swiper Posted March 16, 2022 Report Share Posted March 16, 2022 Nice work Jason! Jdesign 1 Quote Link to comment Share on other sites More sharing options...
Jdesign Posted March 22, 2022 Author Report Share Posted March 22, 2022 Wel, Ive still been plugging away at this. Lots of issues ordering the right parts, and fabrication to make everything work the way I want. The steering column has proved itself to be one hell of a pain in the ass. Partially my fault, but partially not. The latest issue was that the original shaft i ordered was roughly 4" too short. I knew it was going to be close, but when I placed my order, the option was 16" shaft or 48" which was way more expensive. I happened to find a shaft on ebay that was 48" for the same price as the 16" I bought. It showed up and as I should have expected it was a "oversized" part. apparently the supplier messed up and made a few thousand shafts 1m bigger than 3/4" and thats how the description read, but not the listing title. UGHH I ended up machining the D shaft down and cut it to length. Here is what I got: Here is what it should have been: After that bummer, I kind of hit a dead end for the steering and brakes until I got the column mounted. I needed to make sure the angle was correct, so that once I machined the shaft and cut it down, it was a good fit. This literally took days of cutting, welding, and measuring. I didn't take any pictures, but I will be adding some eventually. Once I get the column in and everything mocked up, I will be cad modeling a new steering column bracket based on my dimensions and getting parts from Sendcutsend to weld it all together. (unless someone has access to a laser or water jet?) So I started pulling the engine harness. I forgot how simple and easy this harness was. It might look like a mess, but it took me about 20mins to have everything out and on the workbench. I cant wait to build a new harness for this thing. So once I had the harness out, my main objective was to figure out what Mil-spec firewall plug I would need. I had to figure out how many wires would pass through the plug, and plan for any possible updates as these plugs are expensive. I geeked out and spent a good weeks worth of time reading this site: https://www.rbracing-rsr.com/wiring_ecu.html and researching and ordering materials for building the harness. I HIGHLY recommend reading through that site, as it has tons of information on building high quality wiring harnesses. Here is some of the stuff I ordered: Ty-rap metal tab'd not marring zip ties Full 1jz plug kit. this has every connector I need with pins and gaskets Kapton antistatic tape in various sizes Magnetic polymer magnetic jaws for my vise to use while spinning the leads Zip Tie Mounts for laying out the harness Nylon coated wire for temp tying wire bundles Deutsch DTM 12 Pin Connector for my injector harness ( I plan to upgrade later and this will allow me to without having to rebuild the harness 61 way Mil-Spec connector kit with plug/receptacle connectors , shrink boots and shrink boot adapters. Finally as of today my firewall support bearing for my steering shaft showed up, and it the last part I needed to check the steering off of the list. Due to using dual U-joints for my steering, a support bearing is needed to prevent binding. In addition to that, this will also help seal the hole in the firewall that the shaft passes through. gilber33, Rekpoint and KaiserRolls 3 Quote Link to comment Share on other sites More sharing options...
gilber33 Posted March 22, 2022 Report Share Posted March 22, 2022 I used the same type of steering joint from Condor (I think you actually sent me the link when I had found the stock one was all bound up) and that came the same way. I had to very carefully remove some material from it so it could slide together. Super annoying for a $300 part. And SendCutSend is who I have been using for all of my headlight parts. They're awesome and have been so helpful when I had issues exporting DXF files. Jdesign 1 Quote Link to comment Share on other sites More sharing options...
Jdesign Posted March 23, 2022 Author Report Share Posted March 23, 2022 19 hours ago, gilber33 said: I used the same type of steering joint from Condor (I think you actually sent me the link when I had found the stock one was all bound up) and that came the same way. I had to very carefully remove some material from it so it could slide together. Super annoying for a $300 part. And SendCutSend is who I have been using for all of my headlight parts. They're awesome and have been so helpful when I had issues exporting DXF files. I have heard nothing but good things about them! Quote Link to comment Share on other sites More sharing options...
