SteelBlue Posted April 13, 2019 Report Share Posted April 13, 2019 As I think @Jdesign had said, reps now a days are so good it’s kind of non issue for most uses unless you are a wheel purist. Very excited to see dyno numbers, any predictions? Quote Link to comment Share on other sites More sharing options...
AsparagusMike Posted April 14, 2019 Author Report Share Posted April 14, 2019 4 hours ago, B C said: This setup will ruin you and nothing will ever be fast enough ever again 😁 I sure hope so 1 hour ago, SteelBlue said: As I think @Jdesign had said, reps now a days are so good it’s kind of non issue for most uses unless you are a wheel purist. Very excited to see dyno numbers, any predictions? Only thing I can say about legit wheels is the weight being a bit less. I think these ones come in just around 18.5 lbs which is pretty hefty but they seem beefy and capable so whatev's. Hoping for middle 300's hp, anything better then 330 and I'll be pretty happy. Quote Link to comment Share on other sites More sharing options...
B C Posted April 14, 2019 Report Share Posted April 14, 2019 @DrLeadFoot did just about 500whp on 18-21psi on his S52, and that was on an OBD2 chip tune. That setup was uncomfortably fast 😯 DrLeadFoot 1 Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted April 15, 2019 Report Share Posted April 15, 2019 On 4/13/2019 at 9:25 PM, B C said: @DrLeadFoot did just about 500whp on 18-21psi on his S52, and that was on an OBD2 chip tune. That setup was uncomfortably fast 😯 Obd1 tune. Very bad tune 😥 Quote Link to comment Share on other sites More sharing options...
AsparagusMike Posted April 16, 2019 Author Report Share Posted April 16, 2019 patsbimmer1, jc43089, SteelBlue and 3 others 6 Quote Link to comment Share on other sites More sharing options...
jc43089 Posted April 16, 2019 Report Share Posted April 16, 2019 Excellent! Quote Link to comment Share on other sites More sharing options...
B C Posted April 16, 2019 Report Share Posted April 16, 2019 baseline run? or final result? either way 300whp in an E30 is no joke! Quote Link to comment Share on other sites More sharing options...
AsparagusMike Posted April 16, 2019 Author Report Share Posted April 16, 2019 35 minutes ago, B C said: baseline run? or final result? either way 300whp in an E30 is no joke! Final result. 330hp 316 tq 0n 8.5 psi at around 6000 rpm SteelBlue, P_Roloff, B C and 4 others 7 Quote Link to comment Share on other sites More sharing options...
B C Posted April 16, 2019 Report Share Posted April 16, 2019 I like the Quiznos "NOS" sign in the video. Let us know your driving impressions! Jdesign 1 Quote Link to comment Share on other sites More sharing options...
YoungCR Posted April 16, 2019 Report Share Posted April 16, 2019 300hp looks and sounds fun. Get some miles on it! Jdesign 1 Quote Link to comment Share on other sites More sharing options...
GunMetalGrey Posted April 29, 2019 Report Share Posted April 29, 2019 I got a ride / drove this car this weekend. Holy balls batman, it is sweet. The car feels so good. It is smooth, the power delivery is smooth and linear, and the chassis feels great due to all the work Mike has put into it. And man does it rip, any gear, any rpm, you lean in the throttle and are immediately doing well over the posted speed limit. Great work Mike! straight6pwr, B C, P_Roloff and 1 other 4 Quote Link to comment Share on other sites More sharing options...
straight6pwr Posted April 29, 2019 Report Share Posted April 29, 2019 winning! Quote Link to comment Share on other sites More sharing options...
B C Posted April 29, 2019 Report Share Posted April 29, 2019 well done my friend! picnic or bust? timmer and GunMetalGrey 2 Quote Link to comment Share on other sites More sharing options...
AsparagusMike Posted April 30, 2019 Author Report Share Posted April 30, 2019 22 hours ago, B C said: well done my friend! picnic or bust? Yup I should be able to make it. P_Roloff 1 Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted May 1, 2019 Report Share Posted May 1, 2019 What turbo and manifold are you running again? Edit: did you get a tq curve print out as well? Quote Link to comment Share on other sites More sharing options...
AsparagusMike Posted May 1, 2019 Author Report Share Posted May 1, 2019 Holset HX35 on a Rapid spool manifold I suppose I should have posted this graph earlier, oops. KaiserRolls 1 Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted May 1, 2019 Report Share Posted May 1, 2019 Sweet thanks veggiemike would be interested in seeing that msq file 😉 manual boost controller? Electronic? Or just straight spranging it with boost reference directly to gate? Quote Link to comment Share on other sites More sharing options...
AsparagusMike Posted May 2, 2019 Author Report Share Posted May 2, 2019 14 hours ago, KaiserRolls said: would be interested in seeing that msq file 😉 manual boost controller? Electronic? Or just straight spranging it with boost reference directly to gate? Check your pm's Electronic boost controller Quote Link to comment Share on other sites More sharing options...
GunMetalGrey Posted May 5, 2019 Report Share Posted May 5, 2019 If you're sending those MSQ's around feel free to hit a brother up! Also, I think I know where your oil is going. Watched the dyno pull vid and saw the let off cloud Quote Link to comment Share on other sites More sharing options...
AsparagusMike Posted May 6, 2019 Author Report Share Posted May 6, 2019 23 hours ago, GunMetalGrey said: Also, I think I know where your oil is going. Watched the dyno pull vid and saw the let off cloud Ya No doubt my car is consuming a bit of oil. I have been monitoring it frequently though and it doesn't seem to be much worse then it was when the motor was NA. About a quart every 1000 miles... 1/4 of a quart give or take every 2 tanks of gas or 300 miles.😁 Quote Link to comment Share on other sites More sharing options...
B C Posted May 6, 2019 Report Share Posted May 6, 2019 Do you have an oil restrictor in the oil feed line? Quote Link to comment Share on other sites More sharing options...
AsparagusMike Posted May 6, 2019 Author Report Share Posted May 6, 2019 1 minute ago, B C said: Do you have an oil restrictor in the oil feed line? Not that I know of Quote Link to comment Share on other sites More sharing options...
B C Posted May 6, 2019 Report Share Posted May 6, 2019 That could certainly be part of it Quote Link to comment Share on other sites More sharing options...
AsparagusMike Posted May 6, 2019 Author Report Share Posted May 6, 2019 Ok I lied, I actually do lol GunMetalGrey and Jdesign 1 1 Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted May 6, 2019 Report Share Posted May 6, 2019 Are you running a catch can setup? Or stock style pcv system? Quote Link to comment Share on other sites More sharing options...
