Jump to content
Sign in to follow this
WTB E36 Hitch or a BMW with a hitch.
6 hours ago, snap said:
WOW. Thats surprisingly cheap, but I dont think it will be strong enough.
Also its only a 1.25" and not a 2"
I think I might need to buy one for a truck and make some modifications.
Share this post
Link to post
Share on other sites
You would probably be best to make something custom, those only sandwich through the spare tire well floor.  My thought would be to sandwich the floor and also support it from the bumper mounts to add some tongue weight capacity.
Share this post
Link to post
On 5/15/2018 at 4:59 PM, straight6pwr said:
if you want 2", its going to have to be custom.
the stock BMW 'horsecock' hitch has no receiver.
any aftermarket Curt or equiv. is going to be 1.25" or just a draw bar.
welding on a universal 2" receiver will be child's play for you, though.
Thanks guys, now I know. I was looking into van receivers as I think the width is the same at the bumper mounts. I could cut the chassis and slide the ends into teh frame, then weld the plates and run bolts through the arms and frame rails. I dont plan on pulling too much weight, but I also dont want it to fail.
Share this post
Link to post
A class 2 or 3 hitch bolted to your frame should support/pull more weight than what an e36 is safely rated for. I wonder if you can find one the same width as the e36 frame rails and just drill some holes vertically through the frame? Since you probably don't care where the receiver protrudes through the bumper I'd guess that's the easiest way.
Share this post
Link to post
Thats the plan!!
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
