Whats up WI Bimmers, my name is Tyler and I own a fabrication shop called The Arc Asylum. I primarily make swap parts for E30's.
A guy in Germantown had me do some work on his E30 M3 2 years ago and it turned into me doing swap modifications so guys can run rear sump dual pickup s54 pans after the pan and subframe is modified. I also modify E36 rear sump pans so you can run an M/S 50/52 with a rear pickup. In addition I make an aluminum 6 speed trans mount and am in the process of putting together an LS kit and S54 swap header.
In the next year I will be into a bigger facility and taking on larger projects. The business is a sideline for me, but I strive to put out the best work I can.
Question
Guest TheArcAsylum
Here are some pictures of what I have been doing
http://desmond.imageshack.us/Himg401/scaled.php?server=401&filename=img0914o.jpg&res=landing
http://desmond.imageshack.us/Himg571/scaled.php?server=571&filename=img0917aw.jpg&res=landing
http://desmond.imageshack.us/Himg252/scaled.php?server=252&filename=img0918jj.jpg&res=landing
Here is a teaser of an M3 cage I am doing
Link to comment
Share on other sites
6 answers to this question
