pynacl Posted November 24, 2021 Author Report Share Posted November 24, 2021 29 minutes ago, KaiserRolls said: Will the replacement shocks need to be revalved for the spring rates? Or are they an off the shelf setup Yeah they are custom valved to the springs. I did give the spring rates to TCK when ordering, so hopefully the replacements are an exact match. Honestly not sure how to confirm or deny that though Quote Link to comment Share on other sites More sharing options...
pynacl Posted November 27, 2021 Author Report Share Posted November 27, 2021 Got the new shocks from TCK already! Time to swap the GC camber plates on and get these installed. Still not sure if the factory end links will fit. If not, maybe that'll be an excuse to replace them and upgrade front sway bar too. Jdesign and Rekpoint 2 Quote Link to comment Share on other sites More sharing options...
patsbimmer1 Posted November 28, 2021 Report Share Posted November 28, 2021 22 hours ago, pynacl said: Got the new shocks from TCK already! Time to swap the GC camber plates on and get these installed. Still not sure if the factory end links will fit. If not, maybe that'll be an excuse to replace them and upgrade front sway bars too. I'd suggest going with a shortened or adjustable sway bar link. The stock ones are made for the stock height. You're going to change the pre-load on the sway bar and could impact your handling if you stick with the stock sway bar links and lowered height. Rekpoint and pynacl 2 Quote Link to comment Share on other sites More sharing options...
Rekpoint Posted November 28, 2021 Report Share Posted November 28, 2021 3 hours ago, patsbimmer1 said: I'd suggest going with a shortened or adjustable sway bar link. The stock ones are made for the stock height. You're going to change the pre-load on the sway bar and could impact your handling if you stick with the stock sway bar links and lowered height. https://groundcontrolstore.com/collections/e46-m3-sway-bars/products/bmw-front-sway-bar-end-link-adjustable-pair Quote Link to comment Share on other sites More sharing options...
Bassboy3313 Posted November 29, 2021 Report Share Posted November 29, 2021 1 hour ago, Rekpoint said: https://groundcontrolstore.com/collections/e46-m3-sway-bars/products/bmw-front-sway-bar-end-link-adjustable-pair Just know that heim joint sway links can be noisy. So if that doesn't bother you, go for it! I have them on my Z3 Coupe and will be switching them out for some adjustable ball joint style sway links to quiet things down. Just an FYI pynacl 1 Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted November 29, 2021 Report Share Posted November 29, 2021 2 hours ago, Bassboy3313 said: Just know that heim joint sway links can be noisy. So if that doesn't bother you, go for it! I have them on my Z3 Coupe and will be switching them out for some adjustable ball joint style sway links to quiet things down. Just an FYI He won’t hear it over the Ed Sheeran he listens to Rekpoint, Bassboy3313, YoungCR and 2 others 5 Quote Link to comment Share on other sites More sharing options...
pynacl Posted November 29, 2021 Author Report Share Posted November 29, 2021 On 11/28/2021 at 1:57 PM, patsbimmer1 said: I'd suggest going with a shortened or adjustable sway bar link. The stock ones are made for the stock height. You're going to change the pre-load on the sway bar and could impact your handling if you stick with the stock sway bar links and lowered height. Honestly fairly new to the intricacies of suspension tuning so I reached out to TC Kline and got this response Quote Just so you know our take on the situation... We have never put adjustable end links on any of our track cars(specifically our E90 M3 track car). If your car is set to the appropriate ride height (equal on the left and right side) there is no need for adjustable end links. The only time you will put 'pre-load' on the sway bar is when the left and right ride heights are not set equal (and there is no reason they should be unequal). I could see how adjustable links could come into play with corner balancing, but I've also read BMWs are pretty well balanced from the factory. I'll definitely do my best to test out all this info and report back though! patsbimmer1 1 Quote Link to comment Share on other sites More sharing options...
