P_Roloff Posted March 31, 2018 Author Report Share Posted March 31, 2018 Just now, snap said: List everything you have checked/replaced And which parts are Uro parts Alright, here goes: - o2 sensor replaced - All tune-up parts replaced (cap, rotor, wires) - It’s been smoke tested twice, the first time I found that the blind plugs were leaking and the second time I found that the valve cover had a slight leak along with a disconnected charcoal canister line - ICV has been cleaned and checked, it is as far as I know functional, it buzzes when the key is turned and moves relatively freely. - No Uro parts lol So that’s where I’m at. I’m getting a low idle issue, it sputters and almost dies when returning to idle, hesitated just off idle, but pulls hard and strong everywhere else. Quote Link to comment Share on other sites More sharing options...
P_Roloff Posted March 31, 2018 Author Report Share Posted March 31, 2018 I also just did the stomp test, there are no codes (it flashed 1444 back at me). Oddly enough, it started and idled nearly perfectly today. Before I started it I just pushed the throttle to full, then back to idle with the car off a couple times to see if I could hear or feel the contacts in the TPS. So that’s probably the next plan of attack, making sure the TPS is good and in adjustment. Quote Link to comment Share on other sites More sharing options...
B C Posted March 31, 2018 Report Share Posted March 31, 2018 Ive had an M20 TPS with an intermittent bad contact before. It would pass the continuity test 7 out of 10 times.You should also get a mark D chip, some rebuilt 19# Design III Injectors and some headers while you are trying to fix your idle.It wont help the idle but it will be fun Quote Link to comment Share on other sites More sharing options...
P_Roloff Posted March 31, 2018 Author Report Share Posted March 31, 2018 5 hours ago, snap said: Ive had an M20 TPS with an intermittent bad contact before. It would pass the continuity test 7 out of 10 times. You should also get a mark D chip, some rebuilt 19# Design III Injectors and some headers while you are trying to fix your idle. It wont help the idle but it will be fun Yeah, I’m debating whether I should just spring for a new one or try to clean and adjust the one that’s on there. Chip, headers and injectors would be nice, I really should make sure the injectors are good anyways. The only thing with headers though is that most of them won’t fit an automatic for some reason. I think front suspension and maybe a z3 rack are gonna come before any of that though. Quote Link to comment Share on other sites More sharing options...
YoungCR Posted April 1, 2018 Report Share Posted April 1, 2018 4 hours ago, P_Roloff said: The only thing with headers though is that most of them won’t fit an automatic for some reason. There’s one way to fix that problem Quote Link to comment Share on other sites More sharing options...
P_Roloff Posted April 1, 2018 Author Report Share Posted April 1, 2018 1 hour ago, YoungCR said: There’s one way to fix that problem 😂 yeah but it’s not a cheap one on a college budget. I’d rather drive it as much as I can in the summer than wrench on it. It’s on the list. Quote Link to comment Share on other sites More sharing options...
P_Roloff Posted April 7, 2018 Author Report Share Posted April 7, 2018 Mini-kinda-sorta-maybe-update: I feel like if it snows again, I’m gonna catch the ban hammer from @snap, but oh well. I think this is the first time I’ve ever driven the car with snow on the ground. Salt be damned I guess. I’ve also put nearly 300 miles on in three days of driving, so that’s something. Sadly, tomorrow is probably going to be the last day it gets exercised until late may, gotta finish up the rest of the school year. B C and m42b32 2 Quote Link to comment Share on other sites More sharing options...
YoungCR Posted April 7, 2018 Report Share Posted April 7, 2018 More motivation to get through the semester! P_Roloff 1 Quote Link to comment Share on other sites More sharing options...
Bassboy3313 Posted April 9, 2018 Report Share Posted April 9, 2018 On 4/6/2018 at 9:15 PM, P_Roloff said: I feel like if it snows again, I’m gonna catch the ban hammer from @snap, but oh well. It snowed again... B C, m42b32 and P_Roloff 3 Quote Link to comment Share on other sites More sharing options...
straight6pwr Posted April 9, 2018 Report Share Posted April 9, 2018 Brian...if you ban him...he will win. B C 1 Quote Link to comment Share on other sites More sharing options...
P_Roloff Posted April 9, 2018 Author Report Share Posted April 9, 2018 2 hours ago, Bassboy3313 said: It snowed again... I think I'm gonna keep my presence here to a minimum for a week or so haha. Quote Link to comment Share on other sites More sharing options...
B C Posted April 9, 2018 Report Share Posted April 9, 2018 Not necessary, just wear your new member title with remorse m42b32, jc43089, P_Roloff and 1 other 1 3 Quote Link to comment Share on other sites More sharing options...
P_Roloff Posted June 14, 2018 Author Report Share Posted June 14, 2018 Another small update: Finally got the cruise control working, the speed sensor wire was just disconnected from the cluster. I also put a newer, nicer motor module thing in that I picked up from @Jdesign awhile back. Thanks again! Got a new battery as well a few days ago, the old one was junk after only 4 years but they still gave me some money for the warranty so I’m not too upset. Otherwise, I’ve just been enjoying driving it. According to the OBC, I’m averaging around 20mpg too, which is the best of the 5 cars my family has at the moment. Next on the list is repairing the leak at the filler neck of the fuel tank, doing another smoke test to check for any more vacuum leaks, maybe trying to tackle repairing the rear seat, and disassembling/cleaning/greasing/repairing the front seats. I also rolled over 193k! Quote Link to comment Share on other sites More sharing options...
