gilber33 Posted July 18, 2019 Author Report Share Posted July 18, 2019 25 minutes ago, KaiserRolls said: Ditch that tumor of a damper How do I remove it? 24 minutes ago, straight6pwr said: what do you mean by 'too large'? realoem cross references the same giubo to nearly every every e30: https://www.realoem.com/bmw/enUS/partxref?id=1123-USA-02-1990-E30-BMW-325i&mg=26&sg=10&diagId=26_0023&q=26111225624&series=E30 in any case, as long as the bolt hole locations are the same, either one will work. the driveshaft splines takes up the difference if one is thicker. The giubo I ordered that is listed for a manual transmission and is gab01017 and the one on my car gab01009. Auto: Manual: They are visibly different sizes. From what I can gather the manual has a 78mm bolt hole distance and the auto has a 110mm distance. The one I ordered (for a manual car) is way too big. The bolt holes are not even close to lining up. I guess I'm just wondering if this is a long term issue with having a giubo for an automatic car paired with a manual transmission. edit edit: I guess the e30 came with two types of flanges - small and large. And the late models typically had the smaller. It's weird that the part number of the smaller flange would fall under and automatic transmission listing though. Either way, seems like it should be fine. I'm returning the one I ordered, so with that said does the one in my car look fine? I know when they are visibly torn they need to be replaced ASAP, but I'm trying to eliminate any drivetrain slop - and I do not know if these can wear to the point where they look fine on the outside, but the material is worn enough where it produces some noises? Quote Link to comment Share on other sites More sharing options...
straight6pwr Posted July 19, 2019 Report Share Posted July 19, 2019 if the one you have fits, its fine. if you have it in your hands and can inspect it up close and see no damage, you should be good to go! Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted July 19, 2019 Report Share Posted July 19, 2019 https://www.google.com/amp/s/amp.reddit.com/r/E30/comments/88932d/tips_for_removing_driveshaft_dampener/ Quote Link to comment Share on other sites More sharing options...
gilber33 Posted July 20, 2019 Author Report Share Posted July 20, 2019 That was easy. What’s the benefit of removing it? Anywho. Got the diff pulled tonight and replaced the bushing and changed the fluid and reinstalled that. I had ordered a new giubo and that’s coming tomorrow. Otherwise I can put the driveshaft and exhaust back in and be done. Jdesign 1 Quote Link to comment Share on other sites More sharing options...
Jdesign Posted July 22, 2019 Report Share Posted July 22, 2019 On 7/20/2019 at 12:44 AM, gilber33 said: ""done"' What does that word mean? m42b32 1 Quote Link to comment Share on other sites More sharing options...
straight6pwr Posted July 22, 2019 Report Share Posted July 22, 2019 you need the correct washer fluid tank or you're going to fail in the concours judging Jdesign, m42b32 and B C 1 2 Quote Link to comment Share on other sites More sharing options...
gilber33 Posted July 22, 2019 Author Report Share Posted July 22, 2019 4 hours ago, straight6pwr said: you need the correct washer fluid tank or you're going to fail in the concours judging I didn’t realize I had the wrong one in there. I’m so embarrassed. 😔 Quote Link to comment Share on other sites More sharing options...
gilber33 Posted July 23, 2019 Author Report Share Posted July 23, 2019 Felt like it was a little late at night to start it up, but at least it’s on the ground and has fluids in it. Quote Link to comment Share on other sites More sharing options...
B C Posted July 23, 2019 Report Share Posted July 23, 2019 We have been here once before, I think.... Jdesign 1 Quote Link to comment Share on other sites More sharing options...
gilber33 Posted July 23, 2019 Author Report Share Posted July 23, 2019 6 hours ago, B C said: We have been here once before, I think.... You are 100% correct. Quote Link to comment Share on other sites More sharing options...
The Full Banana Posted July 23, 2019 Report Share Posted July 23, 2019 No judgment. I've groundhogged far too many times with my project. Quote Link to comment Share on other sites More sharing options...
gilber33 Posted July 23, 2019 Author Report Share Posted July 23, 2019 I made a graph of my car so far. Jdesign, B C, Nick_F and 2 others 5 Quote Link to comment Share on other sites More sharing options...
gilber33 Posted July 23, 2019 Author Report Share Posted July 23, 2019 I should be able to start the car tonight, but I don't want to take it out for its first shakedown to seat the rings when it's dark out. Does anyone see any issues with me starting it tonight and bleeding the cooling system but not taking it out right away? Quote Link to comment Share on other sites More sharing options...
