Jdesign Posted May 16, 2018 Author Report Share Posted May 16, 2018 15 hours ago, P_Roloff said: I just looked into it a little online, and there was some discussion on a pilots forum about it. It sounds like the runways are better than they used to be in that they aren’t covered in weeds with brush encroaching on the sides, but they’re definitely bumpy. I might take a look at it when I get back to Madison in a few weeks, I didn’t even know it was there honestly and I live 15ish minutes away. Ive been there both when its been covered in weeds and when its been cleared. There are two guys in specific that fly an autogryos there quite a lot when the weather is nice and they still fly smaller planes out of it because its still an active airfield. So I don't know how easy it will be to get approval to host an event there. I do have a good friend of mine that knows the owner of the airfeild and he also said it will be difficult. I was going to contact him again first and see if I can get more information rather than just going there unannounced. Also I would like to add that if you go down the wrong driveway, there is a risk of being shot. Another friend of mine that grew up in CG rode his bike down that driveway and had an angry neighbor fire a warning shot to scare him off. LOL Rekpoint 1 Quote Link to comment Share on other sites More sharing options...
P_Roloff Posted May 16, 2018 Report Share Posted May 16, 2018 26 minutes ago, Jdesign said: Ive been there both when its been covered in weeds and when its been cleared. There are two guys in specific that fly an autogryos there quite a lot when the weather is nice and they still fly smaller planes out of it because its still an active airfield. So I don't know how easy it will be to get approval to host an event there. I do have a good friend of mine that knows the owner of the airfeild and he also said it will be difficult. I was going to contact him again first and see if I can get more information rather than just going there unannounced. Also I would like to add that if you go down the wrong driveway, there is a risk of being shot. Another friend of mine that grew up in CG rode his bike down that driveway and had an angry neighbor fire a warning shot to scare him off. LOL Jesus. Maybe I won’t be going to check it out. Talk about crazy neighbors. Quote Link to comment Share on other sites More sharing options...
Rekpoint Posted May 16, 2018 Report Share Posted May 16, 2018 Crazy neighbors might start shooting if you make too much noise... Quote Link to comment Share on other sites More sharing options...
straight6pwr Posted May 16, 2018 Report Share Posted May 16, 2018 two things 1)its not the size of your rods, its the angle of the dangle Quote if I hit redline for more than 20 seconds or so 2) winning m42b32 1 Quote Link to comment Share on other sites More sharing options...
straight6pwr Posted May 16, 2018 Report Share Posted May 16, 2018 the angle kit sounds like a great way to get quicker steering on the e30, but the kits are super expensive, and they seem a bit tedious (i.e. special bearings/parts that will wear out). seems like a rack would still be a better option, unless i'm missing something. looks like they reduce lock-to-lock by a half a turn at least. Quote Link to comment Share on other sites More sharing options...
Jdesign Posted May 16, 2018 Author Report Share Posted May 16, 2018 4 minutes ago, straight6pwr said: the angle kit sounds like a great way to get quicker steering on the e30, but the kits are super expensive, and they seem a bit tedious (i.e. special bearings/parts that will wear out). seems like a rack would still be a better option, unless i'm missing something. looks like they reduce lock-to-lock by a half a turn at least. You are missing something. They are just under $50 shipped. Its not a complete angle kit that replaces your LCA's, its just an aluminum adapter that changes the mounting point of your outer tie rod to the knuckle pushing it closer to the main centerline (A'shown below)) of your wheels rotating axis. If that makes sense.. A= the knuckle and hub where the wheel is rotating B=where the existing tie rod was C= where the tie rod is now after the angle kit J= either direction you can steer?- (I have no idea I stole this image from the internet) Quote Link to comment Share on other sites More sharing options...
Jdesign Posted May 16, 2018 Author Report Share Posted May 16, 2018 Oh and for good measure, here is some of that angle: P_Roloff 1 Quote Link to comment Share on other sites More sharing options...
straight6pwr Posted May 16, 2018 Report Share Posted May 16, 2018 i understand the concept, it just appears due to the e30's steering design, the kits are complicated and are between $300-400. there seems to be no simple version available like the e36/e46. Quote Link to comment Share on other sites More sharing options...
Earl Posted May 16, 2018 Report Share Posted May 16, 2018 15 minutes ago, straight6pwr said: i understand the concept, it just appears due to the e30's steering design, the kits are complicated and are between $300-400. there seems to be no simple version available like the e36/e46. That's because most people just switch to e36 front struts and knuckles when drifting an e30. Quote Link to comment Share on other sites More sharing options...
Jdesign Posted May 16, 2018 Author Report Share Posted May 16, 2018 3 hours ago, straight6pwr said: i understand the concept, it just appears due to the e30's steering design, the kits are complicated and are between $300-400. there seems to be no simple version available like the e36/e46. Ahhh I see what you mean. 2 hours ago, Earl said: That's because most people just switch to e36 front struts and knuckles when drifting an e30. And yeah that's probably the reason and makes the most sense. Quote Link to comment Share on other sites More sharing options...
Jdesign Posted May 30, 2018 Author Report Share Posted May 30, 2018 Basically just making a mental note here for myself- The upper LP hose on the PS pump finally split good enough to leak a more fluid that I am happy about. The output seal on the transmission leaks and should be fixed. I need to replace it and I also developed a creaking/clunking noise in the rear that I need to inspect. Keep my eyes pealed for a small VCR for making a switch panel. Quote Link to comment Share on other sites More sharing options...
GunMetalGrey Posted May 31, 2018 Report Share Posted May 31, 2018 On 5/30/2018 at 10:59 AM, Jdesign said: Keep my eyes pealed for a small VCR for making a switch panel. I like you Jdesign 1 Quote Link to comment Share on other sites More sharing options...
