suspenceful Posted June 10, 2019 Report Share Posted June 10, 2019 Was nice bumping into you at WIR! Car looks and sounds great. AsparagusMike 1 Quote Link to comment Share on other sites More sharing options...
Jdesign Posted June 11, 2019 Report Share Posted June 11, 2019 This thing sounded great at the picnic. 😍 AsparagusMike, P_Roloff, timmer and 1 other 4 Quote Link to comment Share on other sites More sharing options...
m42b32 Posted June 11, 2019 Report Share Posted June 11, 2019 22 minutes ago, Jdesign said: This thing sounded great at the picnic. 😍 Agreed, it sounds fantastic!! AsparagusMike 1 Quote Link to comment Share on other sites More sharing options...
B C Posted June 11, 2019 Report Share Posted June 11, 2019 It sounds different than other 24V builds and is the best that I have heard. AsparagusMike 1 Quote Link to comment Share on other sites More sharing options...
straight6pwr Posted June 11, 2019 Report Share Posted June 11, 2019 6 minutes ago, B C said: It sounds different than other 24V builds and is the best that I have heard. the turbo mellowing out any harshness/rasp? would love to hear it sometime too. Quote Link to comment Share on other sites More sharing options...
B C Posted June 11, 2019 Report Share Posted June 11, 2019 I dont know the manifold setup, but I love the hell out of an RB/JZ exhaust note. You are probably correct on that and the single exhaust bundling it all up Jdesign 1 Quote Link to comment Share on other sites More sharing options...
GunMetalGrey Posted June 11, 2019 Report Share Posted June 11, 2019 It makes me all tingly inside seeing this stuff being put to use. The manifold is still the one you ceramic coated @B C, ceramic downpipe, and through a very large resonator. Jdesign 1 Quote Link to comment Share on other sites More sharing options...
AsparagusMike Posted June 18, 2019 Author Report Share Posted June 18, 2019 Very long and over due update... The last 2 months or so have been unbelievably fun with this car and its been exciting to see how competitive she can be against other considerably quick cars. Over the month of May I took the car to a couple shows, local meets, and the occasional trips to Mexico. The car has been really good and for the most part has been running spectacular except for the occasional mishaps. First off, guibo... After about 2 weeks of driving the car I started noticing a lot of vibrations in 2nd and 3rd gear and knew something was up. At first it seemed like suspension so I did a shake down test and while doing this I came upon this. When I got the new reman'd driveshaft the guibo seemed alright but with the extra torque it didn't last long. Not only did my guibo shred up quite badly but my reverse light wire wasn't tied up enough causing it to droop down resulting in it getting caught in the driveshaft and being ripped out leaving only some wire running to the connector by the shifter. Ended up having to make a new one which I wrapped up nicely above the trans where it should hopefully no longer have any interference with any more moving parts. Ordered a new oem guibo through fcp and haven't had an issue sense. Next little fun incident I had was my fuel pump assembly o-ring going bad causing fuel to leak out of the top every time I topped off the gas tank. It would pool out a good quarter to a half a tank of gas from the top of the tank. After pulling the back seat and access panel I found this knowing right away that's what it was. Ordered a new oem ring through the dealer which came the following day, easy swap out. I'm assuming the e85 just took the best. Haven't had a leak sense! Next up I installed a catch can. The catch can was a much needed item as I had the ccv hose just running down underneath by the skid plate causing a oily mess in the skid plate and the surrounding areas. The catch can was a fairly cheap one from amazon but being that I didin't have it recirculating back into the intake I didn't need anything fancy with a good filtration system, just something to catch everything coming out of the crank case. Mounted it in the only place I could find that would make for easy access and fairly clean look. No more oily messes! This was after a weekend of driving and racing around quite a bit. Next up was my fenders. For the most part, my wheel and tire setup have been great but my front tires clearance from the inner fender was tight and was causing quite a bit of a rubbing. Thanks to @GunMetalGrey hooking me up with a fender roller and some guidance I spent a few hours making some better clearances. Sense I had all the wheels off and the roller I decided to do the rear as well which oddly enough had been rolled but only halfway on both sides. After checking on a couple other e30's we determined that it definitely wasn't something done from the factory. Nevertheless it made for an easy job on the rears and they went quickly. No more rubbing issues! Next up was the steering wheel. I had just about enough with the airbag steering wheel and decided it was time for it to go. After spending a week researching and deciding on what to replace it with I decided on a momo steering wheel, the montecarlo. Its incredible how much of a difference a slightly smaller better feeling steering wheel can make. The new steering wheel matched with the z3 steering rack makes for an unbelievable feeling that reminds me