B C Posted February 18, 2020 Report Share Posted February 18, 2020 @Jdesign in the future Jdesign 1 Quote Link to comment Share on other sites More sharing options...
Jdesign Posted February 18, 2020 Author Report Share Posted February 18, 2020 7 minutes ago, B C said: @Jdesign in the future I never realized Biff had euro bumpers Quote Link to comment Share on other sites More sharing options...
jc43089 Posted February 18, 2020 Report Share Posted February 18, 2020 1 hour ago, Jdesign said: I never realized Biff had euro bumpers Duh, it's the future! Also are you doing upper and lower ball joints on the trailing arms instead of the non M style with one ball joint and one bushing? I did that on mine and I don't see any reason why not to. Quote Link to comment Share on other sites More sharing options...
Jdesign Posted February 18, 2020 Author Report Share Posted February 18, 2020 1 hour ago, jc43089 said: Duh, it's the future! Also are you doing upper and lower ball joints on the trailing arms instead of the non M style with one ball joint and one bushing? I did that on mine and I don't see any reason why not to. Yes, although I stupidly forgot that I have new bushings that I made from delrin for the lowers already on the car as seen here: https://www.wibimmers.com/board/index.php?/topic/4537-futuristicconcept-art-bmw-e36-with-a-v8-on-a-bottom-dollar-budget/page/18/ Im also contemplating if I should just find a cheap fuel cell instead of replacing the fuel tank.... Thoughts? Quote Link to comment Share on other sites More sharing options...
jc43089 Posted February 19, 2020 Report Share Posted February 19, 2020 18 hours ago, Jdesign said: Im also contemplating if I should just find a cheap fuel cell instead of replacing the fuel tank.... Thoughts? What's wrong with the fuel tank? Maybe I missed it. The stock tank seems like a good design, it's low and fits around the components of the car well. Any fuel cell is going to be further back and higher up. Also capacity might be an issue, it would be annoying to stop for fuel every 150 miles. I would think tanks should be all over from junked cars, there isn't anything to go wrong on them unless it gets punctured. Quote Link to comment Share on other sites More sharing options...
straight6pwr Posted February 19, 2020 Report Share Posted February 19, 2020 roof rack + Jdesign and m42b32 1 1 Quote Link to comment Share on other sites More sharing options...
straight6pwr Posted February 19, 2020 Report Share Posted February 19, 2020 another idea: put a hole in top of the trunk lid and put that tank in the trunk so you can see it. maybe leave the filler hanging out a hole in the lid or the fender. Quote Link to comment Share on other sites More sharing options...
Jdesign Posted February 19, 2020 Author Report Share Posted February 19, 2020 3 hours ago, jc43089 said: What's wrong with the fuel tank? Maybe I missed it. The stock tank seems like a good design, it's low and fits around the components of the car well. Any fuel cell is going to be further back and higher up. Also capacity might be an issue, it would be annoying to stop for fuel every 150 miles. I would think tanks should be all over from junked cars, there isn't anything to go wrong on them unless it gets punctured. It has a hole in it. When the car bottoms out, it smushed the floor into the tank a poked a small hole in it. I patched it, but I have a new tank I got from TJ. But since the floor is all destroyed, its likely to happen again unless I smasheth everything with a BFH. Not that I dont mind doing that, but I thought it might be smarter to just get a fuel cell. IDK you are probably right about keeping the stock tank. 2 hours ago, straight6pwr said: another idea: put a hole in top of the trunk lid and put that tank in the trunk so you can see it. maybe leave the filler hanging out a hole in the lid or the fender. LOL. I plan on cutting the whole floor of the trunk out while im doing the subframe and all that stuff back there. I think its a smart move to relocate the battery between the strut towers vs. the stock quater-panel location in case I hit something. With that, I figured it might be easy to run a fuel cell but in the end it more messing around that I dont need to do right now. I just want to get this thing road worthy again. This is similar to what I was thinking: Quote Link to comment Share on other sites More sharing options...
straight6pwr Posted February 19, 2020 Report Share Posted February 19, 2020 you'd never have to stop for gas with 45-50 gal. jc43089 1 Quote Link to comment Share on other sites More sharing options...
Jdesign Posted February 19, 2020 Author Report Share Posted February 19, 2020 Just now, straight6pwr said: you'd never have to stop for gas with 45-50 gal. IDK if I would even get moving with the weight and use of diesel in a gas engine. But seriously, that's obnoxious and would require some extensive fabrication to make sure I don't explode when I hit something. (I really plan on hitting something) Quote Link to comment Share on other sites More sharing options...
straight6pwr Posted February 19, 2020 Report Share Posted February 19, 2020 they hang these off the sides of trucks and everything is hunky-dory. i've never seen a semi truck on fire before. Quote Link to comment Share on other sites More sharing options...
Jdesign Posted February 19, 2020 Author Report Share Posted February 19, 2020 3 minutes ago, straight6pwr said: they hang these off the sides of trucks and everything is hunky-dory. i've never seen a semi truck on fire before. https://www.youtube.com/watch?v=rpnCB2OwgVY Quote Link to comment Share on other sites More sharing options...
