jc43089 Posted April 12, 2014 Report Share Posted April 12, 2014 The flywheel bolts are one-time use so dont feel bad about getting new onesOnly because they come with loctite preapplied right? They aren't stretch bolts as far as I am aware, I could be wrong on that though. Quote Link to comment Share on other sites More sharing options...
B C Posted April 12, 2014 Report Share Posted April 12, 2014 You may be correct, the Bentley manual doesn't specifically say they whether they are torque-to-yield or not, but they do specify to use new bolts in section 4-58. Im sure plenty of people have re-used them without issue but boy wouldn't that really blow to have to tear it all back apart within a few hours/days of doing a trans+clutch job. Bassboy had a 240sx that had something similar happen. Quote Link to comment Share on other sites More sharing options...
jc43089 Posted April 12, 2014 Report Share Posted April 12, 2014 I have reused them before, not saying that I am right though, I have seen that in the manual as well. I assumed they are not TTY because it is a straight torque spec rather than torque then degrees like the head/ rod cap bolts. Bentley also says not to reuse the bolts that hold the axle shafts to the differential. Previously I just degreased them and put a little red loctite on them, It also needs the loctite to seal up or it can leak oil because the holes go all of the way through the crank flange. Quote Link to comment Share on other sites More sharing options...
YoungCR Posted April 14, 2014 Report Share Posted April 14, 2014 I have been told by technicians not to reuse the flywheel bolts, so the Bentley is correct. Quote Link to comment Share on other sites More sharing options...
Bassboy3313 Posted April 14, 2014 Report Share Posted April 14, 2014 If you want to throw those 2.0L pistons, rods & crank my way I will gladly get them out of the way for you. Quote Link to comment Share on other sites More sharing options...
bfinley Posted April 14, 2014 Author Report Share Posted April 14, 2014 If you want to throw those 2.0L pistons, rods & crank my way I will gladly get them out of the way for you. I was going to weld them up into a table or something. I'll trade you for those decals email me your shirt files too and I can get started on them. Update: all glass except the door windows are out, I think I've found all the rust holes that need to be fixed, the main debate now is patch or replace... There are some significant holes in the front fenders and new rockers are pretty much a given. I need to shuffle money around to get the 2.7 from Mike, I really hate getting paid once a month... My shop mates are making a run to steel mart so I should have some sheet steel to practice welding and making patches. I'll need to get a lesson in POR15 from Mr. Menard as well Quote Link to comment Share on other sites More sharing options...
jc43089 Posted April 14, 2014 Report Share Posted April 14, 2014 Just brush it on! it self levels pretty nice, I use KBS Rustseal, available at Napa. Similar product, some have said it's better, I just use it because it's easy to get and extremely durable. bfinley 1 Quote Link to comment Share on other sites More sharing options...
Bassboy3313 Posted April 14, 2014 Report Share Posted April 14, 2014 I was going to weld them up into a table or something. I'll trade you for those decals email me your shirt files too and I can get started on them. Sounds good! I will send them to your email. Sent from my XT901 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Bassboy3313 Posted April 14, 2014 Report Share Posted April 14, 2014 Just brush it on! it self levels pretty nice, I use KBS Rustseal, available at Napa. Similar product, some have said it's better, I just use it because it's easy to get and extremely durable. I used nothing but KBS rust seal on my project and it is amazing! Cheaper than POR15 too. Never knew Napa carried it. I always ordered it straight from KBS and it would arrive next day most the time. Sent from my XT901 using Tapatalk bfinley 1 Quote Link to comment Share on other sites More sharing options...
bfinley Posted April 14, 2014 Author Report Share Posted April 14, 2014 Just brush it on! it self levels pretty nice, I use KBS Rustseal, available at Napa. Similar product, some have said it's better, I just use it because it's easy to get and extremely durable. Sounds good I'll try to get some tonight after work Quote Link to comment Share on other sites More sharing options...
jc43089 Posted April 14, 2014 Report Share Posted April 14, 2014 I would go with the gloss black, it turns out great, no clearcoat needed unless it will get alot of sun. Don't plan on reusing the brush and it's best to use the whole can, if you have to reclose it then put a piece of plastic on before the lid or it won't come off again. Quote Link to comment Share on other sites More sharing options...