of driving a go cart, I love it! Oh and I also have a horn now lol. The original airbag steering wheel was messed up causing the horn to go off every time I turned it forcing me to pull the fuse and run without. Next up, brakes. After refreshing the entire brake system I installed centric oem high carbon rotors and stoptech sport pads. This setup worked great with the NA s52 setup and I felt like I had sufficient stopping power. Now with the extra power they are starting to show their weakness. I went out with a couple of friends this last weekend and drove some country back roads with quite a few curves pretty intensely. By the end of it my front wheels were smoking really badly and I even noticed quite a bit of fade on the brake rotor. After seeing this I knew it was time for me to upgrade to something a bit better. I stuck with an oem high carbon rotor but switched over to some hawk hps pads for both front and rear. I was considering doing another step up to the hp+ pads but found that many said they weren't the most ideal if the car is being drivin on the street as they squeak quite a bit. I will see how the hps pads perform and go from there. Lastly and most importantly, my cut out issue. This is something I've had ever sense I got the car back from the dyno. It happened very rarely at the beginning but as I drove the car I figured out where and why it was happening but wasn't quite sure how i should adjust it. Scenario: I'm driving in 3rd gear at about 2600 rpms. If I gave the car 100% throttle right away the car would almost immediately cut out and I would lose all power. I would then let off the throttle completely and let the car roll for a few seconds in which it would then return to normal and I could go along my way with no problem. Now, if I rolled into the throttle in 3rd gear instead of 100% she never cut out and would pull well with no issue. It would also never cause an issue when starting from a dig and revving out all the gears. I started digging through TS a bit and I came upon the afr safety settings. After reading through the settings and thresholds set compared with when the issue was happening I feel that this is what is causing it. After 2500 rpm's when the afr was found to be off by 1.3 lean or 1.3 rich it would kill spark and then fuel tell I let off the throttle for 3 seconds in which it would return to normal. Luckily I just recently found a local guy who tunes a lot of standalone systems and is quite familiar with MS and tunerstudio. I'm bringing the car over to him Wednesday and hopefully we will be able to clear up this issue before the weekend. Well that's about it in terms of things that were fixed and what needs improvement. For those of you who I didn't get to talk to at the picnic I finally got to take the car to my local drag strip and got to see what she runs in the 1/4 mile. Being that it was my first time doing this I was quite nervous causing my first two runs to a little weak. All in all I was able to get in four runs total with my best time on my third run, 12.23 seconds at 118 mph. The match was against a Mitsubishi ralliart which had quite a bit of work done to it including a larger turbo and running e85. (Owner predicted it at around 425 hp awd) Well, it wasn't quite enough... What hurt me the most was my 60 foot which was about 2 seconds. I think I should be able to shave off a good .3 seconds off of that but it's a bit challenging being that trying to launch the car at all results in me spinning a little tire. I had a lot of fun overall and it was a great experience. As for upcoming events I am excited to say that I will be participating in my first auto x event this Sunday at the US air motorsports raceway in Shawano. Hoping to see a few of you guys there! Burnout vids coming soon. Jdesign, Rekpoint, gilber33 and 5 others 8 Quote Link to comment Share on other sites More sharing options...
GunMetalGrey Posted June 18, 2019 Report Share Posted June 18, 2019 10 hours ago, AsparagusMike said: 12.23 seconds at 118 mph I don't do drag racing, but this seems like a pretty solid time for something on street tires at WIR for your first event. Time to get @suspenceful on the road with you and do some 59.99 rolls! KaiserRolls and B C 2 Quote Link to comment Share on other sites More sharing options...
SteelBlue Posted June 18, 2019 Report Share Posted June 18, 2019 1 hour ago, GunMetalGrey said: I don't do drag racing, but this seems like a pretty solid time for something on street tires at WIR for your first event. Time to get @suspenceful on the road with you and do some 59.99 rolls! suspenceful 1 Quote Link to comment Share on other sites More sharing options...
GunMetalGrey Posted June 18, 2019 Report Share Posted June 18, 2019 I now realize it's the wrong crowd for that joke. MTB jokes relating to SRAM switching from a 30mm axle to a 28.99mm Carry on Jdesign 1 Quote Link to comment Share on other sites More sharing options...
suspenceful Posted June 18, 2019 Report Share Posted June 18, 2019 5 hours ago, GunMetalGrey said: I don't do drag racing, but this seems like a pretty solid time for something on street tires at WIR for your first event. Time to get @suspenceful on the road with you and do some 59.99 rolls! I told him I'm down to swap keys! PS: that's a nice fender roller Quote Link to comment Share on other sites More sharing options...
