retoropak Posted January 19, 2018 Report Share Posted January 19, 2018 I am planning to build my m10 this summer. I will be shooting for 400whp on e85 I have two options. Option 1 using 92x82 vw type 1 pistons and s14 rods Bore:92mmStroke:80mmS14 Rods: 144mm Deck height:217.5mmCompression height:35mmHeadgasket thickness:1.5 or 1.8mmCombustion chamber volume:63 ccCompression ratio: 9.25:1 With this setup pistons will be sticking put approximately 1.5mm out of hole. With the 1.8mm gasket i should have 0.3mm clarance. Or I could mill 1.5mm from top of the piston and zero deck it which will result in compression 8.25:1 ratio Option 2 using 92x69 vw type 1 pistons and m10 rods Bore:92mmStroke:80mmM10 Rods: 135mm Deck height:217.5mm- 2.7mm= 214.8Compression height:39.8mmHeadgasket thickness:1.5 or 1.8mmCombustion chamber volume:63 ccCompression ratio: 8.25:1 I would have to deck the block 2.5-2.7mm to get it "zero decked" What would you rather do? Deck the block and use shorter rods or mill the pistons and use longer rods? Or maybe let the pistons stick out the holes and use 1.8mm gasket but it will give me only 0.3mm clearance. Thanks Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
0 B C Posted January 19, 2018 Report Share Posted January 19, 2018 I will never boost another engine with stock pistons. With very old used pistons you start off right away at a disadvantage being that the ringlands have been cycled and are closer to fatigue failure than new (as you know, aluminum doesn’t have an endurance limit)Get some forged pistons and you can specify all the parameters you want to. Quote Link to comment Share on other sites More sharing options...
0 retoropak Posted January 19, 2018 Author Report Share Posted January 19, 2018 I will never boost another engine with stock pistons. With very old used pistons you start off right away at a disadvantage being that the ringlands have been cycled and are closer to fatigue failure than new (as you know, aluminum doesn’t have an endurance limit)Get some forged pistons and you can specify all the parameters you want to. Thats the plan to get the vw type 1 forged JEs or Mahles.Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
0 straight6pwr Posted January 19, 2018 Report Share Posted January 19, 2018 boost advice from this forum? B C and jc43089 1 1 Quote Link to comment Share on other sites More sharing options...
0 retoropak Posted January 19, 2018 Author Report Share Posted January 19, 2018 What boost? Lets assume i am building NA 100hp 2.1 liter m10 for now. Lets get back to the question. A. Deck the block to achieve zero deckB. Mill the pistons to get the zero deckC. Let the pistons poke out the block and use thicker HG Also the reason for the vw type 1 pistons is that they are cheap. $350-420 for a set of four forged mahles or JEs is really attractive when you compare it to a 800-1000 for a set of custom ones Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
0 HipMF Posted January 19, 2018 Report Share Posted January 19, 2018 If your planning on making 100hp per hole I wouldn't think taking 1/8" off the deck is a good idea. Loss of rigidity in that area could make HG sealing an issue. I'd spend the extra money to get pistons made... Bassboy3313 1 Quote Link to comment Share on other sites More sharing options...
0 retoropak Posted January 19, 2018 Author Report Share Posted January 19, 2018 How about milling 1.5mm from the piston? They are claiming the got some extra meat to allow for valve pocketshttps://aapistons.com/collections/piston-liner-kits-sets/products/vw-92mm-2180cc-racing-forged-piston-kitSent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
0 B C Posted January 19, 2018 Report Share Posted January 19, 2018 paging @Jeff who just dealt with this predicament on his M50B32 build. Quote Link to comment Share on other sites More sharing options...
0 Daggerty Posted January 20, 2018 Report Share Posted January 20, 2018 I would use the thicker headgasket. If you are running e85 stick with the higher compression. If for whatever reason you want to switch it up you can always tear it down with the HG. Shaving the piston however you can not. People may say you are doing it the hack way by using the thicker HG, but you are just doing it different than oem. There is more than one way to microwave a cat. Bassboy3313 and B C 2 Quote Link to comment Share on other sites More sharing options...
0 HipMF Posted January 20, 2018 Report Share Posted January 20, 2018 3 hours ago, retoropak said: How about milling 1.5mm from the piston? They are claiming the got some extra meat to allow for valve pocketshttps://aapistons.com/collections/piston-liner-kits-sets/products/vw-92mm-2180cc-racing-forged-piston-kit Sent from my iPhone using Tapatalk Maybe... I'd want a drawing or something more to go on than the blurb. If that's a picture of the actual kit, I'd check on the pins too. I know when you order custom pistons, you can choose different pins for lightweight/high rpm, or something a bit more stout for boosted applications. Good luck with the project btw. I've read a lot about engine building over the years, but don't have much experience myself. Some day I'd like to get crazy with the cheez whiz and build something cool like this. Quote Link to comment Share on other sites More sharing options...
0 Jeff Posted January 20, 2018 Report Share Posted January 20, 2018 paging [mention=2756]Jeff[/mention] who just dealt with this predicament on his M50B32 build. Hello? Quote Link to comment Share on other sites More sharing options...
0 Jeff Posted January 20, 2018 Report Share Posted January 20, 2018 Was this your issue? Quote Link to comment Share on other sites More sharing options...
0 retoropak Posted January 22, 2018 Author Report Share Posted January 22, 2018 Was this your issue?Yup exactly.Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
0 Jeff Posted January 23, 2018 Report Share Posted January 23, 2018 Well instead of machining the top of the piston and the valve reliefs down I made a custom MLS head gasket to keep valve clearances tolerable. Also made longer dowels for the Cylinder head alignment. I am not ver familiar with the M10 engine. A few things to keep in mind is make sure you have The extra slack in the timing chain or belt. Try to keep enough clearance between the valves and piston for thermal expansion. Quote Link to comment Share on other sites More sharing options...
0 6inarowmakesitgo! Posted January 31, 2018 Report Share Posted January 31, 2018 Jeff has very solid advice here. Distance between crank and cam centerlines is quite critical in maintaining proper tolerances so your pistons do not eat the valves for lunch, preventing detonation during periods of high load with low(ish) RPM etc etc. Also, Get the Mahle or JE custom pistons, W do it right the first time and then smack the redline silly with the tach needle for years to come. Wiseco also makes a decent product. I opted for factory Goetze rings when putting my M30B34 back together and she purrs like a kitten. Quote Link to comment Share on other sites More sharing options...
Question
retoropak
I have two options.
Bore:92mm
Stroke:80mm
S14 Rods: 144mm
Deck height:217.5mm
Bore:92mm
Stroke:80mm
M10 Rods: 135mm
Thanks
Link to comment
14 answers to this question
