GunMetalGrey Posted August 25, 2020 Report Share Posted August 25, 2020 I know, I know, I know, I moved and abandoned everyone, but the car and truck both have WI plates so it kinda counts, right? The real reason is to keep track of things, and this forum format is pretty slicks. So, I bought another E30. Like any logical man I made sure to buy one that was thousands of miles away, and too low for any sanely priced shipping company to touch. Took my truck to WI to say hi to a few people, fly out to CA for work, then fly back to WI so I could load up the car on the trailer and head home with it. Nothing like a 4,000 mile round trip to grab a car! So the real question here is; why? This is a car that has been mentioned from time to time, a handful of you know it, but never had much presence on the internet or in person. This is the car that a friend purchased shortly after he saw me rebuilding my first E30 and thought it looked cool. I've been working with this car since day one, and know the details on all of it, so minimal surprises. He's owned the car for around 10 years, and it has seen an M10, M10 turbo (shortly), M50, and the current setup. It has been the bastard child of many projects, but what I really wanted was the current drive-line. Car Details: 1984 318i Rear euro bumper on, front in the car to be put on full late model brake swap houndstooth / black leather interior Koni adjustable suspension, poly throughout the whole car for bushings M3 steering rack Engine Details: S52 OBD1 Swapped 11.5:1 Pistons (bored over) MLS Head gasket (.01" taller than stock to compensate for block and head decking) Shrick Cams Bavarian CNC port and polished head Upgraded valve springs Solid lifters (?) M50 Intake manifold Riot Racing big bore throttle body 3.5" Euro MAF 24lb injectors Turner Underdrive pulleys ARP hardware throughout Ceramic coated headers, full stainless exhaust from Mr. Asparagus's NA setup Needless to say, the car can really get out of its own way. We rolled the car across a scale a year or so ago which was very similar to how it sits now, and the scale showed 2,400 lbs. Lightweight NA power is a whole different ball game from what I've known. The car needs plenty of clean up work as it has been "neglected" for many years, a lot of the finer details are not in a way that I appreciate. I'm excited to be back behind the wheel of an E30 that will actually be enjoyable to drive (the diesel noises were cool before, but the rest was strongly mediocre). Until next time! pynacl, REKIII, gilber33 and 14 others 17 Quote Link to comment Share on other sites More sharing options...
YoungCR Posted August 26, 2020 Report Share Posted August 26, 2020 Glad to see this isn't gathering dust in a corner! I haven't seen this car since it was at your old old shop. Quote Link to comment Share on other sites More sharing options...
SteelBlue Posted August 27, 2020 Report Share Posted August 27, 2020 It definitely scoots. It looked really good after I did a paint correction on it however many years ago, but it sat outside that winter... Quote Link to comment Share on other sites More sharing options...
GunMetalGrey Posted August 27, 2020 Author Report Share Posted August 27, 2020 12 hours ago, YoungCR said: Glad to see this isn't gathering dust in a corner! I haven't seen this car since it was at your old old shop. Yeah it's been a paperweight for the most part lately, will be good to have it back out on the road! 8 hours ago, SteelBlue said: It definitely scoots. It looked really good after I did a paint correction on it however many years ago, but it sat outside that winter... Yep, that was good stuff for sure, minus the missing wheel cap. P_Roloff, Jdesign and SteelBlue 3 Quote Link to comment Share on other sites More sharing options...
B C Posted August 27, 2020 Report Share Posted August 27, 2020 The passenger headrest evokes the boredom of a girlfriend sitting in the car waiting for a car meet to be over. jc43089, patsbimmer1, Rekpoint and 1 other 2 2 Quote Link to comment Share on other sites More sharing options...
