Jump to content
E21 Project Thread - Part 2
There is still quite a bit I need to check over from previous "rush" jobs. I want to fix the exhaust leak at the manifold, fuel leak at the feed connection point, and definitely look to see how I can redo the lower hose routing. All this on top of finishing up the rear end. Then of course body work and group 2 kit install. Oh and I will need to see if I will have to redo the exhaust or not.
Link to comment
Share on other sites
  • 2 weeks later...
Motorsport hardware studs installed in rear hubs. CV axle hardware cleaned and installed with a shit ton of locktite. Better not come out again. Rear rotors resurfaced and installed along with calipers. Rear brakes bled. And test fit of new wheels. Guess I didn't account for the negative camber when calculating fitment with flares. Will have to see what is needed after car is on ground.
451ed5d330bfdd27080a3b555d000f4e.jpg675dba715c95a028ce7b679e292460c0.jpg9f184e92607635e33ee5936467a8241e.jpge12c21d7d7c1d7d544a5e24780d885a4.jpgafb65e90ecac15939f3ce50d80861b36.jpg8b11ced436ceb3105c12c4e4c144dd93.jpg45573f733c7b8805e92ba113a9ee952d.jpg
Link to comment
I originally thought these would do the trick. They are 15x9 with -15 offset. I guess I just didn't take the excessive camber into account. I flipped the subframe mounts which brings it higher up into the chassis, helped the camber slightly. I just ordered some camber adjustments to weld in to dial out a little more. If I have to run a small spacer so be it. My motorsport hardware studs have the room for spacers so that wouldn't be an issue.
Link to comment
uggghhh that looks annoying. Mostly because mine is all painted and its seems yours is too.. Please get someone to help you put it back in the car. I know all to well how annoying it is by yourself on the ground. [emoji20]
It wasn't that bad at all. The nice thing about the e21 is that the subframe mounts unbolt from the subframe. So I install the mounts on the frame studs loosely. Then roll assembly underneath, jack it up and bolt the subframe to the mounts after getting them lined up.
The thing I'm running into now tho is that with the subframe mounted, jacking up the diff puts it at an angle that the mount arms I welded on the car doesn't like. Somehow I need to pull the rear side of mounts towards rear of car about an 1/8th for the diff cover to clear them. I'm thinking maybe rent a slide hammer from AAP and give it a few whacks. That's my best idea. 837f5c777df364622af5e59c78454066.jpg
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Create New...
Important Information
