straight6pwr Posted October 10, 2019 Report Share Posted October 10, 2019 panoroof is happening! *subscribed* Jdesign 1 Quote Link to comment Share on other sites More sharing options...
Jdesign Posted November 19, 2019 Author Report Share Posted November 19, 2019 Here is a better picture of the top on the car. You can see some of the rough edge on the bottom from poor storage. I also wiped it down and remove the stickers that were on it. gilber33 1 Quote Link to comment Share on other sites More sharing options...
Jdesign Posted November 25, 2019 Author Report Share Posted November 25, 2019 Had the ultimate motivation to work on this car. Over the weekend I had two friends (David and Cher) swing by on my birthday and practice light painting using my car. I was only given 1 photo so far, but it's convinced me to put the car on the lift and finally start turning wrenches. 💗 I will post the images as they are processed and shared with me! m42b32, Nick_F, P_Roloff and 6 others 9 Quote Link to comment Share on other sites More sharing options...
YoungCR Posted November 26, 2019 Report Share Posted November 26, 2019 Love it! Quote Link to comment Share on other sites More sharing options...
Jdesign Posted November 27, 2019 Author Report Share Posted November 27, 2019 Image #2 from David. Cher took more images and I even got him to take a "practice" shot of the E24🙃😈. Im excited to see his, although I know they will take longer to process. HipMF, nick.e46.330i. and m42b32 3 Quote Link to comment Share on other sites More sharing options...
Jdesign Posted December 3, 2019 Author Report Share Posted December 3, 2019 As I wait for Cher to work his magic on the pictures, I have begun work again, and I got quite a bit done in one quick swoop. Step 1: was attacking the steering. Moving this thing around with the front wheels going wherever they wanted was extremely annoying. Previously I removed all the Z3 steering parts and left it at that. This past weekend I got the Z4 steering rack is installed, figured out inner and outer tie rods, and was able to delete the PS reservoir, pump, and lines. This meant I needed to install a new serp belt and new tensioner pulley as well to allow the belt to go on the opposite side of the tensioner. I even got a green belt for those added style points. After all of that, there was one last thing I had not been able to solve; the steering coupler issue. If you have an early model E30, the Z4 coupler fits the steering shaft and you just need to shorten the union shaft and call it good. Unfortunately, I have an airbag car and the splines are different. By different I mean that the common size is a 3/4" - 48. 3/4" Dia, 48 Splines. The E30 airbag shaft is 11/16" -36. 11/16" diameter, 36 splines. From what I have read, it seems like keeping some type of vibration damper is ideal as the feeling is very direct and may cause some column vibration. Seeing that I have fairly stiff suspension and rubber bands for tires, I wont overlook this. Basically this is what I need to make, and I need to make it visually appealing. This is what I have; The new Z4 shaft is on the left, the E30 Airbag shaft is on the right Here is a close up of the two couplers. As you will notice that the one is aluminum and one is steel. Because of this I can not simply just weld the correct ends together. And here is the rack in the car. As you can see you need the same spacers as you would for a Z3 or M3 rack. Flaming river makes a dampening universal joint but they are not cheap. I have to make sure they have it available in the correct splines/dia for my application and I won't need to make any custom parts. They look like this: Quote Link to comment Share on other sites More sharing options...
YoungCR Posted December 3, 2019 Report Share Posted December 3, 2019 Forgot to ask you about the firewall, did you already enlarge it for the Z3 rack? Quote Link to comment Share on other sites More sharing options...
Jdesign Posted December 3, 2019 Author Report Share Posted December 3, 2019 12 minutes ago, YoungCR said: Forgot to ask you about the firewall, did you already enlarge it for the Z3 rack? Never needed to. I think that's an issue with early models running newer racks. It was certainly offset more than the factory rack but not enough that I needed to modify anything. I wish they would hurry up and make steer-by-wire more common. 😐 Quote Link to comment Share on other sites More sharing options...
REKIII Posted December 4, 2019 Report Share Posted December 4, 2019 22 hours ago, Jdesign said: I wish they would hurry up and make steer-by-wire more common. 😐 I know it's probably not the point of this build, but it seems from a lot of reviews that the electric power steering, whether full drive by wire or electric motor assist is really disliked for the disconnected feel. Quote Link to comment Share on other sites More sharing options...
