gilber33 Posted September 7, 2019 Author Report Share Posted September 7, 2019 I cannot find any non oil-free ones within what I want to spend. Those seem to be in the more expensive range of compressors. I’ll keep looking though. Quote Link to comment Share on other sites More sharing options...
jc43089 Posted September 9, 2019 Report Share Posted September 9, 2019 You should look into a used one. I bought mine used for 60$ I think. Here are a couple in my area, just watch craigslist. You can get a lot more for your money. Then you will have some money left for a filter/regulator setup. An oil free compressor will not last long under hard usage like painting. https://wausau.craigslist.org/for/d/stevens-point-air-compressor/6972619791.html https://wausau.craigslist.org/tls/d/port-edwards-roll-air-compressor/6949521027.html Why can you not do a 240V unit? You can buy used ones for cheap and they are so much more powerful. If you need advice about wiring it I am a master electrician, it's not hard at all. Quote Link to comment Share on other sites More sharing options...
gilber33 Posted September 9, 2019 Author Report Share Posted September 9, 2019 9 hours ago, jc43089 said: You should look into a used one. I bought mine used for 60$ I think. Here are a couple in my area, just watch craigslist. You can get a lot more for your money. Then you will have some money left for a filter/regulator setup. An oil free compressor will not last long under hard usage like painting. https://wausau.craigslist.org/for/d/stevens-point-air-compressor/6972619791.html https://wausau.craigslist.org/tls/d/port-edwards-roll-air-compressor/6949521027.html Why can you not do a 240V unit? You can buy used ones for cheap and they are so much more powerful. If you need advice about wiring it I am a master electrician, it's not hard at all. Because my garage is wired for 120v and it’s detached from the house. There’s this one locally to me: https://milwaukee.craigslist.org/tls/d/waukesha-speedaire-air-compressor/6966869481.html I assume that 4.9 scfm @ 100psi would mean that it’s well above 6 scfm @ 40psi Quote Link to comment Share on other sites More sharing options...
jc43089 Posted September 10, 2019 Report Share Posted September 10, 2019 Perfect time to bury a feeder for 40-60 amps and have MORE POWAAAAAAAA! That looks alright, maybe on the high side of price for a used compressor. Check this one out. My small one is a Puma and it has been working great for many years. This one is belt drive which means it will be quieter than the direct drive units. https://milwaukee.craigslist.org/tls/d/germantown-puma-air-compressor/6963043391.html Here is a listing for a new one 450$. It says 3.8 @ 40 and 3 @ 90. It seems like it would pump more than that but with additional storage it would work well. I think Napa also sells Puma compressors. https://www.aircompressorsdirect.com/Puma-PK2011VP-Air-Compressor/p11112.html Quote Link to comment Share on other sites More sharing options...
gilber33 Posted September 10, 2019 Author Report Share Posted September 10, 2019 21 minutes ago, jc43089 said: Perfect time to bury a feeder for 40-60 amps and have MORE POWAAAAAAAA! That looks alright, maybe on the high side of price for a used compressor. Check this one out. My small one is a Puma and it has been working great for many years. This one is belt drive which means it will be quieter than the direct drive units. https://milwaukee.craigslist.org/tls/d/germantown-puma-air-compressor/6963043391.html Here is a listing for a new one 450$. It says 3.8 @ 40 and 3 @ 90. It seems like it would pump more than that but with additional storage it would work well. I think Napa also sells Puma compressors. https://www.aircompressorsdirect.com/Puma-PK2011VP-Air-Compressor/p11112.html If you want to come over and tell my wife that I’m going to spend a weekend running new wire out to the garage so I can have a more powerful compressor to have more capabilities to paint my car and she’ll need to watch our 3yo and 1yo while 6mos pregnant by herself you’re more than welcome to. Lol. I have 120 now and I’m going to work within the parameters of what I have. And I did see that one in Germantown but when I looked up the specs, I found the scfm is really low. Seems like it should pump out more than that, but I’m not risking it. Quote Link to comment Share on other sites More sharing options...
jc43089 Posted September 10, 2019 Report Share Posted September 10, 2019 1 hour ago, gilber33 said: If you want to come over and tell my wife that I’m going to spend a weekend running new wire out to the garage so I can have a more powerful compressor to have more capabilities to paint my car and she’ll need to watch our 3yo and 1yo while 6mos pregnant by herself you’re more than welcome to. Lol. I have 120 now and I’m going to work within the parameters of what I have. And I did see that one in Germantown but when I looked up the specs, I found the scfm is really low. Seems like it should pump out more than that, but I’m not risking it. I can relate, and buying the wire, breakers, panel etc would be at least 300$ depending on how far you have to go. That one you linked does look good, when you go get it check if it has water in the tank, that might indicate if the owner usually drained it after use or left it with water inside to rust. Those older ones like that are built heavy duty, not like the newer throwaway stuff. Quote Link to comment Share on other sites More sharing options...