GunMetalGrey Posted November 11, 2020 Author Report Share Posted November 11, 2020 Long time no update This thing has been a struggle. Things that were happening; engine was stumbling around 3200-3500rpm and sometimes wouldn't push past it, light throttle would allow those revs. Would hit some form of limiter far before what the hard limit is set to. I thought it may be due to 92 octane (10% ethanol) vs the tune being for 91 no ethanol. I tracked down some 92 no ethanol (technically not legal in WA) and tried that. No dice Hooked up a wideband to see what it was doing in that range and noticed that it would lean out on light accel and was running right on the edge of what seems comfortable for being too lean. Took the fuel pump out while I was trying to further investigate my lack of fuel gauge and was reminded of the time when the pump in this car was being changed and I noted you couldn't dangle a fuel pump with a piece of wire cable tied to the fuel pump bracket. I dropped the pump back down and verified the pickup of the pump was sitting on the bottom of the fuel tank. Drove again and the AFR's came back nicely, but still struggling a bit in that 3k and rev limit range, though I noted a strong increase in midrange torque. I had been monitoring spark plugs and cylinder tops and had noted that each time cylinder 6 was wet on top, and so was the half of cyl 5 that is near 6. Tried blowing them off to see if it was fuel from a leaky injector or something of the like and nothing happened. Cylinder 5 and 6 were the lowest in a compression test, so the head came off assuming the HG didn't manage to hold through the lean abuse. Off came the head, the old gasket did have faint notes of failure. I decided to go with another MLS as my last cut ring experience was not good, and I was unsure if the stock HG would allow for the 87mm bore pistons. When removing the old gasket it seemed thicker than it should be (.08" was the previous order) and I verified that this engine has been using a .100" thick gasket this whole time. A rough ratio shows that it brought the compression back to just about stock. I ordered stock thickness so we will see a hair above 11.5:1 compression now. Started reassembling the engine and got everything timed up and assembled, went to install the primary chain tensioner and it never got tight. Surprise no more threads in the tensioner hole. Called around to see who had an M26 helicoil with no success. Tried a local E36 shop who said on the phone they had them and could fix it, drove an hour there to drop it off, waited for 2.5 hours, then got a call saying they couldn't fix it and they didn't think they even made helicoils that big. That was a colossal waste of time and made me super happy. i ended up ordering a kit to helicoil it as I'm not super keen on welding in that hole and would still need to pay someone to bore it back out and tap it again. In good news I finally took it from the original (adorable) early 318i front brakes to the late model brakes with all new parts. Hoping to have the head back on by Saturday before I leave for another month work trip. .....This was supposed to be fun to drive and just small projects P_Roloff 1 Quote Link to comment Share on other sites More sharing options...
HipMF Posted November 11, 2020 Report Share Posted November 11, 2020 Classic. Quote Link to comment Share on other sites More sharing options...
GunMetalGrey Posted November 20, 2020 Author Report Share Posted November 20, 2020 Got the engine back together and was still getting breakup issues around the 3500rpm mark, but wouldn't stumble if I was spinning tire at that point, and got worse as the engine warmed up. Being unsure of the quality of the chip tune, and long time desire to see this dyno tuned, it was finally time to take it in and see if the tune was to blame. After some wood and time to get it up the dyno ramps (it's not high off the ground...) it was nestled in and the tuning commenced. Yes the door was open for tuning. The first pull on the chip tune yielded a very lackluster 236hp and 231lbft of torque, and the breakup around 3500rpm really reared its head. I would be lying if I told you that I was happy with that amount of power, but rolled into it knowing that may happen. The tuner then took the existing tune out and tossed on one that he had from a roughly similar motor to see how it liked that. The pull was smooth and didn't break up with the new tune, and it sounded much better. I glanced at the screen and saw 296hp flash across it, and I looked at the tuner to verify what I had just seen. He hadn't looked at the number yet, so we went over and looked. Sure shit, first pull with a different tune and we gained 60hp. We were all quite impressed, as that was nearing the highest HP S5x they have ever seen NA, and its a specific E36 shop that builds many a motor. More tuning commenced and the motor responded really well to any changes and kept improving in powerband and peak numbers, though as the engine would heat-soak the breakup around 3500rpm would return no matter how much fuel or timing was added/removed. That one boils down to a hardware issue somewhere that I am working on tracking down. After a few hours of playing he finally determined that it was doing the best it could, and put down some serious numbers that everyone was happy with. We managed to pick up 75hp and 45ftlbs more torque on an NA engine which is simply astounding. The car is now making more TQ across the entire range than it made in horsepower on the chip tune. The rev limit is at 6600rpm right now and once I find that breakup issue when warm (affects rev limit also) I will be going back and having the limit moved up a fair bit as peak horsepower is at redline right now so I will likely continue to make more power. The car is an absolute machine now, it pulls hard and smooth throughout the whole range and I keep hitting rev limiter because at no point does it feel like I need to shift. Absolutely stoked with the whole tune, and the guys at the shop were great to work with. i_love_cars, Jdesign, KaiserRolls and 1 other 4 Quote Link to comment Share on other sites More sharing options...
SteelBlue Posted November 20, 2020 Report Share Posted November 20, 2020 Wheel centers and the euro front bumper have definitely helped this car's appearance. Those are turbo tuning numbers in terms of gains. Understandably so, given what's in the motor. Looking forward to going for a ride at some point. Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted November 20, 2020 Report Share Posted November 20, 2020 Great results. i know you’re OBD1, but was he able to log any IATs or anything during the runs? Heat soak that quickly sounds not fun Quote Link to comment Share on other sites More sharing options...
m42b32 Posted November 20, 2020 Report Share Posted November 20, 2020 There's just something about an early model with euro bumpers, it looks so good. Amazing numbers! I bet it's an absolute riot to drive. Quote Link to comment Share on other sites More sharing options...