Bassboy3313 Posted April 14, 2014 Report Share Posted April 14, 2014 I would go with the gloss black, it turns out great, no clearcoat needed unless it will get alot of sun. Don't plan on reusing the brush and it's best to use the whole can, if you have to reclose it then put a piece of plastic on before the lid or it won't come off again. Yes! Do this! Speaking from experience as is JC I would imagine, lol. Also, wear latex gloves and a long sleeve shirt you dont mind ruining as once this stuff touches your skin it takes weeks to get off. Ask me how I know Quote Link to comment Share on other sites More sharing options...
bfinley Posted April 17, 2014 Author Report Share Posted April 17, 2014 So I started painting the engine bay with the kbs... Completely disregarded the warning on gloves... Opps... Also decided that despite being welded to the front valence the fenders need to be replaced and therefore be removed. No dice all the bolts are out and the finders won't budge. Inner fender is coated in a rubberized undercoat of some kind and I think it's holding the fender on. Really hoping that they aren't welded too Quote Link to comment Share on other sites More sharing options...
Earl Posted April 17, 2014 Report Share Posted April 17, 2014 If they welded them to the bumper, you can count on them being welded on everywhere else=/ Quote Link to comment Share on other sites More sharing options...
Rowleym Posted April 18, 2014 Report Share Posted April 18, 2014 ^ I thought it was done from the PO Quote Link to comment Share on other sites More sharing options...
bfinley Posted April 18, 2014 Author Report Share Posted April 18, 2014 ^ I thought it was done from the PO Thought what was done? Quote Link to comment Share on other sites More sharing options...
bfinley Posted April 19, 2014 Author Report Share Posted April 19, 2014 Went into the shop planning to clean and organize my pile of parts ... Ended up wrestling the fenders off. Thankfully they were not welded on, just a nasty combo of some kind of gasket paste and rubber under coat... Quote Link to comment Share on other sites More sharing options...
bfinley Posted May 1, 2014 Author Report Share Posted May 1, 2014 Goodness it's been a while, I've been slowly removing paint and bondo.. Gonna take it down to bare metal and build it back up. I finally got an argon tank for the welder. So after commencement I'll be patching the floors. Picked up a 2.7 eta from mike, full harness and ECU, connected to an auto trans which has already been removed. Fighting with the torque converter though. so if anyone has an 885 head laying around... I want it I'll get some pictures over the weekend Mike and maybe John are going to come down this weekend to help me get the 2.7 eta on a stand, grind down some more paint and pull the dash. Quote Link to comment Share on other sites More sharing options...
bfinley Posted May 5, 2014 Author Report Share Posted May 5, 2014 Dash is out, brake booster is out, steering column is out, tail lights are out. Still need to get the heater core. Finally down to just a shell, going to make a trip to steel mart soon and get the floors patched. Then order the roll cage next month. Quote Link to comment Share on other sites More sharing options...
jc43089 Posted May 5, 2014 Report Share Posted May 5, 2014 Looks good, I hope you took lots of pics of how the wiring goes lol. How much interior do you plan on putting back? Quote Link to comment Share on other sites More sharing options...
B C Posted May 5, 2014 Report Share Posted May 5, 2014 We dont frequently get to see the finished product of a project thread on here. I hope we get to see this one finished! Quote Link to comment Share on other sites More sharing options...
bfinley Posted May 5, 2014 Author Report Share Posted May 5, 2014 The dash will go back after I add some tubing for structural integrity. John you know Mike and I aren't as meticulous as you are, we'll just remember where everything went right? ok there isn't a chance I'll rememer and we definitely didn't label them. Most everything in the dash however will not be going back. I'll be making a custom gauge cluster with lots of aircraft style switches, because I can ! Snap, this car will be driving and painted by the end of the summer Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted May 5, 2014 Report Share Posted May 5, 2014 Do work!! Looking good and it is good to see it being done the right way. Quote Link to comment Share on other sites More sharing options...
bfinley Posted May 5, 2014 Author Report Share Posted May 5, 2014 Do work!! Looking good and it is good to see it being done the right way. Thank you! I don't know about "done the right way" but it's going to get done and it's going to be obscenely fun DrLeadFoot 1 Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted May 5, 2014 Report Share Posted May 5, 2014 Do work!! Looking good and it is good to see it being done the right way. Thank you! I don't know about "done the right way" but it's going to get done and it's going to be obscenely funIt seems you aren't bandaidin' the car. You're getting in there and addressing the issue. That's done the right way in my book!Sent from my SCH-I535 using Tapatalk Quote Link to comment Share on other sites More sharing options...
