straight6pwr Posted April 25, 2016 Author Report Share Posted April 25, 2016 did some 'spirited' driving today...wow this car can actually handle! even on stock 15" snow tires, its finally a blast to chuck around the corners. the tires are a little overworked and i think i got some extra toe-out from the lowering (squeeeeeeeeel) but the handling is very neutral, and any slop or clunking is finally gone. hopefully the 18" setup will improve things even more. <3 my e34. this top hit, also from 94, sums up my feelings right now: Quote Link to comment Share on other sites More sharing options...
straight6pwr Posted May 8, 2016 Author Report Share Posted May 8, 2016 Got a couple more things done from the spring cleanup list. hoping to be all done with everything next weekend so I can spend the rest of the summer enjoying the car and doing other summer things. got some new floor mats. have been running rubber ugly mats that came with the car since I got it. also, when I did the suspension swap, i found one dead ball joint on the thrust arms, and one dead one on a sway bar link, so i swapped those out, got an alignment, and got the summer wheels on. I went to Firestone since they were closest to my house and had some open time in the morning, but i had to sit there and convince them they could do the alignment... 'Oh, we're sorry, we don't align BMWs here because of all the weight that is required, blah, blah, blah.' SOB its a 20 year old car with only one adjustment! anyways it was worth it because i was able to put the new kicks on. 18x8" (square) Style 32s with 225/45 all-seasons. Went with those tires for lower weight, less rolling resistance, and road-tripping ability (mountain snow, dirt roads, etc) she's begging for spacers in the back, but we will see. B C 1 Quote Link to comment Share on other sites More sharing options...
B C Posted May 8, 2016 Report Share Posted May 8, 2016 . yogurtland=purple. really yogurtland? Fixed Looks stunning! A front lip of some sort would really complete the package. I know you did the manual swap, are you still planning to do a 4.0 swap down the road? Quote Link to comment Share on other sites More sharing options...
straight6pwr Posted May 8, 2016 Author Report Share Posted May 8, 2016 thanks. yes, you are right about the front lip. i have a plan for that. yeah 4.0 in the future. after being forced to drop $$$ on the valley pan/intake leaks, i think i'll run the 3.0 as far as it will go, though. Quote Link to comment Share on other sites More sharing options...
CMart Posted May 8, 2016 Report Share Posted May 8, 2016 I've got 2 spacers if you are interested. Quote Link to comment Share on other sites More sharing options...
straight6pwr Posted May 8, 2016 Author Report Share Posted May 8, 2016 3 minutes ago, CMart said: I've got 2 spacers if you are interested. size/price/extended lugs? Quote Link to comment Share on other sites More sharing options...
CMart Posted May 8, 2016 Report Share Posted May 8, 2016 Look to be about 3/8", come with extended lugs, ECS Tuning brand. I typed in the part number on the side and get this: https://www.ecstuning.com/Search/SiteSearch/10mm_Spacer/ES2550806/ Half off fair? They could probably use some cleaning. Quote Link to comment Share on other sites More sharing options...
straight6pwr Posted May 8, 2016 Author Report Share Posted May 8, 2016 thanks, going to pass. I need something more like 15mm/20mm to fill things out. Quote Link to comment Share on other sites More sharing options...
CMart Posted May 8, 2016 Report Share Posted May 8, 2016 All good. I had these on the front of the E60 for a while, but they caused rubbing with the wheel setup. Quote Link to comment Share on other sites More sharing options...
straight6pwr Posted May 12, 2016 Author Report Share Posted May 12, 2016 beautiful foggy night tonight. tried not to get murdered while out in the industrial back lots for a picture or two. also, i struggled a bit taking good shots in the fog, I need more practice! DrLeadFoot 1 Quote Link to comment Share on other sites More sharing options...
