SteelBlue Posted May 13, 2019 Report Share Posted May 13, 2019 13 hours ago, B C said: in the E46 world, that drivetrain noise is referred to as the “M Clunk”. The LSDs really can be that noisy Or when the subframe is tearing the floor out of the car 😶 Quote Link to comment Share on other sites More sharing options...
gilber33 Posted May 13, 2019 Author Report Share Posted May 13, 2019 2 hours ago, Boris3 said: Reason I asked is that if these are shot it can also cause the clunk. Differential bolts to the subframe are all tight? They should be. My hope is to pull the driveline out and do new guibo, CSB, diff mount bushing, and rear subframe bushings. 1 hour ago, SteelBlue said: Or when the subframe is tearing the floor out of the car 😶 Ew Quote Link to comment Share on other sites More sharing options...
gilber33 Posted May 15, 2019 Author Report Share Posted May 15, 2019 Love comparing the size of older cars to newer ones. Also started cleaning up the head from the next engine. I should have taken some before pics because it was very gross. Quote Link to comment Share on other sites More sharing options...
gilber33 Posted May 16, 2019 Author Report Share Posted May 16, 2019 I am probably going to take this block in to get honed, but in order to do so I need to remove these things. I believe one drives the oil pump and the other is the oil pressure sending unit. I know the gear for the oil pump can not just be remover and reinstalled, but can this little piece pop out? And how do I remove the oil pressure unit? Quote Link to comment Share on other sites More sharing options...
B C Posted May 16, 2019 Report Share Posted May 16, 2019 That aluminum bit is an oil pressure relief valve. You can remove it, no problem, with a 22 or 24 mm wrench or whatever it is. Theres just a loose spring on the other side. the oil pump drive shaft can be removed via the recessed cap with the bmw logo on it. Make sure you do not forget to put that part in! Ive read a couple threads of people anxiously firing up the engine and quickly realizing they forgot a part. You should also use a drill and a 6/8mm socket on the other end of the shaft (the end under the bmw cap) to prime the oil pump and preoil the engine before startup Quote Link to comment Share on other sites More sharing options...
jc43089 Posted May 16, 2019 Report Share Posted May 16, 2019 Do NOT remove the intermediate shaft bearings unless there is something wrong with them. Replacement is not an easy task. They need to be honed to size after installation. Quote Link to comment Share on other sites More sharing options...
gilber33 Posted May 16, 2019 Author Report Share Posted May 16, 2019 1 hour ago, jc43089 said: Do NOT remove the intermediate shaft bearings unless there is something wrong with them. Replacement is not an easy task. They need to be honed to size after installation. I'm not removing that. I just need to know if it's okay to remove this rod without doing anything crazy to reinstall it. Quote Link to comment Share on other sites More sharing options...
jc43089 Posted May 17, 2019 Report Share Posted May 17, 2019 On 5/16/2019 at 9:48 AM, gilber33 said: I'm not removing that. I just need to know if it's okay to remove this rod without doing anything crazy to reinstall it. It should just pull out. But it's been a while since I built an M20. You can take the intermediate shaft out for cleaning and stuff just the bearings should stay in place. Quote Link to comment Share on other sites More sharing options...
gilber33 Posted May 20, 2019 Author Report Share Posted May 20, 2019 Cars and Coffee in Cedarburg. Fit both car seats in the back seat! They fit much better than I thought they would. Jdesign 1 Quote Link to comment Share on other sites More sharing options...
Jdesign Posted May 22, 2019 Report Share Posted May 22, 2019 Looks great! Quote Link to comment Share on other sites More sharing options...
gilber33 Posted May 23, 2019 Author Report Share Posted May 23, 2019 23 hours ago, Jdesign said: Looks great! Thank you! Started assembling the head last night. Got a bunch of dremel buffing pads which made cleaning the valves and head pretty easy work. Dusty and dirty. But easy. Jdesign and P_Roloff 2 Quote Link to comment Share on other sites More sharing options...
gilber33 Posted May 24, 2019 Author Report Share Posted May 24, 2019 Looking for some insight here. Pulled the pistons out last night. My plan was have the block honed and then do new rings and bearings. There's some light scratches on the side skirts - you can't feel them. There's also no vertical scratches on the cylinder walls and the cross hatching is still very visible. I've read to take an emery clutch or scotch Brite pad or something to clean up the pistons. Think I'm okay to move forward with my plan? Quote Link to comment Share on other sites More sharing options...