AsparagusMike Posted June 18, 2019 Author Report Share Posted June 18, 2019 1 hour ago, suspenceful said: I told him I'm down to swap keys! Absolutely! 1 hour ago, suspenceful said: PS: that's a nice fender roller Oops, my bad. Shoutout to @suspenceful for hooking @GunMetalGrey up who hooked me up with that badass fender roller, much appreciated. SteelBlue, Jdesign and suspenceful 3 Quote Link to comment Share on other sites More sharing options...
AsparagusMike Posted June 21, 2019 Author Report Share Posted June 21, 2019 Update! So last night I took the car over to a man by the name of Hunter Mulhollon (hunter tuned) who knows MS really well and messed around with my tune a bit to figure out why I was cutting out. Luckily he was able to get the car on the dyno the same night and got her dialed in really well. First of all, before he did any tuning he went ahead and pulled a spark plug and checked the gap, it was .025. After informing him that I was running a 2 step colder plug and had gaped them all to .021 he pulled the other 5 and found that all of them were in the .025 to .027 range. It seems I was suffering from a bit of spark blowout. He brought them all down to .019 - .020 and popped em back in. After a few pulls he found that I was getting some pretty lean spots on the fuel table. Went through and cleaned that up making everything a bit more fat (rich) for safety and being that I'm running e85. After making some more adjustments else where he did one final pull and the car put down a whopping 400 hp! The crazy thing is the tune is still pretty conservative as I'm only at about 8 lbs (once in a while creeping to 10ish lbs) and running e85. There was actually room for even a little more power safely but unfortunately being that I only have the stage 2 clutch in there now she's about maxed out and he started to smell it slipping a little so he called her quits. The big thing is my cut out issue is now gone and she feels even more responsive! Driving it home I tried about every situation I could think of that would make the car cut out before and she just kept pulling. All in all amazing work from Hunter. I also just wanna say that Shane at DB performance still did an awesome job on the car and I was very pleased with his work. I think that if my e85 ethanol content had been a little higher with the fuel that was in my tank some of my fuel map values may not have been as lean as they were and I may never had encountered any cut out issues. Overall, awesome job tuning from both Shane and hunter, this thing is a fuckin blast! Pads and rotors should be here tomorrow! Stay tuned! Boris3, Jdesign, timmer and 1 other 4 Quote Link to comment Share on other sites More sharing options...
YoungCR Posted June 22, 2019 Report Share Posted June 22, 2019 Solid! Good to know there's a experienced Meqasquirt tuner around. Quote Link to comment Share on other sites More sharing options...
GunMetalGrey Posted June 24, 2019 Report Share Posted June 24, 2019 Update It's still very fast It sounds very lovely without the muffler. I added that due to getting pulled over and the cop yelling at me lol. If Mr. Mike gets pulled over it wont be because of the noise... Best of luck catching up to the E30 Mr. Policeman! Patiently awaiting auto-x update! AsparagusMike 1 Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted June 24, 2019 Report Share Posted June 24, 2019 1 hour ago, GunMetalGrey said: Patiently awaiting auto-x update! I’ll let veggiemike tell you about his adventures lol Jdesign 1 Quote Link to comment Share on other sites More sharing options...
GunMetalGrey Posted June 24, 2019 Report Share Posted June 24, 2019 5 minutes ago, KaiserRolls said: I’ll let veggiemike tell you about his adventures lol I was hoping you would be there! I suggested Mr. Veggimus speak with you / see if he could steal some of your knowledge. Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted June 24, 2019 Report Share Posted June 24, 2019 26 minutes ago, GunMetalGrey said: I was hoping you would be there! I suggested Mr. Veggimus speak with you / see if he could steal some of your knowledge. We had to scramble just to get him to run the afternoon heat lol Quote Link to comment Share on other sites More sharing options...
Boris3 Posted June 24, 2019 Report Share Posted June 24, 2019 Dyno'd at 400 hp!!! GunMetalGrey 1 Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted June 24, 2019 Report Share Posted June 24, 2019 @AsparagusMike AsparagusMike 1 Quote Link to comment Share on other sites More sharing options...