HipMF Posted June 15, 2018 Report Share Posted June 15, 2018 Congrats on actually trying, let alone succeeding. The cruise in my TI hasn't worked since I bought it. Troubleshooting has been limited to....um.... yeah, kinda never really did anything about it, despite the fact that I drive 100 miles each way to the shop and back most weekends.... P_Roloff 1 Quote Link to comment Share on other sites More sharing options...
P_Roloff Posted June 15, 2018 Author Report Share Posted June 15, 2018 39 minutes ago, HipMF said: Congrats on actually trying, let alone succeeding. The cruise in my TI hasn't worked since I bought it. Troubleshooting has been limited to....um.... yeah, kinda never really did anything about it, despite the fact that I drive 100 miles each way to the shop and back most weekends.... I feel that. It hasn’t worked for over 10 years in this car, I guess I was the first one to care enough about it to try haha. If you even get around to it, I think I have an e36 control stalk laying around if that turns out to be the issue. Quote Link to comment Share on other sites More sharing options...
P_Roloff Posted June 20, 2018 Author Report Share Posted June 20, 2018 Another small update. The faded and worn rockers have bugged me for as long as I can remember, so I finally decided to tackle refinishing them. I did a bit of research on what to use, and finally decided to just use SEM trim black over something like bedliner or a rubberized undercoating. I wasn’t really sure what lengths I should go to for prep work (i.e. whether I need an adhesion promoter, primer, or something else) so I just scuffed with 400 grit per the can instructions and went over it quite a few times with a degreaser. I guess we’ll see how well it holds up. In case anyone was wondering, the black spots above the rockers are POR-15 that was used around 5 years ago when the trim strips were pulled off and rust was found underneath. I just wire wheeled the rust off and coated it, it’s covered by the trim so I figured it didn’t matter much. It does look gross with the trim off though, I’ll take some pics tomorrow with the trim reinstalled. Pics: Quote Link to comment Share on other sites More sharing options...
Jdesign Posted June 20, 2018 Report Share Posted June 20, 2018 We use that paint all the time on prototypes at my work. Its really nice stuff. P_Roloff 1 Quote Link to comment Share on other sites More sharing options...
P_Roloff Posted June 21, 2018 Author Report Share Posted June 21, 2018 4 hours ago, Jdesign said: We use that paint all the time on prototypes at my work. Its really nice stuff. Yeah, I really liked it. What I liked even more is that the auto body supply shop off Fish Hatchery Rd. that I bought this stuff from has a whole rack of different SEM paints, and they’re cheaper than on Amazon or anywhere else I could find. Quote Link to comment Share on other sites More sharing options...
Jdesign Posted June 21, 2018 Report Share Posted June 21, 2018 11 hours ago, P_Roloff said: Yeah, I really liked it. What I liked even more is that the auto body supply shop off Fish Hatchery Rd. that I bought this stuff from has a whole rack of different SEM paints, and they’re cheaper than on Amazon or anywhere else I could find. That's where we get it. They delivery to us weekly. Quote Link to comment Share on other sites More sharing options...
cpandrewschmidt Posted June 21, 2018 Report Share Posted June 21, 2018 which body shop has that paint? Which one is best match for BMW? Quote Link to comment Share on other sites More sharing options...
P_Roloff Posted June 21, 2018 Author Report Share Posted June 21, 2018 Body shop supply on greenway crossing, the SEM trim black matches the black trim and stuff on our cars almost exactly. cpandrewschmidt 1 Quote Link to comment Share on other sites More sharing options...
straight6pwr Posted June 21, 2018 Report Share Posted June 21, 2018 and don't forget its really good quality - it sprays nice, covers evenly and is very durable. i've sprayed basically every trim piece of my e30 with this stuff with great success. Jdesign 1 Quote Link to comment Share on other sites More sharing options...
P_Roloff Posted June 21, 2018 Author Report Share Posted June 21, 2018 3 hours ago, straight6pwr said: and don't forget its really good quality - it sprays nice, covers evenly and is very durable. i've sprayed basically every trim piece of my e30 with this stuff with great success. I see you have the headlight trim rings there-do you like the look painted black? I’m on the fence on whether to keep the silver or go black. Quote Link to comment Share on other sites More sharing options...
straight6pwr Posted June 21, 2018 Report Share Posted June 21, 2018 33 minutes ago, P_Roloff said: I see you have the headlight trim rings there-do you like the look painted black? I’m on the fence on whether to keep the silver or go black. all my headlights are smoked, so it's necessary. for regular headlights, both work nice. it seems unnecessary to buy silver paint since you have the black already. P_Roloff 1 Quote Link to comment Share on other sites More sharing options...
YoungCR Posted June 23, 2018 Report Share Posted June 23, 2018 +1 for Body Shop Supply! They have a store in Madison and Janesville. Quote Link to comment Share on other sites More sharing options...
