straight6pwr Posted October 14, 2015 Report Share Posted October 14, 2015 so you got it? my best guess for this was it was referring to which side of the connector and where it is headed. Basically male(pin)/female(socket) for that junction and everything 'socket' was on the side headed towards the body/other controllers and everything 'pin' was on the side headed to the DME. so your white connector is the 'pin' side, and the the 'socket' side is where its headed toward on the body.B: Socket housingS: Pin housing i wasnt positive, though, because your connector is missing some pins that are listed in the chart, although cars can differ from year to year Quote Link to comment Share on other sites More sharing options...
CMart Posted October 14, 2015 Author Report Share Posted October 14, 2015 Yeeep. A little trial and error and boom. Now all the little wires, straighten up some of the routings, bleed the brakes/clutch and give it some abuse on Sunday. B C and KaiserRolls 2 Quote Link to comment Share on other sites More sharing options...
wasnt m3 Posted October 14, 2015 Report Share Posted October 14, 2015 Congrats! Definitely looking forward to seeing/hearing this thing in person! CMart 1 Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted October 14, 2015 Report Share Posted October 14, 2015 Yes! Was it the pin connector thing ? Quote Link to comment Share on other sites More sharing options...
straight6pwr Posted October 14, 2015 Report Share Posted October 14, 2015 sweet! also cant wait to see it CMart 1 Quote Link to comment Share on other sites More sharing options...
CMart Posted October 14, 2015 Author Report Share Posted October 14, 2015 Yes: The two green wires needed 12v. One to activate the fuel pump relay, red/white wire, (which I was using a go around for) and the other to turn the ECU on. Black is starter which is hooked up to the C101. Ordered a huge Z3M 3 row mishi last night to keep it cool. Hoping to get it on the road Sunday and have the bugs worked out for the fall meet. Quote Link to comment Share on other sites More sharing options...
ClassE Posted October 14, 2015 Report Share Posted October 14, 2015 Awesome - glad you got this running! CMart 1 Quote Link to comment Share on other sites More sharing options...
CMart Posted October 14, 2015 Author Report Share Posted October 14, 2015 Me. Fn. Too. Quote Link to comment Share on other sites More sharing options...
CMart Posted October 19, 2015 Author Report Share Posted October 19, 2015 She moved under her own power today. All of 2 feet, but happy with the progress. Video of it running in better light: KaiserRolls 1 Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted October 19, 2015 Report Share Posted October 19, 2015 I know those feels. I hope to see the car this weekend! Quote Link to comment Share on other sites More sharing options...
CMart Posted October 19, 2015 Author Report Share Posted October 19, 2015 I really want to. I've got a lot of work to do before making a drive that far, but that is definitely the goal. Quote Link to comment Share on other sites More sharing options...
Bassboy3313 Posted October 19, 2015 Report Share Posted October 19, 2015 Nice work man! One step closer is always a good feeling Quote Link to comment Share on other sites More sharing options...
CMart Posted October 21, 2015 Author Report Share Posted October 21, 2015 Alternator is pumping out energy now, not leaking a drop of anything, motor running smooth, and making progress on some of the data going to the cluster. Bad news, mainly is the brakes sink to the floor and don't come back up. Im thinking it could be A. air in the lines. B a bad master cylinder (no leaking though) or C the spring to return the E30 brake isn't strong enough for the new setup. Other than that small stuff and busy work getting the car put back together. Quote Link to comment Share on other sites More sharing options...
straight6pwr Posted October 21, 2015 Report Share Posted October 21, 2015 obviously you havent driven the car, but can you tell if the brakes are engaging? does the pedal build pressure or does it just go flat to the floor? are you sure the return spring on the remote booster setup is in the correct position? all hinge points on the remote setup greased and not binding? i dont know if this helps, but when we picked up the junk e34, the brake pedal did not have an issue (rock solid when the car was not running, and we used the brakes for moving the car around) so hopefully that eliminates the master cylinder from your list of possibilities. although i recall paint missing from a leak near the front of the booster, but that probably was the seals to the reservoir. Quote Link to comment Share on other sites More sharing options...
CMart Posted October 21, 2015 Author Report Share Posted October 21, 2015 Car is running. I just didn't feel comfortable leaving my driveway so I have it some power and hit the brake. It seemed to build pressure at the end - car stopped by using the brake barely - but was at the very end of travel and didn't return. If I am recalling correctly I had no problem with the brake before fluid. I could hit the brake and it would return. That was me just seeing if the linkage was working. Spring is installed on booster bracket correctly and I can't spot any binding. Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted October 21, 2015 Report Share Posted October 21, 2015 Try rebleeding. I like to hit the easy stuff first Quote Link to comment Share on other sites More sharing options...
CMart Posted October 21, 2015 Author Report Share Posted October 21, 2015 Yep, that is the plan for tonight. If that doesn't work check the inside of the booster for fluid as I believe that is where it could be leaking? My brakes are turning into a project of their own. I am waiting to install my coils to install the BBK and I want to clean up some of the plumbing. I am hoping to get it running as is, then take it down for a weekend or over winter and get everything how I want it. Quote Link to comment Share on other sites More sharing options...
CMart Posted October 21, 2015 Author Report Share Posted October 21, 2015 Also, I need to make sure all my return springs are there and linked where they should be. I have one in place, not sure if there is supposed to be another. Quote Link to comment Share on other sites More sharing options...
B C Posted October 21, 2015 Report Share Posted October 21, 2015 Is this a hydroboost setup? sorry, I didnt search through the thread/couldnt remember Quote Link to comment Share on other sites More sharing options...
CMart Posted October 21, 2015 Author Report Share Posted October 21, 2015 Remote booster setup. E34 v8 I believe. Also, sent for the plates today. Went with "V 80 30" Quote Link to comment Share on other sites More sharing options...
Earl Posted October 21, 2015 Report Share Posted October 21, 2015 Clever=) Quote Link to comment Share on other sites More sharing options...
straight6pwr Posted October 21, 2015 Report Share Posted October 21, 2015 Also, I need to make sure all my return springs are there and linked where they should be. I have one in place, not sure if there is supposed to be another. i can take pictures of mine if you need them for comparison. Quote Link to comment Share on other sites More sharing options...
CMart Posted October 21, 2015 Author Report Share Posted October 21, 2015 I meant E30. I'm confident my remote linkage is there. Without being hooked up to hydraulics it all works. Quote Link to comment Share on other sites More sharing options...
CMart Posted October 23, 2015 Author Report Share Posted October 23, 2015 Quote Link to comment Share on other sites More sharing options...
wasnt m3 Posted October 23, 2015 Report Share Posted October 23, 2015 Hell yes. Nice work! CMart 1 Quote Link to comment Share on other sites More sharing options...
