HipMF Posted November 12, 2018 Report Share Posted November 12, 2018 ARP vs grade 12.9 SHCS Go! (paging @snap) Quote Link to comment Share on other sites More sharing options...
0 B C Posted November 15, 2018 Report Share Posted November 15, 2018 My opinion is that ARP hardware is worth the extra cost since a large investment into R&D has been made to fine tune the metallurgy, design, and processing for a good balance of tensile strength, toughness, fatigue and corrosion resistance, along with specific torque values and lubricant. At the end of the day a bolt is a bolt and it will clamp a load as long as the sum total of all of the applied stresses stay within the limits of the molecular bonds. I see nothing wrong with using 12.9's but if I were doing so, I might do a quick experiment in a test jig with a torque wrench to see what the maximum torque is before yield or breakage is and compare that to the BMW recommended torque spec just to make sure you have enough head-room for thermal stresses and cylinder compressive forces. Quote Link to comment Share on other sites More sharing options...
0 HipMF Posted November 15, 2018 Author Report Share Posted November 15, 2018 4 hours ago, snap said: My opinion is that ARP hardware is worth the extra cost since a large investment into R&D has been made to fine tune the metallurgy, design, and processing for a good balance of tensile strength, toughness, fatigue and corrosion resistance, along with specific torque values and lubricant. At the end of the day a bolt is a bolt and it will clamp a load as long as the sum total of all of the applied stresses stay within the limits of the molecular bonds. I see nothing wrong with using 12.9's but if I were doing so, I might do a quick experiment in a test jig with a torque wrench to see what the maximum torque is before yield or breakage is and compare that to the BMW recommended torque spec just to make sure you have enough head-room for thermal stresses and cylinder compressive forces. Thanks. The yield test is something I thought of, but I wanted to do it to one of the stock TTY bolts to see what torque value they yield at to get an idea what torque value I should start at for a non-TTY bolt. I'm an electrical guy, not mechanical, so this is all a bit outside my wheelhouse... The more I think about it, the more complicated it seems. Quote Link to comment Share on other sites More sharing options...
0 jc43089 Posted November 16, 2018 Report Share Posted November 16, 2018 My thought is why would they use TTY bolts if regular ones would work? Doesn't the stretching create a stronger clamp to resist the compression? Also OE TTY bolts are super cheap. Quote Link to comment Share on other sites More sharing options...
0 HipMF Posted November 16, 2018 Author Report Share Posted November 16, 2018 56 minutes ago, jc43089 said: My thought is why would they use TTY bolts if regular ones would work? Doesn't the stretching create a stronger clamp to resist the compression? Also OE TTY bolts are super cheap. Questioning this myself. The internet insists that you need studs because boost. I think the advantage of TTY has more to do with assembly and consistency than clamping force (process windows bruh), but maybe I'm mistaken... Quote Link to comment Share on other sites More sharing options...
0 GunMetalGrey Posted November 16, 2018 Report Share Posted November 16, 2018 Head bolts are going to be sized for their specific application. Keeping things compact while holding an acceptable safety factor is something I would assume to be critical in engine design. When increasing cylinder pressures you are putting the hardware out of its designed range and therefore are at greater risk of failure. If you hit the yield point you are at the point where the hardware is nearing its plastic deformation point, and you actually have a very low overhead before that hardware will stretch and never return. Below is a tensile pull test graph and corresponding data, the spot marked with the red x is the yield point, and you can see that the test specimen starts to rapidly elongate with the continued application of stress (increasing tension) Will the cylinder pressures be great enough to exceed the pre set tension of the hardware? Not sure, but with increasing power that is something that is largely possible. Long story short, ARP's are not that expensive, and are a very proven and relied on product. For peace of mind and potentially avoiding failures I would just run ARP hardware. Quote Link to comment Share on other sites More sharing options...
0 B C Posted November 16, 2018 Report Share Posted November 16, 2018 One more note: Stud and nut is superior to a screw since you significantly reduce/eliminate any torsional stress from the head of the bolt HipMF and GunMetalGrey 2 Quote Link to comment Share on other sites More sharing options...
0 jc43089 Posted November 20, 2018 Report Share Posted November 20, 2018 I was not suggesting that ARP stud kits are inferior to TTY bolts. I was stating that I though TTY bolts would be better than just picking 12.9 bolts. No background was given about intended use or modification from stock. Stockish engine, use TTY because they clearly work well. Significantly beyond stock engine use ARP. That would be my thoughts. Quote Link to comment Share on other sites More sharing options...
Question
Go!
(paging @snap)
Link to comment
7 answers to this question