B C Posted May 12, 2016 Report Share Posted May 12, 2016 Your headlights r garbage. I have Finding Nemo flashlights that r better than that But really, im interested in there being a WIBIMMERS 2017 calendar or something and we should put your photography to use at some of these meets. YoungCR and KaiserRolls 2 Quote Link to comment Share on other sites More sharing options...
straight6pwr Posted June 11, 2016 Author Report Share Posted June 11, 2016 On 5/12/2016 at 6:30 AM, Snap said: Your headlights r garbage. I have Finding Nemo flashlights that r better than that But really, im interested in there being a WIBIMMERS 2017 calendar or something and we should put your photography to use at some of these meets. I would help with a calendar, sure. another update towards the car becoming the Ultimate Daily-ing Machine Installed a Curt Class I hitch. Was going to be building a teardrop camper to tow, but sadly that won't happen. Next plan is maybe a small boat and using a trailer to pickup bigger engines. it bolts to the underside of the bumper, and in these three places under the body. its rated to 150lbs tongue weight, but i stood on it and bounced and i'm a well overweight at 2 1/4 and nothing broke so i have confidence in it. still finishing up the wiring, but the cool part is i can hide the plug behind the tow hook cover to keep it pretty protected from dirt/rain/snow. Quote Link to comment Share on other sites More sharing options...
straight6pwr Posted June 18, 2016 Author Report Share Posted June 18, 2016 wiring done. labeled it for anyone else who is thinking of doing this. because the e34 has the light check system, the wiring adapter you need is the kind that takes its power from the car's battery, and the splice wires to the lights only give the adapter the signal for which lights to turn on. that way the voltage drop/raise is so low the system doesn't throw a check light. mounted it inside the passenger side panel since I don't really use this side for storage. factory sound insulation fits right over the top of it so i can still put stuff in here if i want to with damaging anything. don't mind the brown burned-looking crap on the ground wire. there was mystery goo on the bottom of the insulation that i didnt notice till it was too late. Quote Link to comment Share on other sites More sharing options...
visian Posted June 29, 2016 Report Share Posted June 29, 2016 Looks great! I've been considering adding a hitch to my e46 wagon. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
straight6pwr Posted July 3, 2016 Author Report Share Posted July 3, 2016 On 6/29/2016 at 0:35 PM, visian said: Looks great! I've been considering adding a hitch to my e46 wagon. Sent from my iPhone using Tapatalk Thanks! did some touring things with the touring today. i custom built the tandem rack by re purposing a set of two regular bike holders. new tandem racks cost $300-400, I did this one for $15 in hardware (i found the racks on the side of the road) KaiserRolls 1 Quote Link to comment Share on other sites More sharing options...
Earl Posted July 3, 2016 Report Share Posted July 3, 2016 Hell yeah=) Quote Link to comment Share on other sites More sharing options...
Bassboy3313 Posted July 3, 2016 Report Share Posted July 3, 2016 Amazing!! Sent from my SM-G930R4 using Tapatalk Quote Link to comment Share on other sites More sharing options...
B C Posted July 3, 2016 Report Share Posted July 3, 2016 First time seeing a tandem on the roof of a car. Great pic! Like a lot of people, wish that car belonged to me Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted July 3, 2016 Report Share Posted July 3, 2016 Ride a tandem bike by yourself from the rear seat Quote Link to comment Share on other sites More sharing options...
straight6pwr Posted July 3, 2016 Author Report Share Posted July 3, 2016 thanks guys. like this? visian 1 Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted July 4, 2016 Report Share Posted July 4, 2016 Use the front pedals tho Quote Link to comment Share on other sites More sharing options...
suspenceful Posted July 5, 2016 Report Share Posted July 5, 2016 Looks awesome. Love the Alpinas? Quote Link to comment Share on other sites More sharing options...
YoungCR Posted July 5, 2016 Report Share Posted July 5, 2016 1 hour ago, suspenceful said: Looks awesome. Love the Alpinas? BMW Style 32's, Alpina's have more spokes. suspenceful 1 Quote Link to comment Share on other sites More sharing options...
straight6pwr Posted July 5, 2016 Author Report Share Posted July 5, 2016 5 hours ago, YoungCR said: BMW Style 32's, Alpina's have more spokes. yup. 90% of the style for 25% of the cost = 100% worth it. m42b32 and YoungCR 2 Quote Link to comment Share on other sites More sharing options...
straight6pwr Posted July 22, 2016 Author Report Share Posted July 22, 2016 welp, sold the tandem bought a kayak, so now the e34 has a kayak rack and hood loops. Quote Link to comment Share on other sites More sharing options...