pynacl Posted November 29, 2021 Author Report Share Posted November 29, 2021 Waiting on some suspension parts yet so I started the header install. Have to say that this is MUCH harder than the downpipe install on my F30. Since there's such limited room to work I had to remove the coolant reservoir tank, turkey basting out all the coolant so I didn't make an absolute disaster. Still probably spilled 1/2 gallon on the floor that came out the other end though lol. Even with this and the heat shielding out of the way, access to the 18 nuts is still pretty grueling. Just kept swapping out swivel, wobble and regular extensions, as it seems like each nut requires a different approach. After a few hours I finally got the old set out, woohoo! Still waiting on new gaskets and nuts, but should be here in about a week or so and I can get the new headers installed. Rekpoint, P_Roloff and m42b32 3 Quote Link to comment Share on other sites More sharing options...
patsbimmer1 Posted November 30, 2021 Report Share Posted November 30, 2021 16 hours ago, pynacl said: Just so you know our take on the situation... We have never put adjustable end links on any of our track cars(specifically our E90 M3 track car). If your car is set to the appropriate ride height (equal on the left and right side) there is no need for adjustable end links. The only time you will put 'pre-load' on the sway bar is when the left and right ride heights are not set equal (and there is no reason they should be unequal). If that's what they say then I'd go with that! I know when KW sent me my coilovers they came with a new set of shorter sway bar end links to avoid the pre-loading and I know others that do it as well. I'm sure it's like everything else handling related where it's heavily opinion based on independent results. If it works it works! pynacl 1 Quote Link to comment Share on other sites More sharing options...
Jdesign Posted November 30, 2021 Report Share Posted November 30, 2021 In the future I would suggest invest in an Airlift. You can suck all the coolant out of the system without spilling much. As far as getting to the manifold bolts, I feel your pain. lol pynacl 1 Quote Link to comment Share on other sites More sharing options...
pynacl Posted December 4, 2021 Author Report Share Posted December 4, 2021 Replaced the CPV o-ring with a viton one while I was waiting on parts to finish the headers. It wasn’t leaking, but seems like a PITA to replace later. While in there I noticed the cam position sensor is leaking a bit. Death by 1000 gaskets… Rekpoint 1 Quote Link to comment Share on other sites More sharing options...
Rekpoint Posted December 4, 2021 Report Share Posted December 4, 2021 Dont let the GF know how much you have spent in the last few months. pynacl 1 Quote Link to comment Share on other sites More sharing options...
pynacl Posted December 5, 2021 Author Report Share Posted December 5, 2021 Got the ports all cleaned, fresh gaskets, fresh hardware and the headers bolted up. Now just have to sort through the O2 sensor wiring because I’m an idiot and didn’t mark them. I'll have to fire up Ecuworx too and code out the downstream O2 sensor and secondary air pump so we don't get a CEL. YoungCR and Rekpoint 2 Quote Link to comment Share on other sites More sharing options...
pynacl Posted December 8, 2021 Author Report Share Posted December 8, 2021 Since I went with catless headers, I decided to delete the whole secondary air injection system since I don't think it serves any purpose besides helping in the cat heating sequence (saves 4lbs too). Got this nifty little aluminum block off plate from Achilles Motorsports that looks pretty sweet, even though it will never be seen. Rekpoint 1 Quote Link to comment Share on other sites More sharing options...
pynacl Posted December 14, 2021 Author Report Share Posted December 14, 2021 Since it was looking pretty tired out, I decided to replace the fan blades and fan clutch with a new Mahle one. Better preventatively than to see it grenade and take out the hood or radiator. Personally prefer this setup to an electric fan swap, because it just works. No overheating in hot weather while stopped, no blasting heat in the middle of summer or messing with fan shrouds etc. Easy enough to service so I’ll keep it. Quote Link to comment Share on other sites More sharing options...
pynacl Posted December 14, 2021 Author Report Share Posted December 14, 2021 Also got around to fixing some small oil leaks. One coming from the exhaust side camshaft position sensor o-ring and the other the oil return pipe crush washers. Quote Link to comment Share on other sites More sharing options...
