KaiserRolls Posted April 23, 2018 Report Share Posted April 23, 2018 I went with a kit from gripforce. The kit includes a lightweight billet aluminum flywheel (10.6 lbs I believe) and a stage 2 sprung hub clutch disk and pressure plate rated for 342 ft/lbs of torque.If it comes with a pilot bearing and throw out bearing, toss them in the trash and never look at them again - go OEM for those parts Good time to replace the pivot pin on the clutch fork as well AsparagusMike 1 Quote Link to comment Share on other sites More sharing options...
AsparagusMike Posted May 2, 2018 Author Report Share Posted May 2, 2018 Update... Did a few little things while waiting for parts to show up. Swapped out connectors on the engine harness. After ciphering through a good amount of shitty pin out charts I located one from mega-squirt that literately couldn't have been more helpful. link below for others: http://www.megasquirt.325ix.com/MS_to_Motronic/C101 to X20.html Used a c101 connector off I snatched off an e30 at Gibson's salvage yard. Only wire I had a little confusion but I think I got right was pin #20 abs relay wire. After some digging I found the popular choice was to wire it back on to pin# 6 which is a switched power wire on a 15 amp fuse. Only extra wires I did not hook up was pin # 2, #10, and #16. 2 and 10 are oil level sensors for the m20 and don't even exist on the 318is c101 connector and #16 is airbag related which of course will be unneeded as I removed the entire airbag system in the car. As for all the wires I did not hookup on both sides, I shrink rapped the ends of each one to avoid any hot wires short circuiting with each other. Once the connector was complete I started cleaning up the harness and wrapping split loom around everything. Haven't finished the harness yet as I need to pickup some better electrical tape then the junk I have. Also was able to snatch up a pigtail for the diff sensor at the salvage yard. Soldered in the wires, covered it with shrink rap and split loom, good to go. The wire or tab that held the sensor were broke and I wanted to be original so I did something a bit more creative with it 😉. (notice I used blue zip ties to go a long with the powder-coated pieces.) Went ahead and started dissembling the injectors for a rebuild. Purchased a kit on amazon coming with all the filters and o rings needed to refurbish them. Used a wood screw to pull out the old filters... As some of the injectors had some minor surface rust and the paint was wearing off the only right thing to do was to put a fresh coat of paint on them. I did apply a light coat of primer before the paint. Finally got myself a brake booster that was much needed. Picked it up out of a salvage yard in fond du lac (diamond auto parts). The booster is from a 86 Porsche 944 turbo and I was very pleased with the condition of it. As it did have some surface rust and what not I got to repainting that as well... A lot of bare metal was showing after I went at it with a wire wheel and scotch brite so I threw on a coat of primer first. Gonna head over and throw a coat of flat black paint on it in a bit. Injectors should be dry by now and ready to be installed. As that was drying I dissambled all the shifting linkages off the trans and took the pressure washer to it one more time to see if I can't get any more grim off. I was very unsuccessful. After a half hour of 3500 psi of water on a 0 degree tip I gave up, shit ain't comin off. Blew the thing off with a air hose and put in some fresh trans oil. Quick tip: I used MT-90 as it is recommended to be used on all getrag trans with a green tag. If yours is not green taged it is recommended to stick with redline MTL. Quick question: On this particular trans, it came with a harmonic dampener on the flange. This was in particular is not like the one's where the dampener is on the driveshaft that I'm familiar with. Was gonna remove it but I failed miserably as none of my sockets would fit correctly. I'm thinking I'm probably just gonna keep it, any reason to be rid of it? Received some headers in the mail from amazon the other day. Pretty cheap ones but should do