gilber33 Posted July 3, 2019 Author Report Share Posted July 3, 2019 1 hour ago, KaiserRolls said: Playhouse build thread time Lol. Nothing super exciting. But, she’ll be thrilled when it’s done. We’re telling her it’s a tool shed for the lawnmower and she can’t play in it. It’s For her birthday next month. B C, patsbimmer1 and rampelsauce 3 Quote Link to comment Share on other sites More sharing options...
gilber33 Posted July 4, 2019 Author Report Share Posted July 4, 2019 I wanna make sure this is right or wrong. I’m replacing the front crank seal and it looks like the outer lip of the seal doesn’t sit flush against the crank. Is this right? It doesn’t feel like it should be. It’s an elring seal. Quote Link to comment Share on other sites More sharing options...
B C Posted July 4, 2019 Report Share Posted July 4, 2019 Thats fine, and on older engines it is preferable for the lip seals to ride deeper or shallower than normal to avoid riding in the minute groove that is formed on the shaft surface Quote Link to comment Share on other sites More sharing options...
gilber33 Posted July 4, 2019 Author Report Share Posted July 4, 2019 13 minutes ago, B C said: Thats fine, and on older engines it is preferable for the lip seals to ride deeper or shallower than normal to avoid riding in the minute groove that is formed on the shaft surface That outer lip doesn’t even touch the crank. The inner seal do for sure, just not the outer one. That’s okay? Quote Link to comment Share on other sites More sharing options...
B C Posted July 4, 2019 Report Share Posted July 4, 2019 The actual sealing lip is further back like so. Trust your gut, if you feel funny about it, redo it with a new seal and also check to make sure the aluminum seal housing is sitting flush on the block. Kind of a dumb suggestion but its the only thing im coming up with off the top of my head that could physically affect the seal position Quote Link to comment Share on other sites More sharing options...
gilber33 Posted July 4, 2019 Author Report Share Posted July 4, 2019 That picture helps. It’s weird to me that this one would have that gap around the outer lip but the others wouldn’t. That’s why it’s throwing me off. Oil pump gear crank Quote Link to comment Share on other sites More sharing options...
gilber33 Posted July 4, 2019 Author Report Share Posted July 4, 2019 I took it out. Quote Link to comment Share on other sites More sharing options...
straight6pwr Posted July 4, 2019 Report Share Posted July 4, 2019 48 minutes ago, gilber33 said: That picture helps. It’s weird to me that this one would have that gap around the outer lip but the others wouldn’t. That’s why it’s throwing me off. theres like 100 types of shaft seals, this should not be weird to you. Quote Link to comment Share on other sites More sharing options...
gilber33 Posted July 4, 2019 Author Report Share Posted July 4, 2019 49 minutes ago, straight6pwr said: theres like 100 types of shaft seals, this should not be weird to you. This is the first time I’ve seen one that was “open” on the face like that. It’s the only seal on the m20 like that and I’ve never seen one on all of the Volvo’s I’ve owned. Quote Link to comment Share on other sites More sharing options...
Jdesign Posted July 8, 2019 Report Share Posted July 8, 2019 It's pretty common. A lot of hondas and aftermarket seals are like that. Quote Link to comment Share on other sites More sharing options...
gilber33 Posted July 9, 2019 Author Report Share Posted July 9, 2019 Oh look. More pictures of an m20 on an engine stand. Quote Link to comment Share on other sites More sharing options...
gilber33 Posted July 11, 2019 Author Report Share Posted July 11, 2019 Tonight I got the old engine out and transmission off and moved some more stuff over to the new engine. Also so finished the roof on the playhouse. Need to put in one more window and then finishing trimming it out. Then the next project is a garden shed off the back of the garage and the siding that is coming off of the garage will be going on here. KaiserRolls and P_Roloff 2 Quote Link to comment Share on other sites More sharing options...