Jdesign Posted May 10, 2022 Author Report Share Posted May 10, 2022 Still fighting this car as much as I can. As of yesterday, I think I can say the steering is complete. Sadly, I needed to add a secondary support bearing closer to the double D joint as it would bind under certain conditions. To do this meant I could no longer use the shaft that I had machined down and had to get yet another D shaft. Luckily I had a friend with a spare sitting in his shop that was the right size and length, and was also chrome plated. I was able to mount everything where it needed to be, and welded a new bracket to the pedal box bracket for the new support. After that I added an additional bracket to the column as well to replace the factory support under the dash cluster. This last bracket made everything much much stronger. Finally the steering "inside" the car is done. If you look close here you can see the L bracket right at the back of the column that would make that final rigid support. The next thing I needed to attack was getting all the bulkheads in the firewall and the braided brake lines ran. Most of these were already routed earlier, but I will need to add adel clamps so they aren't flying around. One that I did not install was the clutch line. I was waiting to do this as I wanted to hide most of the bulk heads and this one was near the steering shaft and the throttle. I had to complete these in order to prevent any more redos. So first up I had to modify the throttle for the pedal box. The throttle beam and cam is made of aluminum, and the pivot travels behind the steering shaft and the brake pedals. The cable from factory exits just above where the clutch pedal is, and with the new pedal box, this needs to be moved. I cut the cable arm right above the factory stop to maintain the correct pedal height, and added material approximately the same height directly above the throttle pedal itself. This would allow the cable to be located closer to the center of the engine bay and directly inline with the throttle body. I was able to reduce the length of the cable by about 12" with this alteration! What I didn't expect was that with the cable location to the cam profile on the pedal, was that I now would need about an extra 2-4" of leverage from the fulcrum to completely open and close the throttlebody. So my solution was a billet aluminum lever from a cheap hydro that I could make an adjustable extension. This worked perfect, and actually made everything much more sturdy. Finally I ran the clutch line bulkhead right below the heater core lines beside the throttle. The angle of the picture below gives you an idea on the location, and also how tightly everything fits together. Note the cable at the top of the lever and the space on either side as it passes through when the throttle is depressed. On the exterior of the steering issues was something I didn't mention previously. The new Wilwood rotors sat much further inward to the hub and were very close to the heatshields. So close in fact that with the factory tie rods installed, the boots pushed the shields into the rotors and would cause them to rub. I tried to get different tie rods and even shave them down, but that didn't help. I then bought an cheap angle kit like the one on my E36 to move the pivot inward and away from the rotor. The kit I bought didn't quite fit the hubs I have, so I had to mill them down on the Bridgeport. This was a fail, as even after machining them, I would need additional spacers on the brackets and special hardware. Ultimately I caved and bought a bump steer kit that uses Heim joints in place of the tie rods that allowed me the extra space. I figured these will also help with bumpsteer (duh) and the car being so low and not having power steering anyways. See failed E36 bracket below And the MRT bumpsteer kit installed. Note the space between the heatshield and rotors. Next is wiring. I started, but its nothing worth mentioning just yet. Fingered Crossed for the Picnic! P_Roloff, m42b32 and pynacl 3 Quote Link to comment Share on other sites More sharing options...