B C Posted July 23, 2019 Report Share Posted July 23, 2019 7 minutes ago, gilber33 said: I should be able to start the car tonight, but I don't want to take it out for its first shakedown to seat the rings when it's dark out. Does anyone see any issues with me starting it tonight and bleeding the cooling system but not taking it out right away? Yes, you could be kidnapped and never know how it drives. Quote Link to comment Share on other sites More sharing options...
gilber33 Posted July 24, 2019 Author Report Share Posted July 24, 2019 Started it and bled the cooling system. Sounded great. 0780933E-7A4B-4254-B6EC-A38FEADBF48D.MOV Quote Link to comment Share on other sites More sharing options...
gilber33 Posted July 30, 2019 Author Report Share Posted July 30, 2019 Drove it to work for the first time for the third time. 😑 Also, I’m sure you’re all dying for an update on the playhouse. It’s drywalled, taped, mudded, and painted. Other than staining the floor and interior accessories, it’s pretty much done. Put these adorable solar lights on it. And my shed is almost done! Wrapping these up is a huge relief. B C and SteelBlue 2 Quote Link to comment Share on other sites More sharing options...
B C Posted July 30, 2019 Report Share Posted July 30, 2019 Impressive! Me and wood do not get along. Playhouse doesn’t appear to meet required egress codes as the grass could obstruct the door in the event of a fire. Also Wis. Stat. M20.b25(e)(30) states that “No external structure shall take precedence over completion of any existing E30 builds, and something something about culverts.. or culvers...” I’ll give it a B+ m42b32 and gilber33 2 Quote Link to comment Share on other sites More sharing options...
gilber33 Posted August 3, 2019 Author Report Share Posted August 3, 2019 Condor tall knob. Felt it fit the time period of the car better than the ZHP knob. I love it. And the shed and playhouse are done (other than putting stuff in it for her to play with). It is such a relief to be done. SteelBlue 1 Quote Link to comment Share on other sites More sharing options...
SteelBlue Posted August 8, 2019 Report Share Posted August 8, 2019 I like the look of those knobs, but they can be kind of pricey. I do need to change up my current one though. I tried my Nardi on and it felt so sloppy because the knob is so light. I am debating getting one of those IRP short shifter centering shifting deals as @suspenceful's feels like an bolt action shifter. Granted, these can be very pricey. But for how much you use it, I feel it's worth the price. suspenceful 1 Quote Link to comment Share on other sites More sharing options...
gilber33 Posted August 8, 2019 Author Report Share Posted August 8, 2019 55 minutes ago, SteelBlue said: I like the look of those knobs, but they can be kind of pricey. I do need to change up my current one though. I tried my Nardi on and it felt so sloppy because the knob is so light. I am debating getting one of those IRP short shifter centering shifting deals as @suspenceful's feels like an bolt action shifter. Granted, these can be very pricey. But for how much you use it, I feel it's worth the price. $114 for a shift knob is more than I wanted to pay, but I was willing to pay a little more something that worked well and that fit the era of the car. I would say the extra height gives it a little more “slop”, but I haven’t had an issue with missing a gear. Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted August 16, 2019 Report Share Posted August 16, 2019 Your knob looks great Jdesign 1 Quote Link to comment Share on other sites More sharing options...
gilber33 Posted August 16, 2019 Author Report Share Posted August 16, 2019 3 hours ago, KaiserRolls said: Your knob looks great That’s the nicest thing anyone has ever said about my knob. Thank you. Jdesign 1 Quote Link to comment Share on other sites More sharing options...
gilber33 Posted August 19, 2019 Author Report Share Posted August 19, 2019 An e30 in a sea of minivans and SUVs. Took the girls to Bookworm Garden in Sheboygan. Excellent day for a drive in the bimmer. And both kids fell asleep in it on the way home - which I always consider an accomplishment. Quote Link to comment Share on other sites More sharing options...
B C Posted August 19, 2019 Report Share Posted August 19, 2019 I know it always fees like an accomplishment when I have my kids in the BMW and am running errands. Makes the car’s existence feel more legitimate and justifiable gilber33 1 Quote Link to comment Share on other sites More sharing options...
gilber33 Posted August 19, 2019 Author Report Share Posted August 19, 2019 39 minutes ago, B C said: I know it always fees like an accomplishment when I have my kids in the BMW and am running errands. Makes the car’s existence feel more legitimate and justifiable I totally agree. I wanted this to be my fun car, but I also did things in a way that we could use it for day trips and everyone would still be comfortable. It’s a really good feeling when my family is in it. Ive also been dailying it for the past week while I give the wagon a tune up and repair the AWD. It’s been very pleasant. Quote Link to comment Share on other sites More sharing options...