Rekpoint Posted December 14, 2021 Report Share Posted December 14, 2021 15 hours ago, pynacl said: Personally prefer this setup to an electric fan swap, because it just works. No overheating in hot weather while stopped, no blasting heat in the middle of summer or messing with fan shrouds etc Why do I feel like this is a jab at me. Quote Link to comment Share on other sites More sharing options...
pynacl Posted December 14, 2021 Author Report Share Posted December 14, 2021 9 minutes ago, Rekpoint said: Why do I feel like this is a jab at me. Lol! The moment I saw you in 90 degree traffic with the heat blowing and your shirt off I said, that doesn’t look fun. Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted December 15, 2021 Report Share Posted December 15, 2021 Is there not a good efan solution for those cars? Is it a space constraint? Quote Link to comment Share on other sites More sharing options...
pynacl Posted December 15, 2021 Author Report Share Posted December 15, 2021 32 minutes ago, KaiserRolls said: Is there not a good efan solution for those cars? Is it a space constraint? Great question. Most run the 16" SPAL like the one in this BuildJournal thread: https://thebuildjournal.com/diy/n15-design-e46-m3-electric-fan-mount-diy/. It seems to cover as much as the clutch fan, but maybe it has to do with the fact it deletes the aux fan and the clutch fan? Not entirely sure. KaiserRolls 1 Quote Link to comment Share on other sites More sharing options...
pynacl Posted December 22, 2021 Author Report Share Posted December 22, 2021 Got the front suspension installed with the reinforcement plates, replacing the OE Bilstein kit. Definitely a lot of stuff to balance together while you line them up by yourself. Set them as close to factory height as I could for a good starting point and -2.5 camber. Totally overkill for the factory wheels right now, but plan to get something else before I actually pull it out in the spring. Full setup is: Front TC Kline Single Adjustable coilover (uses a Koni shock) Ground Control Race Camber/Caster Plate 500lb Hyperco Springs OEM BMW Reinforcement Plates Rear TC Kline External Adjustable Rear Shock TC Kline Buna Rubber rear shock mounts 600lb Hyperco Springs Rogue Engineering Spring Perch Reinforcement Plates Rogue Engineering RSM Reinforcement Plates Rekpoint 1 Quote Link to comment Share on other sites More sharing options...
pynacl Posted December 22, 2021 Author Report Share Posted December 22, 2021 Got an awesome christmas gift from @Rekpoint, a genuine BMW fire extinguisher and seat mount kit. These are pretty dang hard to get into the states because they're considered a dangerous good with the pressurized canisters. The brackets and seat are only drilled from the factory and require a M6x1.25 thread to be tapped. Luckily the included hardware is self tapping, just requires some pretty small tools to properly install everything. Rekpoint 1 Quote Link to comment Share on other sites More sharing options...
pynacl Posted December 22, 2021 Author Report Share Posted December 22, 2021 Saw Turner came out with a revised brake line kit that was stainless steel + zinc plated AND it was on sale over cyber Monday. Couldn't help myself. Finally got around to installing them tonight, and so glad I did because my factory line had a was pretty crusty and had a nasty gash in it that was probably pretty close to exploding! Bled the system with some fresh RBF600 after install Oooo shiny Rekpoint 1 Quote Link to comment Share on other sites More sharing options...
YoungCR Posted December 22, 2021 Report Share Posted December 22, 2021 Very cool! Didn't know "newer" cars had the fire extinguisher option too. You could get them on E28's as well along with the spare mounted gas can too. Rekpoint and pynacl 2 Quote Link to comment Share on other sites More sharing options...
pynacl Posted December 22, 2021 Author Report Share Posted December 22, 2021 2 hours ago, YoungCR said: Very cool! Didn't know "newer" cars had the fire extinguisher option too. You could get them on E28's as well along with the spare mounted gas can too. Definitely is! Seems like it's only a thing on newer cars in the EU, since I think there's certain countries that require them as part of inspection. Since the US doesn't have any requirements, they stopped offering them here and getting your hands on them is crazy hard. Although I know I could just get any generic gloria style canister, having an OEM one is cool! Quote Link to comment Share on other sites More sharing options...
