gilber33 Posted April 1, 2020 Author Report Share Posted April 1, 2020 That is for a power sunroof. So the emergency key isn’t for manual sunroofs. I found that what I’m missing is this little gear here: As you turn the handle, the little tooth on there catches the tooth on the inside of the gear that drives the gear to open and close the sunroof. So I need to source one of those. I am assuming that the handle broke - as appears to be very common - and the PO removed the handle and this stuff fell apart. I’m crossing my fingers the whole mechanism still works once I get the crank back together. Quote Link to comment Share on other sites More sharing options...
straight6pwr Posted April 1, 2020 Report Share Posted April 1, 2020 oh, berty30. he said he's going to get 'race status' door panels 🙄 Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted April 1, 2020 Report Share Posted April 1, 2020 25 minutes ago, gilber33 said: That is for a power sunroof. So the emergency key isn’t for manual sunroofs. I found that what I’m missing is this little gear Tried to edit, you were too fast Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted April 1, 2020 Report Share Posted April 1, 2020 27 minutes ago, straight6pwr said: oh, berty30. he said he's going to get 'race status' door panels 🙄 I haven’t watched his content, just came up in search. Guessing by your comment I don’t need to watch lol Quote Link to comment Share on other sites More sharing options...
straight6pwr Posted April 1, 2020 Report Share Posted April 1, 2020 35 minutes ago, KaiserRolls said: I haven’t watched his content, just came up in search. Guessing by your comment I don’t need to watch lol nah, just another youtuber learning as he goes. some things to learn, with sprinklings of dumb. also heard in that video: "if this in the video then i did it, if its not in the video, then I didnt even do it, so you wont even see this" brilliant. Quote Link to comment Share on other sites More sharing options...
m42b32 Posted April 1, 2020 Report Share Posted April 1, 2020 12 hours ago, gilber33 said: Not knowing much about these: do I just get the crank and install that or do I buy the whole thing with the cables and everything as one large assembly. Ebay prices are ridiculous, do people actually pay that much for those?? I have an entire manual sunroof mechanism that worked perfectly when pulled that I have absolutely zero use for since neither of my cars have a sunroof. I'll PM you. gilber33 1 Quote Link to comment Share on other sites More sharing options...
gilber33 Posted April 3, 2020 Author Report Share Posted April 3, 2020 Sanding is 99% done! I did some touch up with 320, then 400 everything, and then a quick once-over with 600. After cleaning everything up I found a couple spots that need a little attention, but all in all it's done. I cleaned up the garage, blew it out, took down all the plastic and started taking off some of the masking. Next up is to put up new plastic and masking. I plan to paint everything not on the car first and then paint the car a different night to keep paint dust from collecting on parts to a minimum. And @m42b32 to the rescue! I'll be able to at least use this to see if my sunroof still works, and if it doesn't, I can swap in this working mechanism. Saved me a ton of money so it is very greatly appreciated. Jdesign and m42b32 2 Quote Link to comment Share on other sites More sharing options...
SteelBlue Posted April 3, 2020 Report Share Posted April 3, 2020 On 3/31/2020 at 11:25 PM, straight6pwr said: nah, just another youtuber learning as he goes. some things to learn, with sprinklings of dumb. also heard in that video: "if this in the video then i did it, if its not in the video, then I didnt even do it, so you wont even see this" brilliant. He’s like the only one that does E30 content, unless I haven’t come across them. All the other videos are from like 8 years ago recorded on a microwave. Jdesign and m42b32 2 Quote Link to comment Share on other sites More sharing options...
Rekpoint Posted April 3, 2020 Report Share Posted April 3, 2020 Dont forget to wet your floor before painting! Itll grab dust and overspray! Jdesign 1 Quote Link to comment Share on other sites More sharing options...
gilber33 Posted April 4, 2020 Author Report Share Posted April 4, 2020 4 hours ago, Rekpoint said: Dont forget to wet your floor before painting! Itll grab dust and overspray! Got a garden sprayer that I’ll be using for just that! Quote Link to comment Share on other sites More sharing options...
gilber33 Posted April 6, 2020 Author Report Share Posted April 6, 2020 Using the spare sunroof gears my sunroof tilts open but the gears are very sloppy when I try to slide it open. I am hoping the cassette is bad and I can replace that and be fine. The hard part is the front headliner panel is attached on top under the sunroof and to access those screws, I need to slide the sunroof open. I got a spare panel, so I may need to cut off the wrap that’s on it to access the cassette and hopefully fix it, and then put in the spare panel. 🤷🏼♂️ Quote Link to comment Share on other sites More sharing options...