AsparagusMike Posted June 25, 2019 Author Report Share Posted June 25, 2019 Update: Brakes came in Friday! After work I buckled down and spent a few hours tackling all 4 wheels. Once the brakes were done and the car was back on the ground I took it for a little drive to get the pads properly burnished in, all ready to go for Sunday. Well Sunday morning came and I had a bit of a late start from the night before. It was roughly 7:30 when I woke up and I was two hours away from the track. The two hours was not including the fact that I still had to get home to grab the car plus pick up two people, stop for fuel and make it there before ten. Well needless to say I made it to the track... at 10:20. I get inside to find out that my spot had been taken and I wasn't gonna be able to run. I was pretty bummed out at that point as I had been looking forward to driving this track for some time now. I decided to stick around anyways as once they started sending cars out I was able to hop in and ride with another fellow e30 driver who was also quite fast (turbo M20) and I learned quite a bit as well as had a blast. After they got midway through heat four I noticed a car at the starting line who had its hood popped open smoke going everywhere with coolant spilling all over the track, it was the same guy who had replaced me and his car had overheated. I wanna give a huge shout out to @KaiserRolls who approached Tom (the main man running the event) a few minutes later and asked him if I could drive in place of the guy with the crowd killer (found out later his name was Jake) if he would be willing to give up his spot so I could drive the last four laps of round two. Tom acknowledged the idea and so I approached Jake and after chatting with him for a few minutes and informing him that this was my first time doing auto-x he happily gave his spot to me for the last portion of the event! I was in! Once we got the numbers swapped over on to my car and tech inspection was passed I was in line ready to go for the fourth heat which was being combined into four laps one after another (hot lapping) in order to get everyone through more quickly and avoid the rain which was beginning to approach us. As a way of expressing my appreciation I offered to let Jake ride along with me on my first lap which he gladly accepted. I never quite realized how crazy 400 hp in a light car such as the e30 was until I took it out on a proper track like US air raceway. It is quite a lot to handle and makes things really interesting when it comes time to stop to make a turn. I knew going out I wasn't gonna be setting any crazy times and more just wanted to enjoy the car on this incredibly fun track and get a feel for it. Unfortunately I didn't notice to much of an improvement with the hawk hps pads other then the fact that my wheels weren't smoking quite as much by the end of my fourth lap. During my second lap I found out just how little stopping power I had after I was unable to make the last turn to the finish line from the amount of speed I had built and continued straight into one of the a bails of hay which was being used as a wall around the corner. Luckily the car endured no damage other then the valance being slightly pushed in which I pulled back out with ease. For now though I will continue to run with the brake setup I have and just work on not going quite as fast, focusing more on the handling and technique of it. Overall had an awesome time, car ran great and I am really looking forward to the events to come. Now that the car is running properly there is only more thing to do... (Potato phone quality video for your pleasure) m42b32 1 Quote Link to comment Share on other sites More sharing options...
Boris3 Posted June 25, 2019 Report Share Posted June 25, 2019 My experience when I started the transition from parking lot autox to on track events at Blackhawk and Road America was that Hawk HPS were rotor friendly but overwhelmed by the speed of a stock m20, HP+ were better for a few laps and then dropped off quickly and also sounded like a dump truck when cold and chewed rotors. I switched to Performance Friction PFC-06s and then the PFC-08s still with stock calipers and rotors which has been great. When I was still driving the car to track events, the PFCs also worked well on the street. Chewed the rotors but no worse than the HP+ and at least you knew you could slow/stop the car...which is a comforting thought to have on the track. Not sure what brake fluid you're running, but ATE or Motul are popular options. Basic auto parts store off the shelf stuff will boil with what you're putting it through. All that said, with a 400 hp e30, maybe a big brake kit is in your future? Quote Link to comment Share on other sites More sharing options...
GunMetalGrey Posted January 24, 2020 Report Share Posted January 24, 2020 I brought this car up today to Brian, and it made me wonder if anything has happened to it as of late. Or are you just working on farming the 'sparagus? Quote Link to comment Share on other sites More sharing options...
AsparagusMike Posted February 2, 2020 Author Report Share Posted February 2, 2020 On 1/23/2020 at 6:51 PM, GunMetalGrey said: I brought this car up today to Brian, and it made me wonder if anything has happened to it as of late. Or are you just working on farming the 'sparagus? As of right now the car has been sitting in storage collecting dust. Have a few big things in the works for it to get done before spring time roles around. I've been accumulating parts over the last few months and hoping to get er in the shop within the next 2 weeks. Updates coming soon! YoungCR and timmer 2 Quote Link to comment Share on other sites More sharing options...
