KaiserRolls Posted April 29, 2020 Report Share Posted April 29, 2020 Shit. Meant to type 225. I blame the NyQuil m42b32 1 Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted April 29, 2020 Report Share Posted April 29, 2020 2 minutes ago, m42b32 said: Found the sizes on tirerack, a few options for us e30 folks! Yes the 225/45-15 is calling my name. Supposedly more sizes are going to be released as well m42b32 1 Quote Link to comment Share on other sites More sharing options...
m42b32 Posted April 29, 2020 Report Share Posted April 29, 2020 Just now, KaiserRolls said: Yes the 225/45-15 is calling my name. Supposedly more sizes are going to be released as well That option is making me consider 15's again. Price is decent too. Quote Link to comment Share on other sites More sharing options...
SteelBlue Posted April 29, 2020 Report Share Posted April 29, 2020 Have to run that t h i c c side wall if you're running 15s, at least in my opinion. patsbimmer1 1 Quote Link to comment Share on other sites More sharing options...
AsparagusMike Posted June 3, 2020 Author Report Share Posted June 3, 2020 So I fixed/improved a few things on this car a couple weekends back. Even though I had thought I had fixed it entirely with the turbo drain line I have still been having some oil leaking issues lately, Just couldn't pinpoint where it was coming from. After some close inspecting I had reason to believe my valve cover gasket was leaking. A few days later a new valve cover gasket appeared on my door step and I spent an evening swapping them out. After that was finished I started the car up and began inspecting. That's when I noticed something after bumping the oil feed line for the turbo... You can also see that the 90 on the -an fitting had been kinked. I knew about this prior to the leak but new that oil still flowed through it fine and kind of just put it off. well sure enough that's where the leak was all along. When I lifted the line ever so slightly it would begin dripping drastically. After spending a few hours searching around I ordered a new -4 an line from rally road. Also, after some more inspecting I found that the oem breather fitting coming out of the valve cover wasn't cutting it anymore and blow by was getting past the fitting and making an oily mess underneath. While on rally road's site I also found that they sold a fitting to fix this exact issue so I ordered that as well. A week later or so and the fitting and line were here. The following day after work I got to installing the new pieces. Old line vs. new Unfortunately I could not find a -4 an line in black which would have been a little more ideal looks wise but it is what it is. New breather setup installed. The rally road breather fitting was an awesome piece! It has two o-rings on the shaft that slides into the valve cover hole which sort of snaps into place, its a tight fit. Coming out of the other side is a -an fitting so I ordered a -10 an 90 with a hose barb on the other end to adapt to my rubber hose running to the catch can. I love the look of the new setup and best of all, no more leaks! After all this was finished I figured it was also about time for an oil change as well. After some debating back and forth I figured it was time to switch over to synthetic. I had been running shell t4 15w-40 for the last 12,000ish miles with a zddp additive and I had been doing this partly because of engine break in reasons and the fact that if I switched to synthetic that the leaks would get worse. With the new fittings and valve cover gasket I felt much better about making the switch. I chose a t6 5w-40 full synthetic oil. Underneath the car was an oily mess so after completing the change I pulled the skid plate and used about 4 cans of brake clean spraying down everything top to bottom. Two weeks later and no signs of oil leaks anywhere! For the longest time I had been running stacked washers to space the nut out for the momo hub instead of buying the oem spacer. Well when i ordered the valve cover gasket I threw it in with and decided it was time to swap it out for the right part. The spacer was a few mm longer then my washer stack and actually fixed a steering wheel squeak I had been dealing with sometime now so that was neat! First auto-x of the season for me this weekend. Looking forward to seeing how the car feels on the track with the new gearing setup and a non-squeaky steering wheel. KaiserRolls, P_Roloff, jc43089 and 1 other 4 Quote Link to comment Share on other sites More sharing options...
SteelBlue Posted June 3, 2020 Report Share Posted June 3, 2020 10 hours ago, AsparagusMike said: A few days later a new valve cover gasket appeared on my door step and I spent an evening swapping them out. Is it possible to learn this power? Quote Link to comment Share on other sites More sharing options...