gilber33 Posted September 10, 2019 Author Report Share Posted September 10, 2019 34 minutes ago, jc43089 said: I can relate, and buying the wire, breakers, panel etc would be at least 300$ depending on how far you have to go. That one you linked does look good, when you go get it check if it has water in the tank, that might indicate if the owner usually drained it after use or left it with water inside to rust. Those older ones like that are built heavy duty, not like the newer throwaway stuff. It’s about 40 feet to the garage. Plus another 30 feet from the house to the panel. My one concern is the compressor only says what the rating is at 100psi. So how do I know it’s going to be sufficient at 40psi? I ASSUME it will be, but is there a way to know? Quote Link to comment Share on other sites More sharing options...
jc43089 Posted September 10, 2019 Report Share Posted September 10, 2019 30 minutes ago, gilber33 said: It’s about 40 feet to the garage. Plus another 30 feet from the house to the panel. My one concern is the compressor only says what the rating is at 100psi. So how do I know it’s going to be sufficient at 40psi? I ASSUME it will be, but is there a way to know? The ratio is not fixed because it changes based on the compressor dimension bore x stroke will change the compression ratio. But it is usually somewhat higher so i would think it would be fine, also I saw on craigslist several portable tanks for cheap (usually old oil free air compressors that failed and the compressor is removed) I got my 30 gallon upright tank for 20$ and it is a nice wheeled one from a craftsman compressor. I will try to take some pictures of how I plumbed it to be easy to fill and then use the air, just having it between the compressor and my tools eliminates a lot of moisture at the point of use because it has time to cool and condense. Quote Link to comment Share on other sites More sharing options...
gilber33 Posted September 11, 2019 Author Report Share Posted September 11, 2019 On 9/10/2019 at 9:24 AM, jc43089 said: The ratio is not fixed because it changes based on the compressor dimension bore x stroke will change the compression ratio. But it is usually somewhat higher so i would think it would be fine, also I saw on craigslist several portable tanks for cheap (usually old oil free air compressors that failed and the compressor is removed) I got my 30 gallon upright tank for 20$ and it is a nice wheeled one from a craftsman compressor. I will try to take some pictures of how I plumbed it to be easy to fill and then use the air, just having it between the compressor and my tools eliminates a lot of moisture at the point of use because it has time to cool and condense. I'm likely picking up that Speedaire compressor and my Dad has a 20 gallon tank sitting in his shop that he doesn't use. I'll build a little rack for the compressor and tank and plumb them together with an inline dryer. At the end of the day I'll have an oil-lubricated compressor with about 40 gallons of air. Should be sufficient to do what I want with it. It will also be nice to get some air tools again. Jdesign 1 Quote Link to comment Share on other sites More sharing options...
jc43089 Posted September 11, 2019 Report Share Posted September 11, 2019 Awesome, that will be a good setup. It will have no trouble running impacts, die grinders etc all day. The right tools sure speeds up projects. Quote Link to comment Share on other sites More sharing options...
gilber33 Posted September 12, 2019 Author Report Share Posted September 12, 2019 21 hours ago, jc43089 said: Awesome, that will be a good setup. It will have no trouble running impacts, die grinders etc all day. The right tools sure speeds up projects. Any benefit to using pipe VS hose to hook the two tanks together? Obviously using some short sections of hose and fittings would be much easier. Quote Link to comment Share on other sites More sharing options...
straight6pwr Posted September 12, 2019 Report Share Posted September 12, 2019 guyz, https://www.painttalk.com/ i keep coming for e30 content, and find none. jk, carry on Jdesign 1 Quote Link to comment Share on other sites More sharing options...
gilber33 Posted September 12, 2019 Author Report Share Posted September 12, 2019 This is the building blocks for additional e30 content. Quote Link to comment Share on other sites More sharing options...
straight6pwr Posted September 12, 2019 Report Share Posted September 12, 2019 4 minutes ago, gilber33 said: This is the building blocks for additional e30 content. jc43089, Jdesign and m42b32 2 1 Quote Link to comment Share on other sites More sharing options...
