REKIII Posted August 26, 2019 Report Share Posted August 26, 2019 Updates without pics are like.....well, I don't know what they are like, but they suck. Do better. Jdesign 1 Quote Link to comment Share on other sites More sharing options...
Jdesign Posted August 27, 2019 Author Report Share Posted August 27, 2019 11 hours ago, jc43089 said: They make more valves every day. FACT. Quote Link to comment Share on other sites More sharing options...
Jdesign Posted August 27, 2019 Author Report Share Posted August 27, 2019 10 hours ago, REKIII said: Updates without pics are like.....well, I don't know what they are like, but they suck. Do better. I agree. I will do better next time. REKIII 1 Quote Link to comment Share on other sites More sharing options...
Jdesign Posted August 28, 2019 Author Report Share Posted August 28, 2019 Just for @REKIII I started this for the first time in many months. It made the craziest noises from the fuel tank, but fired right up first try. It was slightly motivating (Note the pile of parts on the roof waiting to be installed) And the video isn't uploading Can't do better due to technical difficulties. REKIII 1 Quote Link to comment Share on other sites More sharing options...
SteelBlue Posted August 28, 2019 Report Share Posted August 28, 2019 Can we expect to see this at RA again? Quote Link to comment Share on other sites More sharing options...
Jdesign Posted August 29, 2019 Author Report Share Posted August 29, 2019 17 hours ago, SteelBlue said: Can we expect to see this at RA again? I cant make any promises. Quote Link to comment Share on other sites More sharing options...
SteelBlue Posted August 29, 2019 Report Share Posted August 29, 2019 6 minutes ago, Jdesign said: I cant make any promises. Can we expect to see you at RA again? Quote Link to comment Share on other sites More sharing options...
straight6pwr Posted August 29, 2019 Report Share Posted August 29, 2019 On 8/23/2019 at 2:14 PM, Jdesign said: I haven't updated this in awhile, but I figured I could do a check in. I have a mound of parts to install in this car and haven't had time to touch it. BUT since Halloween is right around the corner, I might need to get this thing on the road again, as it's perfect for the holiday. I did manage to finally find a cam that I will use with the gear drive. It's a Comp cams camshaft spec'd at 236/242, .363"/.361" lobe lift and cut on a 111+4 lsa. I am not 100% if it will work, but I mean, what's the worst thing that could happen? smoke machine? Quote Link to comment Share on other sites More sharing options...
Jdesign Posted August 29, 2019 Author Report Share Posted August 29, 2019 4 hours ago, SteelBlue said: Can we expect to see you at RA again? See last response; 5 hours ago, Jdesign said: I cant make any promises. 4 hours ago, straight6pwr said: smoke machine? Quote Link to comment Share on other sites More sharing options...
Jdesign Posted September 26, 2019 Author Report Share Posted September 26, 2019 Did a thing last night and its closely relates to this car. Some of you may have already saw this posted on my snapchat (jhenrysnapp if you're a snapchatter) yesterday, but I have been cleaning and moving things in my shop and decided to get the old tires off of the spare style 5's and mount the new tires on. There is still a large amount of work to be done before I can actually mount the wheels on the car, but I was able to remove the tires, and install the new ones and flip the faces and the outcome was quite satisfying. OEM back pad and barrel Flipped face and semi cleaned barrel New tire installed on flipped face wheel A video of the wheel next to the car: PLFW0312.MP4 Quote Link to comment Share on other sites More sharing options...
SteelBlue Posted September 26, 2019 Report Share Posted September 26, 2019 bruh Jdesign 1 Quote Link to comment Share on other sites More sharing options...
Jdesign Posted September 26, 2019 Author Report Share Posted September 26, 2019 2 minutes ago, SteelBlue said: bruh Im sorry, is there something wrong? Quote Link to comment Share on other sites More sharing options...
straight6pwr Posted September 26, 2019 Report Share Posted September 26, 2019 how did you attempt to center the face? that could be a lot of wobble with such a heavy tire! Quote Link to comment Share on other sites More sharing options...