B C Posted May 24, 2019 Report Share Posted May 24, 2019 The one side of the piston is a bit more scuffing that I have usually seen on an M20. When I asked the machinist/engine builder about it he said it is no concern/as long as the cylinder bores are clean. Quote Link to comment Share on other sites More sharing options...
gilber33 Posted May 24, 2019 Author Report Share Posted May 24, 2019 9 minutes ago, B C said: The one side of the piston is a bit more scuffing that I have usually seen on an M20. When I asked the machinist/engine builder about it he said it is no concern/as long as the cylinder bores are clean. That's kind of what I've read too. The cylinders are all clean and there are no visible vertical scratches in them. The cylinder I took pictures of is the cylinder that 2nd piston came out of. Quote Link to comment Share on other sites More sharing options...
jc43089 Posted May 24, 2019 Report Share Posted May 24, 2019 Just polish them up and use new rings. Check the ring gaps. The cylinders look nice. Any lip at the top where the rings don't touch? Quote Link to comment Share on other sites More sharing options...
gilber33 Posted May 24, 2019 Author Report Share Posted May 24, 2019 13 minutes ago, jc43089 said: Just polish them up and use new rings. Check the ring gaps. The cylinders look nice. Any lip at the top where the rings don't touch? Zero lip on the cylinders. They're in really good shape, which is why I just wanted to hone, new rings and bearings and put it back together. I've never done a full rebuild on an engine before, so there's really no reason for this other than its something I've wanted to do. And the m20 is so affordable to rebuild. Quote Link to comment Share on other sites More sharing options...
jc43089 Posted May 24, 2019 Report Share Posted May 24, 2019 3 minutes ago, gilber33 said: Zero lip on the cylinders. They're in really good shape, which is why I just wanted to hone, new rings and bearings and put it back together. I've never done a full rebuild on an engine before, so there's really no reason for this other than its something I've wanted to do. And the m20 is so affordable to rebuild. The cast iron used is very high quality. The one I rebuilt that had unknown miles higher than 280k before the odometer quit working still had no lip at all and just needed a light honing and new rings. Quote Link to comment Share on other sites More sharing options...
gilber33 Posted May 29, 2019 Author Report Share Posted May 29, 2019 Crank out. Block mating surface cleaned up. And valves are all lapped. Next I’ll pull the block out into the driveway and pressure wash and then drop it off to get honed. Finish assembling the head. I think I’d like to get this back together before December so it can go into the car between the end of year and next June. Some big life events that will make car time limited. SteelBlue, P_Roloff and Jdesign 3 Quote Link to comment Share on other sites More sharing options...
gilber33 Posted May 30, 2019 Author Report Share Posted May 30, 2019 Took a pressure washer to the block tonight. rampelsauce and Jdesign 2 Quote Link to comment Share on other sites More sharing options...
gilber33 Posted June 4, 2019 Author Report Share Posted June 4, 2019 My clunky drivetrain is getting a little clunkier. Gonna jack it up and check the mounts and make sure nothing’s loose. If there’s nothing obvious then looks like I’ll be tackling guibo, CSB, and diff bushing. Edit - checked the engine mounts, transmission mounts, guibo bolts... all tight. So, I’m not sure. It has gotten progressively worse. It used to be a single clunk where now it several. Happens when I’m rolling slow and push the clutch pedal in. Really sounds like it’s coming from the transmission/clutch. Quote Link to comment Share on other sites More sharing options...
Jdesign Posted June 4, 2019 Report Share Posted June 4, 2019 Axles? CSB is backwards? Diff is loose? My diff was backing the bolts out all the time and then I realized the CSB was backwards. 🤔 Quote Link to comment Share on other sites More sharing options...
gilber33 Posted June 4, 2019 Author Report Share Posted June 4, 2019 2 hours ago, Jdesign said: Axles? CSB is backwards? Diff is loose? My diff was backing the bolts out all the time and then I realized the CSB was backwards. 🤔 Sounds like it’s coming from the front, I’m going to assume it’s not axles. It happens when I push clutch in while rolling slowly, so the only “jerky” movements happening to the car is the clutch. It’s not like I’m engaging the clutch and the car jerks where there could be noises generated from play in axles or something. If that makes sense. That’s why I think it’s something with the clutch. Flywheel coming loose or something. Jdesign 1 Quote Link to comment Share on other sites More sharing options...
SteelBlue Posted June 5, 2019 Report Share Posted June 5, 2019 4 hours ago, gilber33 said: Sounds like it’s coming from the front, I’m going to assume it’s not axles. It happens when I push clutch in while rolling slowly, so the only “jerky” movements happening to the car is the clutch. It’s not like I’m engaging the clutch and the car jerks where there could be noises generated from play in axles or something. If that makes sense. That’s why I think it’s something with the clutch. Flywheel coming loose or something. Guess everyone’s dropping their transmissions this summer Quote Link to comment Share on other sites More sharing options...
gilber33 Posted June 5, 2019 Author Report Share Posted June 5, 2019 18 hours ago, SteelBlue said: Guess everyone’s dropping their transmissions this summer I just wanted to be like the cool kids. Quote Link to comment Share on other sites More sharing options...
gilber33 Posted June 11, 2019 Author Report Share Posted June 11, 2019 Has anyone done a removable core support on their e30? As I get ready to pull the engine for the 3rd time to check the clutch and to put in the rebuilt m20, a removable core support sounds awfully tempting. Quote Link to comment Share on other sites More sharing options...