GunMetalGrey Posted June 8, 2020 Report Share Posted June 8, 2020 On 6/2/2020 at 8:39 PM, AsparagusMike said: Unfortunately I could not find a -4 an line in black which would have been a little more ideal looks wise but it is what it is. 100% why I ordered stuff to make my own lines, though you had the exposed silver end on the turbo so it was a bit of a wash anyway lol. It's crazy to think the motor has seen 12k miles! I look forward to seeing many more updates after many more miles! AsparagusMike 1 Quote Link to comment Share on other sites More sharing options...
AsparagusMike Posted May 6, 2021 Author Report Share Posted May 6, 2021 Well I figured it was time I come back and update this thread lol. Last season was an absolute blast with this thing. I got a fair amount of seat time in and got a better grasp on controlling the car and it's power. (FVSCC auto-x at the Waupaca airport last year) Other then regular maintenance and up keep I didn't do much to the car in terms of upgrades. However, I did end up having a stone hit the windshield causing a small crack on the lower passenger side. On top of the crack there were many scratches all over and it was beginning to become a pain to see through (it was the original one). So I set up an appointment and had it replaced by Tri City glass and door up in Appleton. They did an excellent job and I was very pleased with the finished product. That was about it. After the last auto-x in October I enjoyed the car for another week or so and put it away in storage for the season. Unfortunately I was unable to gain access to my grandfather's shop over the winter to work on it and I had a lot of other things going on that I just wasn't gonna have anytime to work on it anyways. I shared a cold storage unit instead with my cousin where it sat for the winter. March rolled around and I started thinking about the upcoming warm weather and what I wanted to improve on the car before I started driving it again. Seats were the biggest thing on my mind as I still had the old ones that were getting pretty bad to drive in and I had a hard time getting comfortable in them. I was set on finding a set of Recaro srd's. I knew that was the set I wanted in the car and I did not want to compromise for anything else so worse comes to worse I was willing to drive with the old seats a while longer tell I found the right set. Well after several weeks of watching marketplace and other bmw pages/forums I came up with nothing. It seemed that the only sets that were going up for sale were selling within a few days and fetching to high of a price for the condition they were in. I gave up on looking in the midwest area and for shits and giggles started looking around the whole country to see what would pop up. Sure enough a set popped up In Denver, CO. The owner had them mounted in a mustang but sold the car so the seats had to go. I jokingly shared the ad to a friend of mine asking if he wanted to do a road trip to pick these up in which he replied "lets do it!" Over the following days since I had talked with him I thought it over while messaging the owner to see if he would be willing to hold them with money down tell I got out there. He agreed and that weekend my buddy and I made the 32 hour round trip to go pick these seats up. He was the original owner of this set and had taken very good care of them. On top of that he was including wedge brackets and sliders that he used to mount them in his mustang. Being that a new set of brackets and sliders were gonna run me upwards of around four hundred bucks for both seats I wanted to see if I could make the mustang ones work first. I took some measurements of the bolt hole distances and what I would need to modify to get them to fit properly. The following day I took them over to a friends and we went at modifying the brackets to fit the car. After they were all welded up I took them over to the shop and drilled and slotted the holes. The next thing was to figure out how I was gonna get the seat belt buckles to mount. I liked where the mounts were originally but with the e30 buckles it was not gonna work. In order to keep the location and fit the buckles I cut down the vertical piece of metal in half and drilled and tapped a new hole for the bolt. I ended up snagging some 5/8's size bolts from my grandfather's spare bolt bins at the shop and hacked them down so they were smooth without the outside surface. Worked like a charm and I mounted the seats back up to confirm there was no rubbing with the new set up. All that was left was to get them sand blasted and repainted. I put one coat of etching primer and two coats of SEM black trim paint. Purchased some new stainless hardware to bolt down the brackets to the car. The fitment of the seats in the car was exactly what I had hoped for. The fact that I sat lower and could slide back further to get more comfortable and secure in the car was awesome! These definitely were a game changer for the cars comfort and secureness. I can't wait to put these to proper use! After I finished those up I switched gears and started working on a spare sub-frame I had bought the year before. After having enough trouble with not being able to adjust the eccentric bolts I had in the rear (because of the raised sub-frame bushings) and driving the car with something like 2 or 3 degrees of toe out on one side and 1 degree toe in on the other was nothing short of a headache. Same went for the camber adjustments in the rear. I came to the conclusion that I need to swap out the rear sub-frame all together for another one and do everything besides the adjusting bolts. The spare I had was pretty rusty and still had the old rubber bushings in it. After taking an angle grinder and wire wheel to knock off most of the big chunks I sent it in to be sandblasted. I had ordered some new reinforcements for it from garagistic which included the differential mounting holes and trailing arm plates. Once I received the frame back