Jdesign Posted September 26, 2019 Author Report Share Posted September 26, 2019 3 hours ago, straight6pwr said: how did you attempt to center the face? that could be a lot of wobble with such a heavy tire! It self-centered 🤪 Quote Link to comment Share on other sites More sharing options...
straight6pwr Posted September 27, 2019 Report Share Posted September 27, 2019 10 hours ago, Jdesign said: It self-centered 🤪 i've had a set of these in hand and thought it might be iffy, since the centering lip is on the face side, and the splined bolts are a loose fit into the holes on the face. did you mount the wheels on the car and give em a spin to check for run out? Quote Link to comment Share on other sites More sharing options...
Jdesign Posted September 27, 2019 Author Report Share Posted September 27, 2019 10 hours ago, straight6pwr said: i've had a set of these in hand and thought it might be iffy, since the centering lip is on the face side, and the splined bolts are a loose fit into the holes on the face. did you mount the wheels on the car and give em a spin to check for run out? I know what you mean about the lip on the front of the face, BUT the overall diameter of the face also fits tightly inside of the barrel. So tight, I had to pound it back together with a 6x6 and all my might to get it tight. If you look, you can see I left the bolts in their place so that the nuts are on the "new face side." I did this because the bolts are splined, tapered, shouldered, and press tightly into the barrel before passing through the face. Leaving them in this orientation was the best (technically only) option for a secure hold, and the shouldered portion of the bolts also aided in alignment of the face. I did not mount them on the car, BUT I did mount them on my tire balancer to testy runout and they spin true for the most part, but the tire is a hell of a lot of meat, and I might run balancing beads instead of wasting a ton of sticky weights. (Sorry for portrait mode, this is from snapchat) UIJW7639.MP4 Quote Link to comment Share on other sites More sharing options...
straight6pwr Posted September 27, 2019 Report Share Posted September 27, 2019 nice! i thought that there was a gap around the face from the barrel, but I'm probably mistaken. these will be hilarious when mounted. please put a cat or a $100 bill inside the barrel to exaggerate the size of the lip, like when deep flat lips were a thing. Quote Link to comment Share on other sites More sharing options...
REKIII Posted September 27, 2019 Report Share Posted September 27, 2019 Dude.....language. Had to have a meeting with HR after watching the vid. Awesome wheel/tire combo though. Totally worth it. Quote Link to comment Share on other sites More sharing options...
Jdesign Posted September 27, 2019 Author Report Share Posted September 27, 2019 1 hour ago, REKIII said: Dude.....language. Had to have a meeting with HR after watching the vid. Awesome wheel/tire combo though. Totally worth it. OOPPPPPEEE REKIII 1 Quote Link to comment Share on other sites More sharing options...
Jdesign Posted December 16, 2019 Author Report Share Posted December 16, 2019 SO.... Did a lil test fitting this weekend... NOW.... mind you this is at lowered height, no lift, no cutting. With the jack under it I get about 3" of droop and the wheel spins freely. I think with the lift I should be able to clear everything up front. I will just need to trim the bumper and I should be okay. I have yet to test the rear, and I will be a little concerned with running into the subframe mount. REKIII 1 Quote Link to comment Share on other sites More sharing options...
REKIII Posted December 16, 2019 Report Share Posted December 16, 2019 Wow. Now, I agree that from a utility standpoint, this wheel/tire combo will be much better, but I'm still on the fence aesthetically. I'm excited to see how the final stance (I hate myself for using that word) will be. Very cool. Jdesign 1 Quote Link to comment Share on other sites More sharing options...
Jdesign Posted December 16, 2019 Author Report Share Posted December 16, 2019 So I ran across this today now.... which gives me a lot of hope that this will work just fine! B C 1 Quote Link to comment Share on other sites More sharing options...
B C Posted December 17, 2019 Report Share Posted December 17, 2019 It took a beating pretty well! Are those wheels custom built? Quote Link to comment Share on other sites More sharing options...
Jdesign Posted December 20, 2019 Author Report Share Posted December 20, 2019 On 12/16/2019 at 8:08 PM, B C said: It took a beating pretty well! Are those wheels custom built? Which wheels? Quote Link to comment Share on other sites More sharing options...
Jdesign Posted February 18, 2020 Author Report Share Posted February 18, 2020 Not much to look at but I made a little progress on this. Cleaned up the new subframe, painted it and installed new bushings. I also removed the trailing arm bushings and ordered new Ball joints for the trailing arms. I will be painting the swing arms next before installing all the new stuff. I still need to order new brakes for the rear, but then should have everything to complete the rear end swap/upgrade. Quote Link to comment Share on other sites More sharing options...