GunMetalGrey Posted November 21, 2020 Author Report Share Posted November 21, 2020 1 hour ago, KaiserRolls said: Great results. i know you’re OBD1, but was he able to log any IATs or anything during the runs? Heat soak that quickly sounds not fun It's not an intake thing ( I don't think at this point) as the intake tube was cool the whole time. I'm thinking there is a sensor on the fritz or something like that and is affected by temperature. It didn't have the breakup issue in WI but started happening shortly after bringing it out here. I tried (5) different coils today and that didn't change anything, so will shuffle them around and try again. I had tried a new crank sensor but the new one was DOA. Not entirely sure what else to start chasing down. 1 hour ago, m42b32 said: There's just something about an early model with euro bumpers, it looks so good. Amazing numbers! I bet it's an absolute riot to drive. It's a classy look for sure, but doesn't sound or drive classy! Drove it around a bit today, and realized how much I hate the clutch. It was put in when he thought he was going to do boost, so its a stage 39485958 6 puck unsprung on a single mass flywheel. It blows, that's pretty high on the list of things to replace because it simply isn't enjoyable. KaiserRolls 1 Quote Link to comment Share on other sites More sharing options...
YoungCR Posted November 21, 2020 Report Share Posted November 21, 2020 Excellent! Early euro bumpers are the best Quote Link to comment Share on other sites More sharing options...
GunMetalGrey Posted January 12, 2021 Author Report Share Posted January 12, 2021 Update time! I was driving the car around for a day or two after tuning, tearing up the streets and such. Went to a guys house who does E36 racecars and was working on s54 itb adapters for m5x/s5x engines which I wanted to pick his brain about for reasons. Right before I got to his house the temp gauge started climbing above half, figured it was just air so wasn't worried. Before I left his house I opened the expansion tank and worked the hoses a bit. Started my 30 min drive home and made it about 10 before it started overheating. I parked in a gas station and tried for 40 or so minutes to burp the cooling system and add coolant but it was no success. Luckily I was about 5 miles from a friends house who just so happened to not be working that night. I started driving to his place and as I got off the highway I nearly stalled it changing gears as the clutch engagement point was suddenly on the floor... I pumped the pedal once or twice to find out something in the clutch blew out and I could barely get anything. I continued driving my overheating e30 without using the clutch and trying to time traffic lights correctly. I made it into his apartment complex and parked it, got a ride home, and rented a uhaul trailer (again) to pick the car up. Slave cylinder hydraulic seal blew out, so brake fluid was dumping out of the bellhousing. I bought a new master and slave cyl to accompany the new clutch and not have to worry about it for many years again. I dropped the trans with the engine in the car which I haven't done before. Not as bad as everyone says it is! I swapped to a E36 flywheel with 240mm clutch vs the E30 flywheel that was in it at 228mm. The old six puck clutch was indeed required to hold the NA power that this engine is producing which is amusing, but sucks to drive. Swapped to a full face organic disk. Old clutch/PP/Flywheel weight: 31.4 Lbs. New clutch/PP/Flywheel weight: 28.4 Lbs. Three pounds lighter for a better clutch? I'm game! Photo of old clutch so I can remember the abuse it caused. After using the wrong throw-out bearing the first time which required me to take the trans back out, I was finally at the point where everything was back together and ready for coolant. I poured coolant in and started hearing a trickle, and found a pinhole in my radiator that had 3 hours or so of runtime on it. I must've caught it on something while taking it out. My attempt to solder it was unsuccessful so I ordered another one, thankfully the CSF OE replacement is cheap! So everything is back together now, and RockAuto sent me the correct crank sensor after they sent me the wrong one (the must've had a mislabeled box or something odd) and it seems the crank sensor was the cause of my breakup and stumbling issues, as the car now pulls smoothly to 7?00 RPM. I would like to get back on the dyno to make sure that top rev range is tuned and to see where the power starts to taper. The new clutch is so damn nice to drive with, frankly it should've been the first thing I did to the car when I got it. The ability to slip the clutch and not have the car lurching is lovely, and as resulted in me driving this thing a lot more than it ever has been since I've known it. It does still have the issue of losing traction in 3rd gear on moist pavement at 65mph though. I need to work on that one yet! P_Roloff 1 Quote Link to comment Share on other sites More sharing options...
P_Roloff Posted January 12, 2021 Report Share Posted January 12, 2021 2 hours ago, GunMetalGrey said: It does still have the issue of losing traction in 3rd gear on moist pavement at 65mph though. I need to work on that one yet! I think you should post a video of this. You know, for scientific purposes. YoungCR 1 Quote Link to comment Share on other sites More sharing options...