from blasting I brought it over to my friend's place to get welded up. Time for a little por-15 for protection! A few days later the car was brought to the shop and I went to work pulling the rear end out. Took me a whopping two hours to pull it all out. It sure is nice when things come apart nicely. When I had everything apart I went ahead and re-greased the RCAB's and sub-frame bushings as they were already pretty dry from last season. Once the new sub-frame was bolted in and torqued down I went ahead and changed the diff oil out. Checked the old oil for any metal shavings or odd debris and then added some fresh Castrol Syntrax 75w-140. Rear end was popped back in the car afterwards and I swapped out the e-brake shoes and springs with some fresh ones. Over the summer last year the e-brake got left on by accident once or twice while driving the car. That just about roasted the shoe pads off to the point that it no longer could hold the car on a slant. Thankfully those parts were ordered through fcp euro so I went ahead and took advantage of that life time warranty. Once I was done torquing the rest of the bolts down holding the rear end in and inspected everything thoroughly I bled the brakes flushing out the system and added some fresh ATE typ 200 brake fluid. Switching over to the engine side of things I pulled apart the exhaust system and re-wrapped the down pipe and a section of the exhaust pipe. The old wrap had tore in a few places and wasn't looking to great. Ordered some Design engineering titanium wrap as a replacement hoping it will do a little better job at reducing exhaust temps in the engine bay. The kit I bought came with clamps and a tool for easily tightening them down. Unfortunately it took me a few to figure out how tight I could go before the clamp would break so that was a learning process but overall I was very pleased with the finished look. After that was back in and installed I did some maintenance related things: Changed the oil and filter, pulled the plugs and inspected/gapped them, and thoroughly cleaned the under side from oil and grease. The following day I took the car into town for a good wash and detail. I am working on possibly ordering a new breather setup for my pcv system. The catch can I'm running on it currently is sort of a cheapo and is doing a lousy job at filtering out the fluids so I'm looking into something a little better. Also would like to get the car back to the tuner at some point and get a 93 pump gas tune made now that I have a flex fuel sensor in there. Other then that the car is running great! Definitely looking forward to the upcoming season! patsbimmer1, P_Roloff, m42b32 and 1 other 4 Quote Link to comment Share on other sites More sharing options...
m42b32 Posted May 6, 2021 Report Share Posted May 6, 2021 Those seats look fantastic!! AsparagusMike 1 Quote Link to comment Share on other sites More sharing options...
Boris3 Posted May 6, 2021 Report Share Posted May 6, 2021 SRDs are great seats, nice find! AsparagusMike 1 Quote Link to comment Share on other sites More sharing options...
SteelBlue Posted May 8, 2021 Report Share Posted May 8, 2021 Saw you cruising the ave last night. Car looked good. AsparagusMike 1 Quote Link to comment Share on other sites More sharing options...
GunMetalGrey Posted May 8, 2021 Report Share Posted May 8, 2021 I envy your SRD's, I have a soft spot for those and always keep an eye out. Glad to see this thing is still ripping! AsparagusMike 1 Quote Link to comment Share on other sites More sharing options...
AsparagusMike Posted April 11, 2022 Author Report Share Posted April 11, 2022 Mistakes were made this past weekend 😔 Pulled the car out of winter storage on Saturday. After taking it out for a little shake down I went for a ride over to a little local car meet going on. Well one thing led to another and here I am on the highway doing a few pulls against a couple quick cars. Downshifted down to 2nd... 3rd, went for 4th and instead grabbed 2nd again and dropped the clutch. Car banged the rev limiter once or twice before I got the clutch depressed again. As I'm rolling in neutral I checked my gauges, still got oil pressure and the engine is still running and sounds somewhat fine so I continued to drive along another half mile tell I found an exit to pull off. Came to a stop and I find myself driving to what seems to have about the power of a 3 cylinder. Luckily my buddies house was only about a mile up the road so I slowly limped the car, which still had good oil pressure, over to his place and shut it off. Got a ride home and the following day I came back with the truck and trailer and hauled it back over to my grandpa's shop who was less then excited to see it back so soon. Right off the bat I whipped out the old trusty compression tester and started cranking. After seeing my low compression numbers on 4 and 6 I drained the oil and pulled the filter to check for metal pieces or shavings. Oil looked clean and normal as well as the filter so that was at least somewhat encouraging. checked out each cylinder with an inspection camera and found that none of the piston heads appeared to have any markings from a valve hitting them. The quality of the images aren't the greatest so I can't be 100% on anything but it was nice to see the possibility of no valve damage. As of right now i'm thinking one or more of the following things happened: Bent connecting rod bent valve (but seeming less likely after what I found) blown headgasket (it was just an oem one) or recked piston rings Things to consider: When I pulled the car into my buddies I shut it off and restarted it in which it fired right up again but was of course misfiring and had a slight knocking noise from the bottom end. I can also spin the engine by hand no problem and it doesn't feel like there is any binding. Gonna try to start disassembly and removal of the head tonight. Rekpoint 1 Quote Link to comment Share on other sites More sharing options...
