I suppose the only way to get a definitive answer here will probably be to test it myself, but I thought I'd ask anyway.
I have to admit that , until my recent research into injectors, I never knew what the vacuum line on the fuel pressure regulator was even for, so I guess I'll explain it to make sure we're all on the same page and there aren't any details I'm over-looking.
The regulator itself is more or less a valve with a spring holding it shut. Fuel enters the regulator on one side of a diaphragm and the spring is on the other. Once the pressure reaches the set-point, the force pushing on the diaphragm is greater than the spring force. This causes it to move and opens the valve which allows fuel to flow out the return line.
This is all well and good, but the fuel injectors are located inside the intake manifold, not hanging out in free air. If the fuel pressure stays constant relative to atmospheric pressure, then the pressure seen at the injector nozzle will increase as vacuum builds in the manifold and decrease when the manifold is exposed to boost pressure. The vacuum from the intake manifold is connected to the opposite side of the regulator's diaphragm as the fuel pressure. As vacuum increases the valve is opened farther, and fuel pressure is kept constant relative to manifold pressure, not atmospheric pressure.
My initial thought was that the stock fuel pressure regulator was never designed to handle boost, and would have to be replaced. After learning how these things work, I can't see any reason why the regulator would perform any differently with boost pressure versus vacuum so long as the case can hold the pressure and something is done to keep the manifold reference line from popping off...
Question
Thoughts? Hearsay? TL;DR?
Link to comment
Share on other sites
6 answers to this question