B C Posted July 11, 2019 Report Share Posted July 11, 2019 What was the benefit of the new engine? lower miles? and stop trying to beat my record for M20 extractions!!!! Quote Link to comment Share on other sites More sharing options...
gilber33 Posted July 11, 2019 Author Report Share Posted July 11, 2019 59 minutes ago, B C said: What was the benefit of the new engine? lower miles? and stop trying to beat my record for M20 extractions!!!! Lol. This is the 3rd time. I’ve never done a full tear down and rebuild of an engine. Was getting a lot of drivetrain noise and needed to pull the engine to check the clutch. Figured it was a good time to do and drop it in. Fresh hone, new rings, new bearings, and a refreshed head. We’re having our 3rd child in November and I decided while I have the time I’ll get this one in and get the car as reliable as it can be. We’re also doing a home addition next year, so I will very limited access to the garage. 😔 Also, thank you to whoever updated the thread title. Lol Jdesign 1 Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted July 11, 2019 Report Share Posted July 11, 2019 Still have plans to make the core support removable? Jdesign 1 Quote Link to comment Share on other sites More sharing options...
gilber33 Posted July 12, 2019 Author Report Share Posted July 12, 2019 16 hours ago, KaiserRolls said: Still have plans to make the core support removable? Not with this round of things. Don’t want to spend too much time with extra stuff. More focused on getting the drivetrain solid and running again. Eventually, yes. Maybe. Quote Link to comment Share on other sites More sharing options...
B C Posted July 12, 2019 Report Share Posted July 12, 2019 Kid #3 really cut into the time and money I had available for meth, hopefully you can maintain a proper balance SteelBlue and gilber33 2 Quote Link to comment Share on other sites More sharing options...
gilber33 Posted July 12, 2019 Author Report Share Posted July 12, 2019 50 minutes ago, B C said: Kid #3 really cut into the time and money I had available for meth, hopefully you can maintain a proper balance I mean, it is what it is. My wife and I have talked about what we can do to maintain the balance. If that’s picking up some side “jobs” here and there at night, requesting grants from business owners (mostly gas stations), selling my unused semen and bone marrow. There’s lots options. Quote Link to comment Share on other sites More sharing options...
B C Posted July 12, 2019 Report Share Posted July 12, 2019 times are hard Quote Link to comment Share on other sites More sharing options...
gilber33 Posted July 17, 2019 Author Report Share Posted July 17, 2019 Engine is back in the car with the stock flywheel. The lightweight one will be for sale. Just need to work on the driveshaft stuff And of course the update on the playhouse. It’s sided and partially painted. Tonight I will be making and staining the shutters and door so I can seal it up to finish the inside. Jdesign and KaiserRolls 2 Quote Link to comment Share on other sites More sharing options...
Jdesign Posted July 17, 2019 Report Share Posted July 17, 2019 I was hoping to see the engine in the play house, but I guess dreamers will be dreamers. Nice hustle on getting all that stuff done. KaiserRolls 1 Quote Link to comment Share on other sites More sharing options...
gilber33 Posted July 17, 2019 Author Report Share Posted July 17, 2019 2 hours ago, Jdesign said: I was hoping to see the engine in the play house, but I guess dreamers will be dreamers. Nice hustle on getting all that stuff done. Thank you! It’s been exhausting. I’ve also framed and sheathed the shed between these two projects. Sometimes I think I started too much at once this time around.😩 Quote Link to comment Share on other sites More sharing options...
gilber33 Posted July 18, 2019 Author Report Share Posted July 18, 2019 So tonight I was going to replace the giubo and the one I got was too large. After digging around I learned that the one on my car is for an auto. Last time I checked my car is definitely manual. I know the PO replaces the diff, but, how else would this be? Gab01-009 is the auto giubo and gab01-017 is the manual giubo Also, is this an issue?? Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted July 18, 2019 Report Share Posted July 18, 2019 Ditch that tumor of a damper Quote Link to comment Share on other sites More sharing options...
straight6pwr Posted July 18, 2019 Report Share Posted July 18, 2019 what do you mean by 'too large'? realoem cross references the same giubo to nearly every every e30: https://www.realoem.com/bmw/enUS/partxref?id=1123-USA-02-1990-E30-BMW-325i&mg=26&sg=10&diagId=26_0023&q=26111225624&series=E30 in any case, as long as the bolt hole locations are the same, either one will work. the driveshaft splines takes up the difference if one is thicker. Quote Link to comment Share on other sites More sharing options...