HipMF Posted April 12, 2022 Report Share Posted April 12, 2022 Over-reving resulting in non-catastrophic bottom end failure seems unlikely. Putting my $0.02 on bent valve(s). KaiserRolls and Rekpoint 2 Quote Link to comment Share on other sites More sharing options...
AsparagusMike Posted April 13, 2022 Author Report Share Posted April 13, 2022 Yup, six bent exhaust valves. More concerning is the nicks in the pistons that I think are beyond salvageable. I'm afraid this rotating assembly is toast. YoungCR, m42b32, Jdesign and 3 others 6 Quote Link to comment Share on other sites More sharing options...
YoungCR Posted April 13, 2022 Report Share Posted April 13, 2022 Super bummer 😕 Quote Link to comment Share on other sites More sharing options...
GunMetalGrey Posted April 14, 2022 Report Share Posted April 14, 2022 These are not the updates I like here Quote Link to comment Share on other sites More sharing options...
Jdesign Posted April 14, 2022 Report Share Posted April 14, 2022 Bummer. On the plus side it sounds like an opportunity to make more power.... AsparagusMike 1 Quote Link to comment Share on other sites More sharing options...
SteelBlue Posted April 14, 2022 Report Share Posted April 14, 2022 Pain. What actually causes the valves to contact the piston? When it over rev's, it exceeds the limits on the springs and the valve extends further than it should contacting the piston? Quote Link to comment Share on other sites More sharing options...
AsparagusMike Posted April 14, 2022 Author Report Share Posted April 14, 2022 6 hours ago, SteelBlue said: Pain. What actually causes the valves to contact the piston? When it over rev's, it exceeds the limits on the springs and the valve extends further than it should contacting the piston? Ya I imagine the valves stretched a bit at the higher rpm and the cam spun faster than the valves could reciprocate, causing the valve stem to separate from the cam during the close cycle. Quote Link to comment Share on other sites More sharing options...
gilber33 Posted April 14, 2022 Report Share Posted April 14, 2022 1 hour ago, AsparagusMike said: Ya I imagine the valves stretched a bit at the higher rpm and the cam spun faster than the valves could reciprocate, causing the valve stem to separate from the cam during the close cycle. Is that kind of the same principal why they offer HD springs for higher horsepower and higher revving builds? Quote Link to comment Share on other sites More sharing options...
GunMetalGrey Posted April 15, 2022 Report Share Posted April 15, 2022 15 hours ago, gilber33 said: Is that kind of the same principal why they offer HD springs for higher horsepower and higher revving builds? Correct You want the lowest amount of spring force required to match the speed of the cam, as anything above is just added friction and wear. When you over rev the spring force is not great enough to accelerate the valve fast enough to follow the cam and you get valve float, which can in turn cause the valve to contact the piston if the discrepancy is high enough. I did supertech springs in my S52 head and the spring force change becomes VERY noticeable when you try to get the cams back in... m42b32 and Jdesign 2 Quote Link to comment Share on other sites More sharing options...
