, 2013 Report Share Posted September 24, 2013 You can break in on boost no problem, most people prefer to do so because it will seat things with the pressures that they will be seeing most of their life. All of this stuff is personal preference though. I will be breaking in on 7lbs because my clutch needs a 500 mile break-in, after that she will see the full 16lbs. And the lead foot Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted September 26, 2013 Author Report Share Posted September 26, 2013 You can break in on boost no problem, most people prefer to do so because it will seat things with the pressures that they will be seeing most of their life. All of this stuff is personal preference though. I will be breaking in on 7lbs because my clutch needs a 500 mile break-in, after that she will see the full 16lbs. And the lead foot I'm going to run boost on the break in too. I tried to go super easy on it but I know I will want to feel the powa so I'm glad you justified my lead foot syndrome. Sent from my SCH-I535 using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted September 26, 2013 Author Report Share Posted September 26, 2013 This is the most current look of the chariot. Sent from my SCH-I535 using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
B C Posted September 26, 2013 Report Share Posted September 26, 2013 Dat up-pipe doe. Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted September 26, 2013 Report Share Posted September 26, 2013 Wonder if you could crack the windshield with hard backfires. would be awesome Bassboy3313 1 Quote Link to comment Share on other sites More sharing options...
Bassboy3313 Posted September 26, 2013 Report Share Posted September 26, 2013 Wonder if you could crack the windshield with hard backfires. would be awesome +1 on that one!! Quote Link to comment Share on other sites More sharing options...
YoungCR Posted September 26, 2013 Report Share Posted September 26, 2013 I've seen this beast in person! Doesn't sound terrible either DrLeadFoot 1 Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted September 27, 2013 Author Report Share Posted September 27, 2013 I've seen this beast in person! Doesn't sound terrible either Noise wise it is bearable. The fumes however are a different story. I'll just chalk it up under the hotrodding lifestyle. This afternoon I'm going to put some serious miles on if my little oil leak is taken care of. I think I have it nailed down. I tightened some slightly loose 10mm bolts on the vanos cover. One might be stripped and not from me tighting... The PO did some weird things so this didn't surprise me. Anyways, we will see how the garage floor looks!It sees boost to 5psi. I got on it last night on an on ramp. She got scary in 2nd 7/8 down to the floor @ 3800rpm. I let off at 4500 and just started laughing! I'm trying to ease this thing in!Sent from my SCH-I535 using Tapatalk 2 B C 1 Quote Link to comment Share on other sites More sharing options...
B C Posted September 27, 2013 Report Share Posted September 27, 2013 dont die, cant wait to see some video of this. Also cant wait to join you in the absurd world of forced induction next spring. DrLeadFoot and YoungCR 2 Quote Link to comment Share on other sites More sharing options...