Jdesign Posted June 1, 2018 Author Report Share Posted June 1, 2018 I have not touched this car yet, but was reminded of it today via some tags on Facebook. Soon I will have it on the lift and try and address the above. For now here are the tagged images: Also I think I need to vinyl wrap my helmet black. Quote Link to comment Share on other sites More sharing options...
straight6pwr Posted June 4, 2018 Report Share Posted June 4, 2018 dark red to match the tintz Jdesign 1 Quote Link to comment Share on other sites More sharing options...
Jdesign Posted June 29, 2018 Author Report Share Posted June 29, 2018 Taking notez 😐 P_Roloff and jc43089 2 Quote Link to comment Share on other sites More sharing options...
Jdesign Posted July 23, 2018 Author Report Share Posted July 23, 2018 So time for an update. I last drove this car on the cruise to Road America through the kettles, and Im sure some of you are aware I had trouble getting the car to turn over after shutting it down. (thanks for the push X2 everyone) After I got home, I checked my battery, and alternator to make sure that it wasn't the issue. Sure enough, 12.9 when the car was off, 14.2 when the car was on. So I assumed it was the starter, and parked the car back in its spot and didn't touch it until this past Friday night. I had plans to drive to Road America again this past weekend as I had free tickets and a VIP spot in the tower for the Vintage races. Twisting my arm, a friend of mine convinced me that I should fix this car and drive it there. In typical fashion, I waited until 7 pm to get it on the lift and look at it. The stater was fairly easy to get to and only has two bolts holding it in. That was the easy part. I soon learned that a 1990 starter was VERY different from the upgraded version released in 1993 that I needed. I made it back to the store within 15 mins of them closing to exchange it. Once I unbolted the power cable I noticed that corrosion had occurred at both the terminals and the power wire was only attached by a few strands of wire. I had to chop the wire shorter, replace and seal the ends to prevent it from happening again. Once the starter was off, I also discovered a bonus item in the bell housing resting against the starter. A socket head bolt for ?????? Starter comparison: Corroded terminal: Bonus bolt: With the new starter installed it fired right up without issue and as some of you may have witnessed, I made it to RA and back without a hiccup. I also acquired some new wheels from a guy I met at the Picnic. They are Borbet Procast 16x7.5. They seem to be really rare and I am having trouble even finding another set in this size. They seem very fitting for the car and I am looking for paint and style suggestions before I mount them! Bassboy3313 and P_Roloff 2 Quote Link to comment Share on other sites More sharing options...
Jdesign Posted July 26, 2018 Author Report Share Posted July 26, 2018 jc43089, straight6pwr, P_Roloff and 1 other 4 Quote Link to comment Share on other sites More sharing options...
SteelBlue Posted July 27, 2018 Report Share Posted July 27, 2018 My buddies reaction when they saw this at RA for vintage weekend was absolutely priceless. Jdesign 1 Quote Link to comment Share on other sites More sharing options...
Jdesign Posted July 27, 2018 Author Report Share Posted July 27, 2018 13 hours ago, SteelBlue said: My buddies reaction when they saw this at RA for vintage weekend was absolutely priceless. I can't begin to tell you how many people stopped to ask about it. It was pretty funny watching people whip their phone out to snap a pic of my car as I drove past. I guess in a sea of Ferrari's, Maserati's, and Porsche's its was pretty hard to not notice it. 🤣 SteelBlue 1 Quote Link to comment Share on other sites More sharing options...
YoungCR Posted July 27, 2018 Report Share Posted July 27, 2018 Is the brightness on the light bar adjustable? Quote Link to comment Share on other sites More sharing options...
Jdesign Posted July 31, 2018 Author Report Share Posted July 31, 2018 On 7/27/2018 at 11:32 AM, YoungCR said: Is the brightness on the light bar adjustable? Kind of? It depends on the amount of voltage sent to it. in this case the halos are backfeeding it so it glows a bit when they are on. Quote Link to comment Share on other sites More sharing options...
Jdesign Posted October 2, 2018 Author Report Share Posted October 2, 2018 Sadly I havent driven this car very much as I hoped in the past few months. Time, weather, life, and other projects have been standing in the way. Because of this, I have been considering a new approach for this car the next few months. Since my winter/daily is starting to rust, and a civic hybrid isn't the most entertaining thing to drive in the snow, thoughts of lifting this car and adding some knobby tires keeps popping into my head. Thoughts on this idea? Am I going down a wormhole? Anyone have experience lifting an E36? P_Roloff 1 Quote Link to comment Share on other sites More sharing options...
GunMetalGrey Posted October 2, 2018 Report Share Posted October 2, 2018 2 hours ago, Jdesign said: Sadly I havent driven this car very much as I hoped in the past few months. Time, weather, life, and other projects have been standing in the way. Because of this, I have been considering a new approach for this car the next few months. Since my winter/daily is starting to rust, and a civic hybrid isn't the most entertaining thing to drive in the snow, thoughts of lifting this car and adding some knobby tires keeps popping into my head. Thoughts on this idea? Am I going down a wormhole? Anyone have experience lifting an E36? Don't do it, I don't know who in their right mind would lift a BMW. Jdesign, P_Roloff and Bassboy3313 1 2 Quote Link to comment Share on other sites More sharing options...
P_Roloff Posted October 3, 2018 Report Share Posted October 3, 2018 I say go for it, that'd be pretty cool. It already has a truck motor and a roof rack, is basically a truck already, right? And with the welded rear end, it'll be a hoot in the snow! Jdesign 1 Quote Link to comment Share on other sites More sharing options...
YoungCR Posted October 3, 2018 Report Share Posted October 3, 2018 I foresee more rust in your phuture Jdesign 1 Quote Link to comment Share on other sites More sharing options...