HipMF Posted April 22, 2022 Report Share Posted April 22, 2022 On 4/15/2022 at 10:35 AM, GunMetalGrey said: Correct You want the lowest amount of spring force required to match the speed of the cam, as anything above is just added friction and wear. When you over rev the spring force is not great enough to accelerate the valve fast enough to follow the cam and you get valve float, which can in turn cause the valve to contact the piston if the discrepancy is high enough. I did supertech springs in my S52 head and the spring force change becomes VERY noticeable when you try to get the cams back in... Correct. Only thing that I would add is that the actual contact between valve and piston occurs due the valve bouncing off the seat. The cam profile is designed to decelerate the valve so that it gets placed "gently" onto the seat. When the valves "float", by the time the valve comes into contact with the seat, the cam has already rotated past the gentle decel part of the profile, and the valve slams hard into the seat and bounces back off, potentially multiple times, before the piston comes up and hits it. Quote Link to comment Share on other sites More sharing options...
AsparagusMike Posted June 3, 2022 Author Report Share Posted June 3, 2022 And as always, bad with keeping up with the updates on here. Well not to long after I determined the motor was gonna need a full rebuild I got to ripping it out and getting things disassembled and ready for rebuild. Other then the bent valves and scored tops of pistons/cylinder walls, the rest of the rotating assembly looked pretty good. Everything was torn down and boxed up for storage. As for cylinder walls and other bare metal surfaces I sprayed a layer of wd-40 over everything for surface rust prevention. Originally I had intentions of diving into this and begin ordering parts/getting stuff machined to maybe have it up and going this year still but for financial reasons and being that I have a few other more important priorities right now I decided I'm gonna hold off for now. In the mean time, I had some new door seals for the car that had come in a while back and decided to swap the old ones out. I didn't get any pics of them but the original ones were in rough shape and had holes all along the bottom portion. Water would leak in from time to time when I washed the car or it rained. It was also pretty easy to hear the outside wind and cars passing when on the highway which was getting pretty annoying so this was well overdue. After finishing that up I gave er a good wash and topped off the gas tank. Also added another bottle of ethanol stabil treatment, seems to be doing a good job at keeping the e85 in somewhat good shape so far. Afterwards the car was parked back in storage. I had a shelf on the other side of the shop where I was storing all the boxes with the motor parts. As for the crankshaft I had it wrapped up with plastic wrap and stood upright on the shelf cornered in by three other boxes. It was done that way in case it became unbalanced and fell it would only fall onto the cardboard. Unfortunately I hadn't made my grandpa aware of this right away and the following day he started moving the boxes of parts around that I had placed around the crank. This also caused the crank to become unbalanced and fall over and drop five feet to the concrete where it snapped in two. I am thankful that it fell on the ground and not him but I am now on the hunt for another crank. And up tell about two weeks ago that's all that had been going on with this car. For a period of time I had the idea of finding an m52 for cheap and throwing it in the car to still enjoy it for the summer. Unfortunately prices seemed to have go up quite a bit for those now so I kind of tossed the idea out. Well a friend of mine messaged me saying he had an m52 he was gonna use for his car but ending up going with something else and said he would sell to me for cheap so I went and took a look at it. I ended up bringing it home with me. The motor was pulled apart because of a valve keeper popping out of place and dropping the valve in to the cylinder. At first I was hesitant about it since I figured the walls would be scored and would also need a rebuild which I was not looking to do with this. After looking it over I noticed no scoring on the walls of that cylinder (ran my finger nail around it) and the rest of the five cylinders looked fine. He also had it looked over by a few people who have built quite a few racing engines and said he would be fine running it. Everything to turn this into a long block was included as well as some new gaskets. There was also a fresh cylinder head done for it that was hot tanked and decked, ready to be installed. On top of that he threw in the cylinder head that was originally from this motor which was missing the one valve and a few cam studs but the rest of the valves were in good shape and would be a good parts head for the s52. Rotating assembly spins freely and smoothly by hand and just to be safe I pulled the piston out and inspect it. From what I can see it appears to be fine and I saw no major damage besides the scoring on the face. So far this was my plan with this. Pop the piston back in and leave the bottom end as is. Check the block surface for any warpage and if there is any (I'm guessing there most likely will be), re deck the block using the wet honing stone method. Re seal the motor running a stock headgasket, and some arp head studs and see if I can't run high 300's on e85. This would only be a temporary motor to get the car back up and going tell I can start rebuilding the s52. Sort of a budget build you could say. Quote Link to comment Share on other sites More sharing options...
