vbhargava Posted October 23, 2018 Report Share Posted October 23, 2018 I have an M20 with ~150,000 miles on it. Wondering what viscosity you guys use and why. In researching this online it seems everyone uses something different and ECS sells a bunch of options even when narrowing the search down to this car. Thanks in advance for the assistance. Quote Link to comment Share on other sites More sharing options...
1 RobZR Posted October 25, 2018 Report Share Posted October 25, 2018 On 10/23/2018 at 12:12 PM, straight6pwr said: personally, i've never run 20w in anything. i also believe that brand names, additives, blah blah blah is marketing b.s. and the difference in quality doesn't justify the extra costs. get the right weight in whatever fits in your budget. Ditto. 20w- anything is an archaic spec that belongs back in the 50-60's. Only guys using it are into old muscle cars with sloppy clearances, because some of the oils are blended to protect flat tappet push-rod valvetrain. Or they like to see 100psi. on the gauge on cold starts and think it's a good thing. Most older BMW engine clearances are designed to run a 10-13cSt oil viscosity. Or ~30weight oil running @100c. All oils start much thicker when cold. Running a thicker oil doesn't make sense unless you run the oil hotter the 100c. A 20w50 will be ~20cSt @100c but it will thin to ~12cSt at 120c. engine thinks it got 0w30 in it. It's happy. The cold end of the scale looks much worse. A 0w30 is 65cSt @40c while the 20w50 is 180cSt at 40c. It takes that much longer for the oil to warm up and flow throughout the engine. This is not even looking below freezing. In those temps the extra drag can defeat a good battery and starter. You're trying to pump molasses through a coffee straw. The 0w40 synthetics are a good compromise of performance and protection. With a 75cSt cold and ~13 cSt hot. It's on the thick side of spec.@100c thinning to ~8cSt @120c still giving you some track protection, without relying on the additive package to keep the bearings from seizing for 2-3 times longer on cold start. everyone says that most of your wear comes from cold starts, so why use an oil that will take twice as long to warm to running temp. If you need to run your oil that hot add a oil cooler, or as a last resort run a 5W-50 (115cSt cold, 18.5cSt hot). Not as a first step. Oil analysis Oil analysis is a great way to know engine health. Like a blood test for your car. But, it's meaningless by itself. You need multiple samples to get a true picture of engine health. If you put on a lot of miles and change the oil on a schedule with the same brand/type of oil, it can save you allot in showing you true extended drain intervals for your environment/ driving style. In a garage queen that gets an oil change every year and runs 1k mi. it's pointless unless your looking for a piece of mind. by getting a baseline and getting follow up test you can know nothing changed. on a 1million dollar car it's worth something, on a 200k mi daily, not so much. jc43089, vbhargava and Jdesign 3 Quote Link to comment Share on other sites More sharing options...
0 P_Roloff Posted October 23, 2018 Report Share Posted October 23, 2018 19 minutes ago, vbhargava said: I have an M20 with ~150,000 miles on it. Wondering what viscosity you guys use and why. In researching this online it seems everyone uses something different and ECS sells a bunch of options even when narrowing the search down to this car. Thanks in advance for the assistance. I run 20w-50 Castrol GTX, it's the recommended summer weight per the manual and Castrol I believe was BMW's recommended oil at that time. Otherwise, some people say that Valvoline VR1 in the same weight is a good choice due to higher concentration of ZDDP. I don't stress too much about it personally, I can't imagine there would be huge difference in wear whichever way you go as long as you stick to the recommended oil weights and oil change intervals. vbhargava and timmer 2 Quote Link to comment Share on other sites More sharing options...
0 straight6pwr Posted October 23, 2018 Report Share Posted October 23, 2018 from the manual: personally, i've never run 20w in anything. i also believe that brand names, additives, blah blah blah is marketing b.s. and the difference in quality doesn't justify the extra costs. get the right weight in whatever fits in your budget. vbhargava 1 Quote Link to comment Share on other sites More sharing options...
0 Jdesign Posted October 23, 2018 Report Share Posted October 23, 2018 Valvoline VR1 20w-50 or 15w50 is what I always used and I never had any issues. Quote Link to comment Share on other sites More sharing options...
0 P_Roloff Posted October 24, 2018 Report Share Posted October 24, 2018 If you’re really worried ever, you can also send an oil sample off to blackstone labs and have them run an analysis on it, they can tell you if there’s anything amiss. Quote Link to comment Share on other sites More sharing options...
0 Jdesign Posted October 24, 2018 Report Share Posted October 24, 2018 14 hours ago, P_Roloff said: If you’re really worried ever, you can also send an oil sample off to blackstone labs and have them run an analysis on it, they can tell you if there’s anything amiss. This is over kill but its still cool to do though! I personally have never cared enough to do it. Do you have experience? Quote Link to comment Share on other sites More sharing options...
0 Boris3 Posted October 24, 2018 Report Share Posted October 24, 2018 I do Blackstone regularly for the track car. It's good to set a baseline on engine wear and trace changes in metal content in the oil from wear, helps to see signs of gas or early indications of coolant in oil, as well as how the oil degrades over time/ use in terms of additive content and sheer. i recently did the test on 318is that I expect has well over 250k on the m42. Report came back clean which was a nice surprise. Quote Link to comment Share on other sites More sharing options...
0 P_Roloff Posted October 24, 2018 Report Share Posted October 24, 2018 5 hours ago, Jdesign said: This is over kill but its still cool to do though! I personally have never cared enough to do it. Do you have experience? I don't, I never cared enough for the e30 to do it. I was also a little scared of what it'd find haha. I might for the e34 though to see what we're working with and whether there's any weird issues. Quote Link to comment Share on other sites More sharing options...
0 m42b32 Posted October 25, 2018 Report Share Posted October 25, 2018 I think the blackstone analysis is a very useful tool to check the health of your engine. I did it on the M3 when I found those metal shavings on the inside of the exhaust cam, if something were eating itself it would've shown high iron content/etc. Their report was very thorough and gave great feedback on how frequently I should change my oil, engine health (including content of coolant/water/gas in oil), and feedback on my specific concern. I plan to do it on both the e30 and the wagon after the next complete oil change, it's well worth it for the peace of mind (or finding issues before they become very expensive) in my opinion Quote Link to comment Share on other sites More sharing options...
Question
vbhargava
Link to comment
9 answers to this question
