jc43089 Posted September 24, 2019 Report Share Posted September 24, 2019 If the slave cylinder is installed right it can't just randomly blow the pin out. The pin only comes out if you press the clutch pedal without the slave installed to the transmission. KaiserRolls and Partiallypurple 1 1 Quote Link to comment Share on other sites More sharing options...
straight6pwr Posted September 24, 2019 Report Share Posted September 24, 2019 did you use a new clip? make sure the fork was aligned properly? and make sure it wasnt worn through? insert the clutch slave into the bellhousing at a straight angle? (that's what she said) use the correct TOB? Quote Link to comment Share on other sites More sharing options...
Jdesign Posted September 24, 2019 Report Share Posted September 24, 2019 1 hour ago, straight6pwr said: use the correct TOB? Type Of Buttocks? jc43089 1 Quote Link to comment Share on other sites More sharing options...
Partiallypurple Posted September 24, 2019 Author Report Share Posted September 24, 2019 On 9/23/2019 at 8:23 AM, Jdesign said: Are you back in business now? Finishing it up today after work. Fingers crossed everything will go well 🤞 Quote Link to comment Share on other sites More sharing options...
Partiallypurple Posted September 24, 2019 Author Report Share Posted September 24, 2019 4 hours ago, straight6pwr said: did you use a new clip? make sure the fork was aligned properly? and make sure it wasnt worn through? insert the clutch slave into the bellhousing at a straight angle? (that's what she said) use the correct TOB? New clip, didn’t make sure the fork was aligned properly to be honest. Kind of stupid of myself. Didn’t have any problems with the last slave on my other e36 so I figure it was as easy as screwing on and making sure it’s tight. Going to make sure everything is perfect before I even look at that clutch pedal this time Quote Link to comment Share on other sites More sharing options...
straight6pwr Posted September 24, 2019 Report Share Posted September 24, 2019 you can also test fit the slave before installing the transmission Quote Link to comment Share on other sites More sharing options...
SteelBlue Posted September 24, 2019 Report Share Posted September 24, 2019 2 hours ago, Partiallypurple said: New clip, didn’t make sure the fork was aligned properly to be honest. Kind of stupid of myself. Didn’t have any problems with the last slave on my other e36 so I figure it was as easy as screwing on and making sure it’s tight. Going to make sure everything is perfect before I even look at that clutch pedal this time Correct me if I'm wrong, and I could be given this is a 1J, but when the fork is lined up correctly, the slave should sit off the bell housing a little as the dowel is pressing into the arm. Partiallypurple and Jdesign 2 Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted September 25, 2019 Report Share Posted September 25, 2019 6 hours ago, SteelBlue said: Correct me if I'm wrong, and I could be given this is a 1J, but when the fork is lined up correctly, the slave should sit off the bell housing a little as the dowel is pressing into the arm. Correct, it takes some pushing to get the slave to sit flush on the back of the trans Jdesign and Partiallypurple 2 Quote Link to comment Share on other sites More sharing options...
Partiallypurple Posted October 5, 2019 Author Report Share Posted October 5, 2019 Well a whole new clutch setup later and throwout bearing and we are finally back up and running! Spent the day deep cleaning all the interior panels, deciding what was good enough to keep and what had to go! Also made a shift boot/cage for the CAE. Going to wrap it in alcanatara suede but the brushed aluminum isn’t bad till I park the car for winter soon. patsbimmer1, SteelBlue, Jdesign and 2 others 5 Quote Link to comment Share on other sites More sharing options...
jc43089 Posted October 7, 2019 Report Share Posted October 7, 2019 Looks nice! Partiallypurple 1 Quote Link to comment Share on other sites More sharing options...
Jdesign Posted October 7, 2019 Report Share Posted October 7, 2019 CAE is a life changer. are you planning on keeping it aluminum or will you darken that up a bit too? Quote Link to comment Share on other sites More sharing options...
Partiallypurple Posted October 9, 2019 Author Report Share Posted October 9, 2019 On 10/7/2019 at 10:35 AM, Jdesign said: CAE is a life changer. are you planning on keeping it aluminum or will you darken that up a bit too? Which part? The part I made is getting wrapped, the shifter itself will stay as is with probably a white knob to match the letters on the seats and steering wheel. The aluminum should match the lips of the wheels Jdesign 1 Quote Link to comment Share on other sites More sharing options...
Jdesign Posted October 9, 2019 Report Share Posted October 9, 2019 11 hours ago, Partiallypurple said: Which part? The part I made is getting wrapped, the shifter itself will stay as is with probably a white knob to match the letters on the seats and steering wheel. The aluminum should match the lips of the wheels The shaft. 🤭 It just doesn't seem like there is any other raw aluminum in the interior. Partiallypurple 1 Quote Link to comment Share on other sites More sharing options...