gilber33 Posted April 6, 2020 Author Report Share Posted April 6, 2020 Fuck yeah. It needs to be cleaned out and lubed up, but this is a big win for me. m42b32, Rekpoint, jc43089 and 4 others 7 Quote Link to comment Share on other sites More sharing options...
gilber33 Posted April 8, 2020 Author Report Share Posted April 8, 2020 Still need to apply clear coat. It took five coats to get the hang of it. Had terrible issues with striping. Once I turned down the material adjustment a little bit and did much tighter passes it came out awesome. Doing large, flat areas is really hard. This is definitely not as easy as they make it look on YouTube. P_Roloff, Rekpoint and straight6pwr 3 Quote Link to comment Share on other sites More sharing options...
gilber33 Posted April 8, 2020 Author Report Share Posted April 8, 2020 Clear coated. Very happy with how these turned out for being my first time. KaiserRolls, straight6pwr, P_Roloff and 3 others 6 Quote Link to comment Share on other sites More sharing options...
B C Posted April 8, 2020 Report Share Posted April 8, 2020 Looks great from here! Cant wait to see it in a few years after the apocalypse is over Quote Link to comment Share on other sites More sharing options...
YoungCR Posted April 8, 2020 Report Share Posted April 8, 2020 Looks like a good match to delphin, nice work! Quote Link to comment Share on other sites More sharing options...
gilber33 Posted April 8, 2020 Author Report Share Posted April 8, 2020 10 hours ago, B C said: Looks great from here! Cant wait to see it in a few years after the apocalypse is over Thank you! There are some minor streaks, but it has a good balance of being really good and not perfect because it’s not a show car. 6 hours ago, YoungCR said: Looks like a good match to delphin, nice work! Thanks! It’s a little lighter than delphin I think. But, I like the color and I’m not changing it. Haha. Quote Link to comment Share on other sites More sharing options...
straight6pwr Posted April 8, 2020 Report Share Posted April 8, 2020 its now a much better match to the color of dolphins Quote Link to comment Share on other sites More sharing options...
gilber33 Posted April 8, 2020 Author Report Share Posted April 8, 2020 1 hour ago, straight6pwr said: its now a much better match to the color of dolphins I like that. Henceforth this car is no longer Delphin, but Dolphin. Quote Link to comment Share on other sites More sharing options...
gilber33 Posted April 12, 2020 Author Report Share Posted April 12, 2020 Next up is to wetsand it and then do a cut and polish. Going to order a setup from Chemical Guys. There are some really good spots, and there are some spots where the clear feels a little dusty - assuming it’s overspray. m42b32, AsparagusMike, B C and 3 others 6 Quote Link to comment Share on other sites More sharing options...
gilber33 Posted April 14, 2020 Author Report Share Posted April 14, 2020 Wet sanding underway. 1000, 1500, and 2000. m42b32 and P_Roloff 2 Quote Link to comment Share on other sites More sharing options...
jc43089 Posted April 14, 2020 Report Share Posted April 14, 2020 It is so scary to start sanding on paint. Quote Link to comment Share on other sites More sharing options...
gilber33 Posted April 14, 2020 Author Report Share Posted April 14, 2020 2 minutes ago, jc43089 said: It is so scary to start sanding on paint. It was an uneasy feeling at first, definitely. But it has three coats of clear on it which gives me a nice layer to work with and some reassurance I'm not going to mess it up. Quote Link to comment Share on other sites More sharing options...
jc43089 Posted April 14, 2020 Report Share Posted April 14, 2020 51 minutes ago, gilber33 said: It was an uneasy feeling at first, definitely. But it has three coats of clear on it which gives me a nice layer to work with and some reassurance I'm not going to mess it up. I am watching and learning. I painted a hood and bumper cover for my van but did not do any finishing, I would like to clean it up a little because it has some orange peel and spots that feel rough like you mentioned. Thanks for the walk through. Quote Link to comment Share on other sites More sharing options...
gilber33 Posted April 14, 2020 Author Report Share Posted April 14, 2020 36 minutes ago, jc43089 said: I am watching and learning. I painted a hood and bumper cover for my van but did not do any finishing, I would like to clean it up a little because it has some orange peel and spots that feel rough like you mentioned. Thanks for the walk through. I really didn't want to wetsand. I had already spent so much time getting to the point of painting, that I was burnt out on it. But I was convinced to do it and after I started I'm really glad I did. Wetsanding showed me how many imperfections the clear coat had that you really can't see. When I'm all done I'll put together my overall thoughts on the whole project and what'd I'd do differently. Jdesign, KaiserRolls and jc43089 3 Quote Link to comment Share on other sites More sharing options...