the job well. Plan is to ceramic coat them so the following day I threw them in the blasting cabinet. I will be using the ceramic coating from eastwood (same stuff @snap used) which should hopefully be here in the next day or so. Clutch kit showed up! as well as many other things greatly needed to get this car a few steps closer to being finished. Parts above: Gribforce clutch kit with aluminum flywheel CSS clutch line Oem control arms Oem E36 tie rod assembly's Oem tie rod boots 2 liters of ate typ 200 dot 4 brake fluid oem clutch fork pivot oem clutch release arm spring oem throw-out bearing oem pilot bearing 2nd bosch knock sensor 2 oem grommets for brake master cylinder reservoir vdo oil pressure gauge I picked up on r3v custom ashtray gauge pod a friend of mine designed and cut out for me (will be wrapping it with oem vinyl) 1 lb of black nylon flocking fibers Stuff hoping to see in the next day or so: IE front adjustable sway bar links IE poly steering coupler bushing eastwood ceramic coating UUC EVO III short shifter Right away I ripped open the clutch kit and did what needed to be done. Now that that's done, on to the next thing of business... steering rack. Applied red loctite to threads before tightening and applied some grease around the inner tie rod joint before installing the boots. I was so very pleased with the gauge pod my buddy made for me I feel a need to post a more justified pic of it. As u may of noticed above I did end up getting the UUC shifter. After looking around a bit I noticed a guy selling one hardly used and in nice shape for less then half of what they are new also including the aluminum shifter carrier and a weighted shifter . It was posted as an auction so for my very first time I played the bidding game and Won! For only about 5 dollars more then the starting price. Hopefully gonna be seeing it here sometime Friday. Got myself a lot on my plate to get installed. Plan is to start getting the rear end assembled and get the trans and harness installed on the motor this weekend. KaiserRolls 1 Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted May 2, 2018 Report Share Posted May 2, 2018 Nice trash pic Lol! Might want to test fit those headers in the car before going through all the ceramic coating. They will most likely need some coaxing with a hammer to clear the subframe/engine mount. Might have to widen out the flange holes as well awesome progress! Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted May 2, 2018 Report Share Posted May 2, 2018 Also use OEM gaskets on the headers if you can. The ones they provide will probably leak after 1000 miles. Cant remember if you bought exhaust studs yet, but I think(?) people buy n54 because they have an Allen on the end for easy install (no two nut method, unless you’re into that) Quote Link to comment Share on other sites More sharing options...
YoungCR Posted May 3, 2018 Report Share Posted May 3, 2018 For the trans dampener you have to remove the output flange with a thin wall 30mm socket **after removing the lock plate** around the flange nut. Most guys just grind down a cheaper impact socket but you also need a good impact too. TLDR it’s a pain, so leave it if it’s fine. Quote Link to comment Share on other sites More sharing options...
GunMetalGrey Posted May 3, 2018 Report Share Posted May 3, 2018 Looks like you need boost. Just sayin' AsparagusMike 1 Quote Link to comment Share on other sites More sharing options...
B C Posted May 3, 2018 Report Share Posted May 3, 2018 Are those harness wire connections just twisted together and heat shrinked? I am breaking up with my soldering iron because I have discovered the joy of a properly installed crimp connector. I spend way too much time soldering things. The o2 bungs on those headers are worthless so dont toss the plugs that come with them. I didnt really have too much issue with fitment. The engine mount arm I have has already been clearancedfor the header and I just had to compress the relatively soft heat shielding material on the firewall where it bends down into the floorpan. Quote Link to comment Share on other sites More sharing options...