AsparagusMike Posted February 14, 2023 Author Report Share Posted February 14, 2023 And the start of a new chapter begins... After further consideration of my plans for putting back together the M52 I had picked up and throwing that in, I decided against it, rolled the car back into storage and let everything rest for the remainder of the year. Although the bottom end seemed alright to run as is, I felt foolish doing it and didn't want to go through all the time and effort of putting it back together just to possibly run into issues right away. As things sat I slowly began acquiring parts needed for a full engine rebuild. I brought the old s52 block into a local machine shop to figure out what my options would be for piston size. After doing an inspection of the cylinder walls they said I would need to bore the cylinders 20 thousandths over which left me with going to an 87 mm piston. Initially I was good with this but after seeing possible issues with others having cylinder walls crack on them as well as not having any wiggle room with the cut rings on the HG and running into valve and piston head interference's I threw that block back up on the shelf and re-considered my options. Thankfully I had an M52 laying around now which gave me the option to run the piston size I wanted to so I landed on using that block for the rebuild. Fast forward a few months and the block, pistons and rods were dropped off at the machine shop as well as an s52 crank that I purchased a few months prior. Unfortunately the crank main and rod journals were in rough shape and required a .010 grind and polish. I also had the machine shop do a re-balance of the entire rotating assembly. As for the block, it was bored out to 86.5 mm and honed with a torque plate installed afterwards. block was also decked with the timing cover attached and line honed for the upgraded arp main studs. As for the cylinder head, I brought in the head that I got with the m52 and had the shop check the deck for straightness as well as vacuum testing it and pressure testing to see if it would need a valve job. Thankfully everything checked out good there. Had them run that through the hot tank to clean everything up. Other machine work I had done included having the rod clearances checked and sized for the wrist pins and the cam shafts being polished up as they were a little scored up on the journals. Everything when I got it back from the machine shop a few weeks later... After spraying the entire block down with mineral spirits to remove all oils used for flash rush prevention it was time to paint the block coat of primer first Was pretty happy with how that turned out. Assembly time rolled around and I ran into a small road barrier right away. First thing on the list was installing the oil squirters. I went through the six squirters I had from the blown s52 and used a small pick to test the spring pressure on each one. All of them had very weak or no spring pressure. So I dug up the six that came with the m52 and tested those. I found four of them that seemed to have fairly good pressure while the other two were very weak. Instead of just replacing the two bad ones I just ordered a whole new set of six. With the squirters on the way I went ahead and got the main bearings installed so I could get the clearances checked. When I went to set the crank in the motor I noticed it did not want to slide into place and was getting hung up on the thrust bearing washers. Pulled the crank out to see if I was missing something but after pulling the bearing out and attempting to place it on the journal I found there was no way it was going in and was larger then the width of the journal surfaces by a good amount. Gave the machine shop a call and found that they had not ground down the thrust washer surfaces as they were unaware that the thrust bearing was a one piece design instead of the more common multi piece style. The oem .25 mm undersized bearings I ordered also make the thrust washer area undersized instead of keeping it oem size. After some extensive researching I was unable to find a thrust bearing on the market that came undersized but held the oem thrust washer thickness. So the crank needs to go back into the shop so they can grind that up correctly. With me unable to do anything with the crank I switched gears and began the tedious process of gaping all my rings. Went with a slightly wider gap then oem spec for boost reasons. I did have a hard time with my newly purchased ring gaping tool and on my first go around I messed up a top ring for cylinder #1 leaving me with too wide of a gap requiring me to order another set for that piston. Thankfully another ring set was fairly inexpensive. After that one I got a feel for how fast it took off material and the rest of the rings went pretty well. Afterwards I switched gears and worked on getting the oil pump ready to go. Original plan was to reuse the oil pump from the blown s52 but after pulling the rotor out I found there to be quite a bit of scoring on both surfaces making the pump unusable. Dug out the oil pump from the m52 block and found everything to be in much better shape and score free! Purchased the Achilles upgraded oil pump shaft kit to go along with it. Went ahead and got the old shaft pressed out and the new shaft installed and set at the correct distance. Also took the time to clean up the pump housing a bit and remove all the oil staining. Decided while I was in there I might as well do a full rebuild of the pump with an all new control valve, spring and rubber washer. Once everything was lubed up and installed I got the pump primed and ready to go. As for now that's all the progress I've managed to get done. Hoping to get the crank back to the machinist by Wednesday and maybe see it back by the end of the week or early next week so I can really get the ball rolling. timmer, Rekpoint, RobZR and 2 others 5 Quote Link to comment Share on other sites More sharing options...
