So, this has happened a few times, but not in awhile. Previously, I figured out that the problem was a loose fuel line clamp on the top of my fuel tank under the back seat. If I park on just the right angle or slope, my car would have a difficult time firing. It would turn over fine, but just keep cranking with a little sputter here and there. If I would wait a minute or two and try again, sooner or later it would fire, and once it was running, it would be fine.
I fixed the fuel line and haven't had a problem since.....SINCE today. I was pretty low on fuel and when I started my car this morning, it took a few extra cranks to fire. I thought maybe is was because my car was on E. So I drove to the gas station, shut it off and filled it up. Got back in, crank it and a few sputters and nothing. Awesome.
So I sat there for a few minutes. My car was at that perfect slope at the pump. Crap. So I tried again and it fired a little more but then died and showed no further signs of firing. So I sat there and thought to myself thinking; did my fuel pump just die? Well what else is there?
FUEL
-Relay -OEM
-Pump -OEM (I think)
-Filter -New
SPARK
-plugs -New
-wires -Old as shit :/
-cap/rotor -New
So I got out, pulled the relay for the FP out and cleaned it off with what I had. ( a towel ) I put it back in, and tried again. The car cranked and slightly fired. I stopped, pumped the gas while cranking again, fired right up. So....
I assume the relay is bad, but can anyone confirm this is my actual problem? Or could it actually be the pump, and for some reason the time it sat there while I cleaned the relay allowed it to work again? I have a new pump and I will be buying a new relay regardless.
Question
FUEL
-Relay -OEM
-Filter -New
SPARK
-plugs -New
-cap/rotor -New
Link to comment
Share on other sites
13 answers to this question