AsparagusMike Posted May 3, 2018 Author Report Share Posted May 3, 2018 16 hours ago, KaiserRolls said: Nice trash pic Lol! Might want to test fit those headers in the car before going through all the ceramic coating. They will most likely need some coaxing with a hammer to clear the subframe/engine mount. Might have to widen out the flange holes as well awesome progress! Thanks for the tip! I will take a look at that 16 hours ago, KaiserRolls said: Also use OEM gaskets on the headers if you can. The ones they provide will probably leak after 1000 miles. Cant remember if you bought exhaust studs yet, but I think(?) people buy n54 because they have an Allen on the end for easy install (no two nut method, unless you’re into that) Shit! that sucks. When I sold the exhaust manifolds to a guy last week I gave him the oem gaskets I had purchased for these headers as well sense I saw that they came with new ones already. Live and learn. I did go ahead and use the n54 exhaust studs, I very much like the torque head on the end to tighten them in, lots of time is saved going that route for sure. 14 hours ago, YoungCR said: For the trans dampener you have to remove the output flange with a thin wall 30mm socket **after removing the lock plate** around the flange nut. Most guys just grind down a cheaper impact socket but you also need a good impact too. TLDR it’s a pain, so leave it if it’s fine. Like u said I noticed that I would probably have to modify a socket to get it off. Seems like a pita so I'm just gonna leave her on there. 1 hour ago, snap said: Are those harness wire connections just twisted together and heat shrinked? I am breaking up with my soldering iron because I have discovered the joy of a properly installed crimp connector. I spend way too much time soldering things. The o2 bungs on those headers are worthless so dont toss the plugs that come with them. I didnt really have too much issue with fitment. The engine mount arm I have has already been clearancedfor the header and I just had to compress the relatively soft heat shielding material on the firewall where it bends down into the floorpan. Yup I just twisted the wires tightly, helps if you have longerish thumb nails to get them really tightened together. I use to have a really cheapy soldering iron that barely got hot enough to melt the solder, made me hate soldering tell I finally invested in a better one that I couldn't be happier with and it makes soldering very quick and painless. I have used the crimp connects as well on other applications and I don't mind them but for the little extra time it takes for the soldering and shrink tube I think its worth it cause IMO they seem to hold up much better. Couple more things showed up at the old doorstep dis mornin... Also got around to finishing up with the injectors and getting them reassembled. Before reinstalling them I want to run some injector cleaner through them to make sure they are working properly. straight6pwr and KaiserRolls 2 Quote Link to comment Share on other sites More sharing options...
SteelBlue Posted May 3, 2018 Report Share Posted May 3, 2018 This build is incredible. Great work. Quote Link to comment Share on other sites More sharing options...
AsparagusMike Posted May 5, 2018 Author Report Share Posted May 5, 2018 I got no pressure plate bolts with the girpforce kit. @KaiserRolls Is this normal? Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted May 5, 2018 Report Share Posted May 5, 2018 11 hours ago, AsparagusMike said: I got no pressure plate bolts with the girpforce kit. @KaiserRolls Is this normal? Mine did not come with any either. Could snag some decent stuff at the hardware store or re use if you’re in a pinch Quote Link to comment Share on other sites More sharing options...
AsparagusMike Posted May 14, 2018 Author Report Share Posted May 14, 2018 So I did end up having to do a little modifying to get the headers to clear the motor mount. After a little shaving everything is fitting up nicely. Front suspension and steering reinstalled. Made some measurements for a new plate for the re-positioned steering shaft and got that cut out. The hole where the boot goes in is slightly smaller then the original. The boot fits very snug in there which I like a lot. ( The new piece is out of 12 gauge stainless) UUC shifter showed up. The guy threw in a weighted selector rod he made himself with the shifter, which seems to consist of just a bunch of heavy gauge wire wrapped tightly around. Not gonna be using it as we ended up making a dssr instead so if anyone is interested in it you are more then welcome to have it. Speaking of dssr... So things went a little differently then anticipated so the gap is a bit wider which meant I had to throw in nylon washers on both sides to make the shifter and selector joint fit nice and tight. Once the washers are in though it is a very snug fit and I think is gonna work out great anyways. I did remember to