GunMetalGrey Posted January 12, 2021 Author Report Share Posted January 12, 2021 On 1/12/2021 at 12:56 PM, P_Roloff said: I think you should post a video of this. You know, for scientific purposes. Ahhh man an excuse to go beat on the car... I hate those! Note my overzealous let-off that had me pointing toward another car in oncoming traffic, and the other side being a ditch lol I hope @B C appreciates the audio, the timing was unintentional. The highway was actually dry enough to let 3rd gear stretch its legs, I always debate going back to a 3.73 in this car, but the 3.25 feels like it takes great advantage of the torque on hand. Jdesign, SteelBlue, HipMF and 3 others 5 1 Quote Link to comment Share on other sites More sharing options...
P_Roloff Posted January 13, 2021 Report Share Posted January 13, 2021 That looks like an absolute riot. The way it built speed... 115 at the end of the pull? Friggin awesome. If this car ever makes it’s way back to Wisconsin, I want to see it. Quote Link to comment Share on other sites More sharing options...
YoungCR Posted January 13, 2021 Report Share Posted January 13, 2021 Bury that tach! It wouldn't be a project car without ups and downs, this seems worth the trouble. Quote Link to comment Share on other sites More sharing options...
SteelBlue Posted January 15, 2021 Report Share Posted January 15, 2021 S52 to the moon. Quote Link to comment Share on other sites More sharing options...
Rekpoint Posted January 15, 2021 Report Share Posted January 15, 2021 8 minutes ago, SteelBlue said: S52 to the moon. Where it should be 🤩 Quote Link to comment Share on other sites More sharing options...
GunMetalGrey Posted January 16, 2021 Author Report Share Posted January 16, 2021 Started making an airbox, ended up going down a rabbit hole, will update more later once parts arrive. I believe I'm going for the highest power NA S52 SteelBlue, Jdesign, m42b32 and 1 other 4 Quote Link to comment Share on other sites More sharing options...
m42b32 Posted January 16, 2021 Report Share Posted January 16, 2021 14 hours ago, GunMetalGrey said: Started making an airbox, ended up going down a rabbit hole, will update more later once parts arrive. I believe I'm going for the highest power NA S52 I like this, interested to see! Quote Link to comment Share on other sites More sharing options...
GunMetalGrey Posted January 16, 2021 Author Report Share Posted January 16, 2021 Alright I'm going to start thinking out loud here. So what I was looking at while working on an airbox is the tight radius elbow that leads into the throttle body on my car. The bimmerworld elbow is used to adapt to the 3.5" MAF but seems to have a tighter radius than stock. Bends are bad for airflow, and I currently have a tight radius 90 before the throttle body, then a 90 after the filter. Total of 180° of bends. The E36 chassis needs this bend due to the strut tower location and them being close together, but the strut towers are further back and apart in an E30, and the throttle body is almost entirely forward of it. Random google pic instead of going to my car. Step 1: New throttle body. I recently stumbled upon someone who put an M60 throttle body (80mm) on an S52. Turns out many years ago Treehouse racing actually made a kit to do this, but I have never seen this or heard about it, and it looks like not many were ever made. The throttle body uses the same TPS, but everything else is different. I picked up one on ebay for $60 shipped. This is the same engine that my MAF is from. I will be making an adapter that will allow me to bolt this up to my engine, and I will be opening up the hole in the manifold to capitalize on the swap. I will need to make a bracket for the throttle cable as well. Step 2: Remove 90° bend at throttle body. If I move my coolant expansion tank to the passenger side of the car (plenty of space) I can get away with running (1) 45° elbow at the throttle body, and keep the rest straight with maybe a small bend to accommodate the filter. Taking 135° of bends out of my intake tubing should help, especially with eliminating the tight radius bend before the throttle body. What I'd like to do is swap this stuff while it's on the dyno and see actual results. The biggest downside is going to be drivability; currently I barely have to breathe on the throttle pedal to cruise, and this swap will amplify that issue. I will make a different throttle arm if I have enough pedal travel to do so. I don't think this swap ever caught on because it is likely very pointless on a relatively stock engine, but we're far from that in this thread! wasnt m3, m42b32, Jdesign and 1 other 4 Quote Link to comment Share on other sites More sharing options...
YoungCR Posted January 16, 2021 Report Share Posted January 16, 2021 I like where this is going 😎 Quote Link to comment Share on other sites More sharing options...
GunMetalGrey Posted February 4, 2021 Author Report Share Posted February 4, 2021 Throttle body updates? Nah I determined I want to do some data collection before that regarding intake vacuum pre/post TB What I did do was replace the boat 3 spoke steering wheel with a smaller unit. Please ignore the lack of kick panel near the pedals, and the speaker grille. Gotta love early models for not having actual kick panels there. P_Roloff and m42b32 2 Quote Link to comment Share on other sites More sharing options...
