Jump to content
1978 e21 m20 turbo swap, AKA What did I get myself into
bfinley
What linkage parts?  Kruse Warthan is usually dissapointing, on service and price.
I'm at my parents so I went to motorwerks BMW in Bloomington mn.
I'm going to go back on Monday when a friend of a friend is working. He is supposed to be good.
Basically the whole carrier and linkage that you have in yours John
Link to comment
Share on other sites
Oh, I have been thinking about a better deal, there are floor mount shifters available like this.
We could make a custom one, it is just a plate over the shifter hole with a socket for the pivot ball.  And then all that is needed is to fabricate a custom length selector rod once you know the dimension from the shifter to the transmission.  Do you know for sure that the e30 parts will even work correctly in an e21?  I bought a used aluminum carrier from somebody on BFC for $35 shipped so I would not but that stuff new.
Link to comment
Well I went to the Motorwerks BMW in Bloomington MN on Saturday since I am at my parents for the weekend.
They want 538 dollars for everything in the specific exploded diagram, I politely thanked them for their time and walked out with an itemized list and the memory of why I don't work for a dealership anymore.
After doing some more digging about my specific trans I found that it is a "late" model gt 260 which can accept both the plate and beam style of shifter...
So that helps and I'll be holding out for a used part instead of dropping a ridiculous amount for NEW
Which means I can look at buying the clutch and flywheel as well.
Shooting for an installable motor by the end of the month.
Here's the website that helped me sort out which version of the 260 I've got
http://www.unofficialbmw.com/phpBB/viewtopic.php?t=33173
AND - dohcdoh on bimmerforums.com just sold me a complete linkage for 45 dollars shipped... that is a lot better than 500!
Link to comment
lots of dust up in there!
Are you finished with the metal cutting/welding patches?
Havent started yet... I'll admit that cutting the floor out scares me a bit and I've been fixated on getting the pait stripped so I can deep clean the shop and be done with that.
Link to comment
Glad you found one, I got one minus the shifter itself for 35 shipped.  I just used my old e36 shifter for the e30.  What are you thinking for the flywheel clutch setup?
Yeah someone said I could reuse the e21 shifter as well, I figured what the heck and got the whole unit so I don't have to mess around with it.
I'll get a short shifter eventually as well.
Clutch and flywheel I'm just going to buy new and bite that bullet but as long as both pieces are for the same car I can use a clutch and fly wheel from any model e30 I like, so lightweight single mass kit it is.
spending 700 bucks on a kit doesn't sound so bad when you're not spending 500 dollars on a shifter either
Link to comment
What kits in particular are you looking at?  I think my UUC is great at 11.5 lbs (flywheel is actually 8.5 but the larger clutch/PP is 3lbs more than stock) but very expensive.  After more research I think the are made by Fidanza, I am not convinced that the Ebay ones are different at all.  You may be able to tell by what clutch parts are used in the kit.  Mine uses an e34 m5 oem clutch, PP, and throwout bearing.
Link to comment
Ok, Watch their site directly, they do nice promos almost every weekend, until midnight it is 10% off and free shipping.  The price on their site is $974.  They frequently do 15% off so I would hold out for that, Price has probably gone up from 3 years ago but I think I paid 750ish.
Link to comment
  • 2 weeks later...
Might be saving a bunch of cash and getting the clutch and fly off the Kamotors e30
Got the shifter linkage
Flares are ordered
Got a second lead on fenders in good shape
So I'm using mine to test the paint scheme
Dtm fiberwerks Motorsport front bumper and factory rear vent windows are on there way shortly
Now I need to drop the rear sub, get the drive shaft out
Fab motor mounts
Fix brakes
Paint
Reassemble
M20 burnouts !
Link to comment
Got the first layer of green on the fenders only to run out, no one in town currently has the dupli-color self etching OD flat primer that I'm using.
I'm going to check with napa tomorrow about custom mixed aerosol cans....
Since I didn't want to go home with no power I went back to the shop and cut my riveted aluminum panels to cover the gaping holes in the fenders
Link to comment
  • 2 weeks later...
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Create New...
Important Information