angle the one side 10 degrees to compensate for the angle of the g260 trans when installed. ( All materials are off stainless as well ) Got the Obd1 harness dissected up and all the connectors identified and labeled. Everything makes sense except for one particular thing. It's the cam sensor harness connector. It's a male connector, and so is the cam sensor. Do I need to to cut and splice in a female plug on the harness side? I did some digging and checking but couldn't find anything on it. I do know for sure it is the cam sensor though. Now for exciting news... Motor is off the stand now. Got the flywheel, pilot bearing and clutch kit installed. I ended up picking up some hex bolts for the pressure plate at Menards, they worked great! Trans is installed on the motor as well as the starter. Everything torqued down. ... I did go ahead and hook up the shifter linkage to see how the dssr fit up. It looks like I'll be removing that flange dampener after all. Just to be sure here, Do I have to modify the shifter carrier at all sense it is twisted as well? On a even more positive note, Header clearances are looking great! I will be cutting off the reduced section on the one header as well. Next things on the to do list: Get the harness installed on the motor Brake booster modified and installed remove, ceramic coat and re-install headers flock the dash a second time clean carpet get drive shaft and shifter linkage fully installed I have brake rotors and brake pads showing up tomorrow so I will hopefully get around to getting those installed and bleed sometime this week. Sent my slave cylinder back to fcp for warranty replacement, hoping to see that back sometime this week so I can get that installed and bleed as well. This is the last week of school for me so as always I am getting slightly swamped with last minute projects and finals so I will work my hardest to find time and get over to the shop and get things cranked out. Of course I want to get the car going asap but not trying to meet any dead lines like the picnic as there is no way the car will be ready for that by then anyways. I do although still plan on coming down and hanging out with everyone, hopefully put a few names to faces. HipMF 1 Quote Link to comment Share on other sites More sharing options...
B C Posted May 15, 2018 Report Share Posted May 15, 2018 Looking forward to meeting you at the picnic! The cam sensor has a female connector which fits with the male connector on the harness. I had to order a different cam sensor because the first one I bought was the wrong gender/different plug. It needs to be an M50/S50 cam sensor I cant remember what gender everything is supposed to be but all I know is there was once a gay situation requiring a new sensor purchase Jdesign 1 Quote Link to comment Share on other sites More sharing options...
AsparagusMike Posted May 15, 2018 Author Report Share Posted May 15, 2018 Damn you @GunMetalGrey Quote Link to comment Share on other sites More sharing options...
HipMF Posted May 15, 2018 Report Share Posted May 15, 2018 40 minutes ago, AsparagusMike said: Damn you @GunMetalGrey Ben is still confused at the moment, but when he get it, it will be like: Quote Link to comment Share on other sites More sharing options...
GunMetalGrey Posted May 15, 2018 Report Share Posted May 15, 2018 10 hours ago, AsparagusMike said: Damn you @GunMetalGrey Easy chief! Is this because of your gender fluidity? Quote Link to comment Share on other sites More sharing options...
AsparagusMike Posted May 15, 2018 Author Report Share Posted May 15, 2018 1 hour ago, GunMetalGrey said: Easy chief! Is this because of your gender fluidity? It is. It's not your fault, lol. I thought for sure I had the right sensor because real oem was giving me that same part number as the sensor you gave me under a couple different obd1 vehicle. Made me keep thinking something was funky with harness. Quote Link to comment Share on other sites More sharing options...
GunMetalGrey Posted May 30, 2018 Report Share Posted May 30, 2018 Buy thishttp://www.bimmerworld.com/Cooling/Radiators/CSF-OE-Plus-Radiator-E36-M3-328-325-323.html Quote Link to comment Share on other sites More sharing options...
Earl Posted May 30, 2018 Report Share Posted May 30, 2018 @Tkuhn and I can attest that CSF is the way to go for radiators=) I had no clue that they made one with OE plastic ends. Tkuhn 1 Quote Link to comment Share on other sites More sharing options...
GunMetalGrey Posted May 30, 2018 Report Share Posted May 30, 2018 ^ For sure, it's a super cost effective option and I've used a few myself with no issues. Quote Link to comment Share on other sites More sharing options...
AsparagusMike Posted May 30, 2018 Author Report Share Posted May 30, 2018 3 hours ago, GunMetalGrey said: Buy thishttp://www.bimmerworld.com/Cooling/Radiators/CSF-OE-Plus-Radiator-E36-M3-328-325-323.html Quote Link to comment Share on other sites More sharing options...