YoungCR Posted February 19, 2020 Report Share Posted February 19, 2020 31 minutes ago, straight6pwr said: they hang these off the sides of trucks and everything is hunky-dory. i've never seen a semi truck on fire before. I’ve seen more cars burning on the side of the road then tractors but it does happen haha. It’s usually electrical issues. Quote Link to comment Share on other sites More sharing options...
jc43089 Posted February 20, 2020 Report Share Posted February 20, 2020 Also for a truck it's filled with diesel which doesn't readily burst into flames like gasoline... YoungCR and Jdesign 2 Quote Link to comment Share on other sites More sharing options...
Jdesign Posted March 11, 2020 Author Report Share Posted March 11, 2020 So, I finally took some time to work on this. Despite the parts being moved around the shop as I tended to other projects, I finally moved the crate for the last time and got this going last weekend. Up on the lift I pulled the old wheels off and found that one of my spacers became no longer hub centric.. Besides that I was able to get 6"s of lift out of the coilovers up front before the bottom of the uprights hit the control arms. I made a slight adjustment back down to prevent this. In the future I might need to add a spacer to the subframe and control arm bushings to get more lift and travel out of this set up. I also had to remove the brake lines from mounting locations as the flex section was maxed out and would have prevented me from turning. The PO deleted the ABS and its a mess, so I might find myself addressing the brakes again in the near future, but for now I will just weld tabs for new "lower" mounting locations to allow the lift. I had to remove the front bumper due to the tires rubbing and I was unsure if I wanted to trim it and the filler panel with the kidneys. After I removed it I test fit the front wheels and kind of like the look with no bumper cover. I might need to attach some kidneys of some sort just because of the BMW factor but I will revisit this later. I then started the rear last night which was a whole different situation. I started by removing the over fenders and exhaust. As mentioned earlier, I was upgrading to ///M Swing arms and axles. So with that, I have all new bushings, subframe, control arms, control arm supports, ETC. I am swapping out everything besides the shocks, brakes, and diff. I was able to remove everything without any major issues. Once everything was set aside, I started to trim the arches more to allow the bigger tires. After this I gave up for the night and will return tonight. ...... But obviously I had to see how it looked on the ground, so I set it all in place and lowered the car back on the ground. Needless to say I was pretty happy with the results. gilber33, jc43089, m42b32 and 2 others 5 Quote Link to comment Share on other sites More sharing options...
jc43089 Posted March 11, 2020 Report Share Posted March 11, 2020 Excellent! Jdesign 1 Quote Link to comment Share on other sites More sharing options...
Jdesign Posted March 11, 2020 Author Report Share Posted March 11, 2020 32 minutes ago, jc43089 said: Excellent! 🤠👹😈 Quote Link to comment Share on other sites More sharing options...
straight6pwr Posted March 11, 2020 Report Share Posted March 11, 2020 WhistlinDiesel would be proud next step: Jdesign, P_Roloff and REKIII 3 Quote Link to comment Share on other sites More sharing options...
YoungCR Posted March 11, 2020 Report Share Posted March 11, 2020 Mount the kidneys to a custom brush guard? Or make your own monster kidneys Quote Link to comment Share on other sites More sharing options...
Jdesign Posted March 11, 2020 Author Report Share Posted March 11, 2020 2 hours ago, YoungCR said: Or make your own monster kidneys You mean use a set from a 2020 BMW? P_Roloff, YoungCR and jc43089 3 Quote Link to comment Share on other sites More sharing options...
Jdesign Posted March 12, 2020 Author Report Share Posted March 12, 2020 Got the gas tank out last night. Despite what I thought, the gas tank wasn't actually what was leaking. Turns out the brake lines behind the fuel tank for the rear brakes was extremely rusted in the corners and was leaking. The vent tube on the top of the tank was in pretty bad shape which may have been leaking too but only when the tank was full. Speaking of full, I also had 3/4 of gas in the tank. 🙄 The line above the two vent lines: The spot where I thought the tank was leaking once I cleaned it off. It was rubbing on the chassis but I fixed that with a hammer once it was out. Also, thinking ahead, I realize the fuel and brake lines running to the back of the car are low an pose a threat to any obstructions I may find, So I will be building bash plates to "fix" the floor and cover all the lines to prevent damage. Pics of floor to show you why cars have windows and leaving wet carpet in your car for a year is bad: Quote Link to comment Share on other sites More sharing options...
Jdesign Posted March 16, 2020 Author Report Share Posted March 16, 2020 I figured the rust wasnt removing enough weight fast enough. Also needed room for this With nothing in the back of the car, I noticed that the car was starting to tip off of the lift so I had to strap it down LOL Some quick C.A.D. I found some nice sheet metal at my work from an industrial washing machine, which made a perfect new floor. I will be using the same stuff under the rusty sections too before I fully flintstone the car. P_Roloff, jc43089, REKIII and 1 other 4 Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted March 16, 2020 Report Share Posted March 16, 2020 Me, every time I see this thread updated Jdesign 1 Quote Link to comment Share on other sites More sharing options...
Jdesign Posted March 16, 2020 Author Report Share Posted March 16, 2020 Just bought a BIGGER BFH. If anyone is bored and has a desire to be destructive, wants a little extra arm exercise, or just wants to watch me break something, I need to persuade the chassis a bit, for some slightly larger wheels, you are all more than welcome to "swing" by. YoungCR, jc43089 and P_Roloff 3 Quote Link to comment Share on other sites More sharing options...
REKIII Posted March 17, 2020 Report Share Posted March 17, 2020 Based on how the world is devolving, you better get this thing on the road sooner than later. 😮 Quote Link to comment Share on other sites More sharing options...