Jdesign Posted December 4, 2019 Author Report Share Posted December 4, 2019 7 minutes ago, REKIII said: I know it's probably not the point of this build, but it seems from a lot of reviews that the electric power steering, whether full drive by wire or electric motor assist is really disliked for the disconnected feel. Yeah I would never use steer-by-wire. It was more of a joke. I will say that electric power assist is great though. I have driven a few cars with it and it's not any different than traditional PS. My civic hybrid actually has it and its great. Quote Link to comment Share on other sites More sharing options...
REKIII Posted December 4, 2019 Report Share Posted December 4, 2019 5 minutes ago, Jdesign said: Yeah I would never use steer-by-wire. It was more of a joke. I will say that electric power assist is great though. I have driven a few cars with it and it's not any different than traditional PS. My civic hybrid actually has it and its great. That's good to hear. I haven't owned anything new enough to try out electric power assist yet. Someday before I die it would be great to figure out a rack set up for the M5. Stupid steering box with 37 linkages is stupid. Jdesign 1 Quote Link to comment Share on other sites More sharing options...
HipMF Posted December 4, 2019 Report Share Posted December 4, 2019 First idea: Use the Z4 u-joint bit and fabricate an adapter so that it could be bolted to the rubber damper on the E30 bits. Welding on the cast piece probably isn't a good idea, but the stock shaft is attached to it somehow...? Jdesign 1 Quote Link to comment Share on other sites More sharing options...
straight6pwr Posted December 4, 2019 Report Share Posted December 4, 2019 not sure how limited you want to keep the fab work on this but here's what popped in my head: leave a stub of the z4 shaft connected to the u-joint. cut a flat onto it and put a hole through the middle. key the flat into the adapter plate and put a bolt through to clamp the two parts together. a recess in the adapter plate could keep the bolt away from the flex joint. Jdesign 1 Quote Link to comment Share on other sites More sharing options...
Jdesign Posted December 4, 2019 Author Report Share Posted December 4, 2019 1 hour ago, HipMF said: Use the Z4 u-joint bit and fabricate an adapter so that it could be bolted to the rubber damper on the E30 bits. Welding on the cast piece probably isn't a good idea, but the stock shaft is attached to it somehow...? Almost spot on to my plan. I looked at it all for about 3 hours last night and decided my best bet is make a disc that I can weld to the Z4 steel end. This I will then turn on the lathe to make it centric and mark the placement for the mounting bolts. Then I will run two bolts through the plate into the flex disc connecting it to the aluminum E30 U joint. 16 minutes ago, straight6pwr said: not sure how limited you want to keep the fab work on this but here's what popped in my head: leave a stub of the z4 shaft connected to the u-joint. cut a flat onto it and put a hole through the middle. key the flat into the adapter plate and put a bolt through to clamp the two parts together. a recess in the adapter plate could keep the bolt away from the flex joint. That's a damn nice illustration. I am basically doing something similar, although the bolts have to be on the outside of the joint as the end caps of the U-joints are press fit with a special tool and hold the bearings to spec and I don't want to pull them apart. Otherwise I won't be able to get a bolt/ U joint stub through the center. I hope to have something mocked up this evening. Quote Link to comment Share on other sites More sharing options...
straight6pwr Posted December 5, 2019 Report Share Posted December 5, 2019 17 hours ago, Jdesign said: Almost spot on to my plan. I looked at it all for about 3 hours last night and decided my best bet is make a disc that I can weld to the Z4 steel end. This I will then turn on the lathe to make it centric and mark the placement for the mounting bolts. Then I will run two bolts through the plate into the flex disc connecting it to the aluminum E30 U joint. That's a damn nice illustration. I am basically doing something similar, although the bolts have to be on the outside of the joint as the end caps of the U-joints are press fit with a special tool and hold the bearings to spec and I don't want to pull them apart. Otherwise I won't be able to get a bolt/ U joint stub through the center. I hope to have something mocked up this evening. the shaft is press fit into the u-joint? no weld or splines? although i know the resistance of a press fit can be astounding, that's a little disconcerting. Quote Link to comment Share on other sites More sharing options...
Jdesign Posted December 5, 2019 Author Report Share Posted December 5, 2019 1 hour ago, straight6pwr said: the shaft is press fit into the u-joint? no weld or splines? although i know the resistance of a press fit can be astounding, that's a little disconcerting. Correct, and it's in there CRAZY good. You would need to chuck it in a mill to remove it without destroying both parts. Quote Link to comment Share on other sites More sharing options...