jc43089 Posted September 12, 2019 Report Share Posted September 12, 2019 4 hours ago, gilber33 said: Any benefit to using pipe VS hose to hook the two tanks together? Obviously using some short sections of hose and fittings would be much easier. You could, I use hose because it is portable and easily reconfigured. I usually use a pretty short hose between the compressor and extra tank, it flows pretty fast even with a regular 3/8" hose that is 25' long. I like to fill the portable tank and then unhook the hose and drain the compressor. Then I can use the tank on wheels for airing up tires and little things until the pressure is too low and it needs filling again. I would recommend thread sealant like Rectorseal 5 to make a perfectly leak free system. Thread tape can be ok but sometimes leaks. You can get a jar for a couple bucks at my store. Quote Link to comment Share on other sites More sharing options...
gilber33 Posted September 12, 2019 Author Report Share Posted September 12, 2019 19 minutes ago, jc43089 said: You could, I use hose because it is portable and easily reconfigured. I usually use a pretty short hose between the compressor and extra tank, it flows pretty fast even with a regular 3/8" hose that is 25' long. I like to fill the portable tank and then unhook the hose and drain the compressor. Then I can use the tank on wheels for airing up tires and little things until the pressure is too low and it needs filling again. I would recommend thread sealant like Rectorseal 5 to make a perfectly leak free system. Thread tape can be ok but sometimes leaks. You can get a jar for a couple bucks at my store. I’ll use regular hose. I’m going to build a rack that will stack the 2nd tank on top of the compressor, so the hose will only be a couple feet connecting the two. First tank acquired though! Quote Link to comment Share on other sites More sharing options...
REKIII Posted September 12, 2019 Report Share Posted September 12, 2019 You will want at lease a short section of flexible. The aircompressor vibrates when running....a lot, the expansion tank wont. The vibration load on the connection, if all solid, will cause something to crack at some point. gilber33 and Jdesign 1 1 Quote Link to comment Share on other sites More sharing options...
gilber33 Posted September 12, 2019 Author Report Share Posted September 12, 2019 15 minutes ago, REKIII said: You will want at lease a short section of flexible. The aircompressor vibrates when running....a lot, the expansion tank wont. The vibration load on the connection, if all solid, will cause something to crack at some point. That’s a really good point. I didn’t think of that. I’ll use regular compressor hose since the distance will be so short. Quote Link to comment Share on other sites More sharing options...
gilber33 Posted September 13, 2019 Author Report Share Posted September 13, 2019 Got it all home. Jdesign 1 Quote Link to comment Share on other sites More sharing options...
straight6pwr Posted September 13, 2019 Report Share Posted September 13, 2019 #wagonlife those tie-down rails are awesome. thats volvo right? Quote Link to comment Share on other sites More sharing options...
gilber33 Posted September 13, 2019 Author Report Share Posted September 13, 2019 18 minutes ago, straight6pwr said: #wagonlife those tie-down rails are awesome. thats volvo right? They really are. I use them pretty regularly. And yes, ‘08 Volvo XC70. Quote Link to comment Share on other sites More sharing options...
gilber33 Posted September 14, 2019 Author Report Share Posted September 14, 2019 How about some e30 content? All cleaned up for Road America tomorrow. The Full Banana, SteelBlue, straight6pwr and 3 others 5 1 Quote Link to comment Share on other sites More sharing options...
SteelBlue Posted September 15, 2019 Report Share Posted September 15, 2019 23 hours ago, gilber33 said: How about some e30 content? All cleaned up for Road America tomorrow. Great weather for being at the track. One of the few events I didn’t make it to this year. Hopefully you got to see the F1 cars run. Judd V10s ♥️ Quote Link to comment Share on other sites More sharing options...
gilber33 Posted September 17, 2019 Author Report Share Posted September 17, 2019 It was a lot of fun and my girls enjoyed it which is always awesome. Tonight I got the air compressor hooked up. Not super thrilled with the overall look of it but it will be fine until I redo the garage next year. I still need to do some hose management, so please ignore the crazy hoses. SteelBlue and jc43089 2 Quote Link to comment Share on other sites More sharing options...
gilber33 Posted September 24, 2019 Author Report Share Posted September 24, 2019 Been driving the car to work once in a while and I've noticed that the oil pressure light stays on for a couple seconds on cold starts. I'm going to get a new oil pressure sensor, but I'm just curious what people's thoughts are? It didn't always do this. I remember it turning of instantly - I think even with this engine when I first got it back in. Quote Link to comment Share on other sites More sharing options...