Jdesign Posted March 22, 2023 Author Report Share Posted March 22, 2023 P R O C R A S T I N A T I O N Yeah so I didn't really work on the harness. BUT! I have accomplished some other things. I had Tim come by and 3D scan my engine bay which was a pretty neat ordeal. I wanted to get a CAD file of my engine bay and hardtop for reference files to allow me to create models for reinforcing my firewall, filler panels to give the bay more symmetry, and the hardtop to build a jig for the Lexan. Tim also traded in his F90 M5 Comp for a G20 M340 and he wanted to swap grills right away. So for fun, this is what 7th gen 3series grills look like on a second gen 3series E30. Anyways I also got around to ordering and installing some more parts. I finally finished up relocating the fuel lines because of the steering shaft / starter interference. I unfortunately think I will end up redoing these lines because they are still factory 8mm -5/16 hardlines up until they get to the bottom of the firewall where I adapted them to braided -6AN that goes to the fuel rail and regulator. I think that once I get the car running again and start tuning I will add more fuel and boost, and the 8mm factory lines will limit my flowrate. But for now, its good till I cross that bridge. (Sorry I have no pictures of this)^^ I also ordered everything needed for the remote oil cooler. I got a Chase Bays thermostatic oil cooler wedge plate, HKS filter, -10 fittings (x2 45's| x2 60's), way too much -10 braided line, and I had a cooler that Chubs made a few years ago. I was debating on the line routing, but after I made the lines, it seems like both options I was considering will work if I need to move the lines up in the future. Option 1 Option 2 The result And I also painted the far edge of the oil cooler as I didn't want the offset of the cooler to throw off the factory look of the car through the kidneys. Also not shown, I installed a new oil pan as the one I had was dented since I got it. With that, I also started to reroute my dipstick as it is one of the biggest sys sores in the engine bay IMO. I got about 90% done making a new dipstick, and wasn't sold on how it looked, so I ordered a Lokar locking flexible billet dipstick that I will mount down near the cooler oil filter and out of the way. Besides that, I feel pretty good and the oil system is all buttoned back up! My next task is going to install the stereo and get that out of the way. I have everything besides drivers and I want to get all the chassis side of the wiring complete before( warning: procrastination excuse) I move onto the engine harness. P_Roloff and KaiserRolls 2 Quote Link to comment Share on other sites More sharing options...
GunMetalGrey Posted March 28, 2023 Report Share Posted March 28, 2023 It's things like painting the edge of the oil cooler to maintain visual symmetry that I love. Looking good! Jdesign 1 Quote Link to comment Share on other sites More sharing options...
Jdesign Posted March 29, 2023 Author Report Share Posted March 29, 2023 On 3/28/2023 at 2:17 PM, GunMetalGrey said: It's things like painting the edge of the oil cooler to maintain visual symmetry that I love. Looking good! Thanks! Its hard for me to keep looking at everything in a "temporary" sense as I just want to get it all built, but at the same time I'm so distracted by such minimal details. I really just want to be at the testing / finalizing phase so I can tear it all back apart for the 3 P's; paint, powdercoat, and plating. Quote Link to comment Share on other sites More sharing options...
Jdesign Posted April 18, 2023 Author Report Share Posted April 18, 2023 I went a little backwards a few days ago and tore out most of the interior. I was hesitant but it kind of needed to be done sooner or later. I really want to pull the carpet, but that might be too far at this stage. The plan was to hunt down the factory speaker wires and remove them due to the car having premium sound, and upgrade to standard +/- speaker wire that all heads to the back seat of the car. I managed to remove everything needed and cleaned up unused wires for who knows what previously. I ordered a full Infiniti reference component set to replace all the speakers and tweeters. Man I had no idea the factory tweeter housings were so expensive for what they are ($150 a side!?) I carefully removed the old tweeter which was glued in really well and mocked up the new ones. Sadly as I was about to trim the housing my rotary tool died, so I ordered a new one and didn't get to finish last night. I moved onto the head unit area which I think I mentioned before, but I will not be running a head unit, as my amp connects directly to my phone. So I ordered a single din storage tray/ dual cup holder combo to fit in its place. This was the only one I could find that I knew would fit and wasn't overly complicated. I wasn't please with the quality as it felt cheap and the trays pulled out loosely and uneven as there are no guides/ slides for the drawers. I fixed this by adding felt to the inside edges of the drawers which completely changed the feeling of them. This made such a huge difference. I also added some green felt inside the drawer to class it up a bit. That's all for now until I finish the tweeters and get the amp mounted. I plan on building an enclosure in the void between the rear seat and the trunk for a sub eventually, but for now this is a huge improvement. Quote Link to comment Share on other sites More sharing options...
