Jump to content
I did a practice tap on my old valve cover and it turned out to be pretty easy and not nerve racking. I was nervous about how much metal would be left after the tapping but I think we'll be good!
I also scuffed up my rain rails to prep them for painting.
This is what Rat has been up to. Installing a $5000 inverter from a yacht into the barn that he got for free.
Link to comment
Share on other sites
Update:  Tuesday the e30 will go on jack-stands as soon as I get the new passenger caliper and rear brakes on the M3.
E30 to do list:
-I think I have sourced a drive-shaft that I will install.
-My PLX wideband brain just arrived back from warranty work.  Throwing that in.
-Oil pressure sensor back light and signal wire.
-CCV
    -Pull valve cover
    -Tap
    -Die grind port for more flow.
-Change trans fluid
-Top off diff fluid and RTV seal speed sensor.
-RTV seal ICV connector and brace hoses underneath intake manifold somehow.
-Replace Wilwood rotors and front pads.
-Bleed front brakes.
-Move BOV to brake booster vacuum.  Going to T into that.
-Install fuel pressure regulator.
And that's it!!
Link to comment
?? Kummrow put the head/timing belt on.
 s52 doesnt have a timing belt. haha. No i heard they put the motor together like block, crank, rods, pistons. etc. or did you have the machine shop do all that?
Chain! Haha
I had the machine shop do all that.
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Create New...
Important Information