Partiallypurple Posted October 16, 2019 Author Report Share Posted October 16, 2019 On 10/9/2019 at 8:17 AM, Jdesign said: The shaft. 🤭 It just doesn't seem like there is any other raw aluminum in the interior. There is now! Just picked these up from a local tire shop they had sitting in the back in a box from the early 90’s. They used to be a MOMO distributor back in the day. Super neat score that’ll match the Recaro Momo Special and fit the period correct theme I’m going for. Also the cage is currently polished/cleared. I can’t find any other pictures or anything on these pedals Jdesign, P_Roloff and SteelBlue 3 Quote Link to comment Share on other sites More sharing options...
YoungCR Posted October 17, 2019 Report Share Posted October 17, 2019 Really cool! How did those sit on a shelf for 20years?? Quote Link to comment Share on other sites More sharing options...
Partiallypurple Posted October 17, 2019 Author Report Share Posted October 17, 2019 45 minutes ago, YoungCR said: Really cool! How did those sit on a shelf for 20years?? Sat in the back warehouse where no one could see them. Quote Link to comment Share on other sites More sharing options...
Rekpoint Posted October 17, 2019 Report Share Posted October 17, 2019 2 hours ago, Partiallypurple said: There is now! Just picked these up from a local tire shop they had sitting in the back in a box from the early 90’s. They used to be a MOMO distributor back in the day. Super neat score that’ll match the Recaro Momo Special and fit the period correct theme I’m going for. Also the cage is currently polished/cleared. I can’t find any other pictures or anything on these pedals This is pretty sick Partiallypurple 1 Quote Link to comment Share on other sites More sharing options...
Jdesign Posted October 17, 2019 Report Share Posted October 17, 2019 WOAH.. that brings me back. So oddly, my very first car had a very similar set of those Circa 2004. The guy I bought it from was best friends with the owner of LINK motorsports back in the day. He got a bunch of free parts for the car that was sitting on the shelf. Sadly, this also meant the car was a pile of mismatched parts. Red seats, blue harnesses, red faded to brown steering wheel, etc. I ended up selling my pedals to some kid years ago, nowhere NEAR as clean as those. Congrats on your find! Partiallypurple 1 Quote Link to comment Share on other sites More sharing options...
Partiallypurple Posted October 26, 2019 Author Report Share Posted October 26, 2019 Well not related to the Daytona. But picked up a Mauritiusbleu metallic 318i individual that has been sitting in a storage unit since 01’. Hasn’t seen daylight in 18 years. Originally ordered in Canada it spent its entire life in New Mexico. The thing is flawless underneath and has no rust. Excited to daily drive it and give it the love it needs. A deep cleaning, a buff, new fender and hood on the way! Was originally parked because the owner was leaving his marine base driving it to wisconsin home and got into a minor accident. Parked it, and here we are 18 years later. suspenceful, P_Roloff and SteelBlue 3 Quote Link to comment Share on other sites More sharing options...
straight6pwr Posted October 27, 2019 Report Share Posted October 27, 2019 very cool! sad that someone who spec'd an 'individual' didnt upgrade to the painted bumpers. Partiallypurple 1 Quote Link to comment Share on other sites More sharing options...
Partiallypurple Posted October 27, 2019 Author Report Share Posted October 27, 2019 44 minutes ago, straight6pwr said: very cool! sad that someone who spec'd an 'individual' didnt upgrade to the painted bumpers. I personally like the look of the unpainted bumpers. I made my other coupe 2 tone with grey bumpers on purpose Quote Link to comment Share on other sites More sharing options...
YoungCR Posted October 27, 2019 Report Share Posted October 27, 2019 What a cool find. Not many factory fresh E36's around anymore. Partiallypurple 1 Quote Link to comment Share on other sites More sharing options...
Rekpoint Posted October 27, 2019 Report Share Posted October 27, 2019 Saw this one on CL. With alittle front end work itll be great. I have an extra set of usdm headlights if interested, Quote Link to comment Share on other sites More sharing options...
jc43089 Posted October 28, 2019 Report Share Posted October 28, 2019 Nice find. And cool wheels, what style are those? Quote Link to comment Share on other sites More sharing options...
Partiallypurple Posted October 30, 2019 Author Report Share Posted October 30, 2019 So after contacting International BMW where I know a manager, I got the word that the car was in Germany from 1993-1998. It spent almost all of its miles there and has all the service history of the car documented. The guy I bought it off must’ve been misinformed on the history of where the car was originally from. The service booklet had some really cool brochures in it and a bunch of other stuff like this cool napkin. Super pumped about finding this car. Jdesign 1 Quote Link to comment Share on other sites More sharing options...