AsparagusMike Posted May 30, 2018 Author Report Share Posted May 30, 2018 I feel so lame with my wimpy amounts of progress lately. Got the output flange removed, pulled the dampener off so I don't have anymore dssr clearance issues, then reinstalled. Had to modify a 30mm socket just slightly to fit around the nut. Now that the dssr clears, everything feels nice and tight and the shifter is very crisp. As you can see though, I'm having some lineup issues. I have no issues with shifting and it goes into every gear with no interference's but the thing is completely off center and looks wacky as hell so I'm just curious what others have done or if they had similar issues. Ceramic coat headers... check Re-installed them and was relieved when I crawled under and was able to screw in my O2 sensor with just enough clearance on the original bungs welded on the headers. Last week I pulled the dash back out and threw another layer of the flock it kit on there. It needs about a week to cure completely before blowing off access and reassembling. At the moment I'm waiting for the last of my parts to show up for the motor so to keep chugging along I took some time to install and bleed the entire brake system, brake pedal feels great and there are no leaks! Figured out why I was having troubles with the booster rod not bolting up to the pedal... I was trying to use the 944 clevis (left) instead of the original e30 one (right). All I can say is I'm lucky I didn't take any more off the threaded rod cause once I put the e30 one on it fit up perfectly! On to more brake related things... doesn't look like I will be having a e-brake this season. Instead of replacing the dust shield like any person with a brain would do I decided to sand blast and por-15 the old ones in order to save them. Well, turns out the metal is a bit to corroded through around the holes where the pins go in to hold the shoes and every attempt at installing the pins with the springs results in it just ripping back out and tearing the hole even more, yah! Sense I will have to replace the dust shields (which means pulling the trailing arms back off and the wheel hub) I removed the e-brake lines and decided I'm just gonna run no e-brake for this season and mess around with reinstalling it next winter. I did get the carpet scrubbed as best I could this last weekend. There are a few stains that are most definitely coming out but they are in areas where the floor mats will be covering so I'm not gonna worry about it to much. Hoping to get the carpet and dash reinstalled by the end of this week. Also gonna start tearing the front seats apart for reupholstering. Oh! one other thing I should mention is I found an alternative replacement for the gas tank tube. https://www.advancedfluidsolutions.co.uk/m16-x-15mm-swivel-nut-x-7mm---8mm-hose-tail-516-2107-p.asp I located this website off the forums from a guy who had found this part that has the correct flared ends for the tank. With the barbed end sides you just have to run a rubber gas hose with a bit of slack from one to the other. Now these parts are coming from the UK so I'm not entirely sure when they will be showing up but the cost was so inexpensive I couldn't not give it a try and according to this guy, they worked great with no leaks. Quote Link to comment Share on other sites More sharing options...
HipMF Posted May 31, 2018 Report Share Posted May 31, 2018 3 hours ago, AsparagusMike said: I feel so lame with my wimpy amounts of progress lately. Please. Your progress has made most off the people around here look lazy and pathetic, myself included. That being said, it's all the little nit-picky PITA details that make the difference between a "finished" project and a pile of parts that runs and drives. Keep it up! 👍 3 hours ago, AsparagusMike said: Don't tell @GunMetalGrey but I did the same mod to his 30mm this past weekend to get the input flange off my diff 😀 GunMetalGrey and AsparagusMike 2 Quote Link to comment Share on other sites More sharing options...
AsparagusMike Posted June 2, 2018 Author Report Share Posted June 2, 2018 😁😁 (ya I know, the pics are terrible. I dropped my phone and the camera lens hit a small rock and cracked so now I get fun little glares on every picture) Quote Link to comment Share on other sites More sharing options...
GunMetalGrey Posted June 15, 2018 Report Share Posted June 15, 2018 I like hearing these noises. suspenceful, m42b32, B C and 1 other 4 Quote Link to comment Share on other sites More sharing options...