Jdesign Posted December 6, 2019 Author Report Share Posted December 6, 2019 Made an adapter last night and it came out pretty good. I still need to weld it all together but Im thinking this might be temporary though. I need to prove out that there is no binding with a single joint, otherwise I will take the dimensions and still go with the anti-vibe flaming river joint. (images wont attach. I will try again later) I have yet to weld this as I realized that I will not be able to remove the hardware once I do so. I rather not tap threads into the plate but that might be my only option. Quote Link to comment Share on other sites More sharing options...
straight6pwr Posted December 9, 2019 Report Share Posted December 9, 2019 what will the assembly process be? Are the two adapter bolts the last parts to be installed to bolt the column to the rack, or can everything be preassembled? can you just weld the screws into the adapter plate holes on the z4 joint side so you don't have to put a wrench on that side after final welding? or just weld a nut on that side and flip the fastener to avoid having to tap the adapter plate? i'm not sure what your main goal is here - professional fit/finish, ease of maintenance, or ease of fabrication, etc. Quote Link to comment Share on other sites More sharing options...
Jdesign Posted December 9, 2019 Author Report Share Posted December 9, 2019 4 minutes ago, straight6pwr said: what will the assembly process be? Are the two adapter bolts the last parts to be installed to bolt the column to the rack, or can everything be preassembled? can you just weld the screws into the adapter plate holes on the z4 joint side so you don't have to put a wrench on that side after final welding? or just weld a nut on that side and flip the fastener to avoid having to tap the adapter plate? i'm not sure what your main goal is here - professional fit/finish, ease of maintenance, or ease of fabrication, etc. It can be preassembled due to the telescoping airbag steering column. I could weld the nuts or bolts to the adapter and call it done. I need to get the right diameter shanked bolts first to see if I’m happy with it. It seems like once it’s all tight, the flex disc deflects and the bolts will just push the material out of the way. If that’s the case, this might just be a mock up for a flaming river joint. ¯\_(ツ)_/¯ Quote Link to comment Share on other sites More sharing options...
Jdesign Posted January 6, 2020 Author Report Share Posted January 6, 2020 Successful weekend. I completed the steering joint and installed it, bolted in new inner and outer tie rods, and I was able to make a pair of E36M3 boots stretch over the bigger bore Z4 rack by putting them in the oven and soften them. My first expectation of the rack is that lock to lock is super quick. 2.8 rotations or so. Feedback sitting in place is a little bit of a struggle as I kind of expected from what I read online with a non-powered rack. I have had non-powered rack cars before so this isn't new to me. I will potentially look into a electric assist (Similar to this one) later on if it is really bother some. I painted it black in hopes to hide it better in the engine bay. HipMF 1 Quote Link to comment Share on other sites More sharing options...
Jdesign Posted January 7, 2020 Author Report Share Posted January 7, 2020 Sick of moving the hardtop around, and I didnt want to leave it on the top of the car, I decided to start taking the hardtop apart over the weekend. It proved to be MUCH more challenging than I expected. One reason; GLUE. During the assembly, they literally use resin everywhere and glue almost everything in, EVEN if it has fasteners holding it in. Seals, trim, mounts, and fabric are all glued. On the plus side, I inspected all of the seals, latches, and trim and it is all in great shape, just the vinyl and headliner is in visually aging. Here are pictures as I dismantled it; Quote Link to comment Share on other sites More sharing options...
Jdesign Posted January 7, 2020 Author Report Share Posted January 7, 2020 At this point I was able to pull all of the fabrics off. I didnt take any in progress pics but it was really easy and happened quickly. Quote Link to comment Share on other sites More sharing options...
Jdesign Posted January 7, 2020 Author Report Share Posted January 7, 2020 The next step was to remove the glass. I want to keep the glass as it will make a nice guide for creating a buck for forming the Polycarbonate, but it sat a touch higher than the top, and in order to paint and re wrap the top properly it needed to come out so I bought one of these. Quote Link to comment Share on other sites More sharing options...
Jdesign Posted January 7, 2020 Author Report Share Posted January 7, 2020 So yeah that happened. I was able to get 3 of the 4 sides completely detached and I didnt think it would be a problem to finish. Although it was a work out as the top wasn't secured to anything, I was holding the top and pulling the carbide through the seal without a problem. the last edge I stopped and determined if I wanted to tape the glass to preventing it from falling or shifting. I removed the tool and stepped back. Heard a loud sealing/suction type noise and watched the window blow out about 5 feet into the air as I was standing about 3 feet away. I immediately went over to the fridge and poured myself a strong drink. So here is the top now. Its a weird astro turf color which I would like to think is the dye from the canvas. Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted January 7, 2020 Report Share Posted January 7, 2020 Must’ve had the rear defrost turned on Jdesign 1 Quote Link to comment Share on other sites More sharing options...
