MattY Posted August 1, 2017 Author Report Share Posted August 1, 2017 real talk though i'll stop shitting up the group chat and get my m50(b25tu) maintenance sorted out here. currently todo: head gasket vanos seals, rattle repair kit (besians) thermostat housing replacement hydraulic alternator tensioner conversion upgraded oil pump shaft (achilles) reinforce oil pick-up (also achilles) thermostat and water pump / pulley are replaced already. am i missing anything big? motor has 140-160 on it iirc Quote Link to comment Share on other sites More sharing options...
m42b32 Posted August 1, 2017 Report Share Posted August 1, 2017 Jdesign, MattY, Earl and 2 others 5 Quote Link to comment Share on other sites More sharing options...
B C Posted August 1, 2017 Report Share Posted August 1, 2017 Which trans are you using? I see the M20 flywheel. I am still extremely skeptical about all this nonsense people spout off online about the M20 flywheel hitting the block. Im not seeing it. I see the upgraded oil pickup tube. Are you using a rear-sump oil pan? Quote Link to comment Share on other sites More sharing options...
MattY Posted August 1, 2017 Author Report Share Posted August 1, 2017 G260 with the sachs m20 clutch kit (https://www.ecstuning.com/b-sachs-parts/clutch-kit/21211223102~sac/), I've got the trans brace from ben already. i have an e34 oil pan but i personally wouldn't know if that's rear sump, haven't ordered the oil pump parts so no worries if I screwed up. Quote Link to comment Share on other sites More sharing options...
B C Posted August 1, 2017 Report Share Posted August 1, 2017 E34 is front sump, all others are rear sump Quote Link to comment Share on other sites More sharing options...
MattY Posted August 1, 2017 Author Report Share Posted August 1, 2017 Just now, Snap said: E34 is front sump, all others are rear sump on the bright side, looks like ya boy here gets to save $60. should i be okay with just the oil pump upgrade? Quote Link to comment Share on other sites More sharing options...
B C Posted August 1, 2017 Report Share Posted August 1, 2017 Yes MattY 1 Quote Link to comment Share on other sites More sharing options...
