KaiserRolls Posted July 10, 2017 Author Report Share Posted July 10, 2017 Well with uncle bens help: Cams are in and engine is timed, everything is torqued. Will be rechecking the ARPs after the first heat cycle Still need to flush block as well Rebuilt the vanos while he installed the cams (didn't take pics) was pretty easy. There was a decent amount of play before, not as much after. Hooray for no more marbles. Installed new Stewart pump as well Now it's just reinstalling exhaust & all other crap. Realized I sold my intake elbow, so I can't really drive it around the rest of the year NA, so I'm forcing myself to finish the SC. Looks like I'll have to figure out something for modifying the dipstick tube for a drain (or just tap the pan) as it interferes with the sc piping. Probably need to buy a new tensioner as well. Also figure out belt routing. Closer! Quote Link to comment Share on other sites More sharing options...
patsbimmer1 Posted July 10, 2017 Report Share Posted July 10, 2017 Hey, get this done so i can get a ride when i'm up next. Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted July 11, 2017 Author Report Share Posted July 11, 2017 Hey, get this done so i can get a ride when i'm up next. I'll try, been tough getting some free time as my folks are visiting this month from Nevada & spending time w/them is > e30 Quote Link to comment Share on other sites More sharing options...
straight6pwr Posted July 11, 2017 Report Share Posted July 11, 2017 woah woah woah Quote forcing myself to finish the SC. you slipped that in there very non-nonchalant. thats awesome! KaiserRolls, Jdesign and Bassboy3313 3 Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted July 16, 2017 Author Report Share Posted July 16, 2017 Waiting on a temp sender (7/18 arrival) for the water temp gauge. Also waiting on the ICV connector (to manifold) from reboot engineering (machined alum). After breaking 3 of the shit plastic ones and for the amount of times I'll most likely have to remove the intake manifold in this thing, I figured why not. ^thats all in the "parts yet to arrive" category Stuff I'll need to figure out: -oil drain from SC, tapping the pan annoys me -intake elbow deal from SC to TB (current one has 2.7 million holes drilled into it) need to either replace it or slap something together Need to get the 2nd O2 bung welded onto my exhaust for the wideband. Need to install and wire all the gauges/senders/etc Seatbelt situation Extend fuel lines Replace all the vac lines & install vacuum distribution block There's more but I can't remember Quote Link to comment Share on other sites More sharing options...
GunMetalGrey Posted July 17, 2017 Report Share Posted July 17, 2017 21 hours ago, KaiserRolls said: Need to get the 2nd O2 bung welded onto my exhaust for the wideband. Should be able to use the narrow band output on the AFR gauge Saves you some hassle and another sensor Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted July 17, 2017 Author Report Share Posted July 17, 2017 Need to get the 2nd O2 bung welded onto my exhaust for the wideband. Should be able to use the narrow band output on the AFR gauge Saves you some hassle and another sensor Don't you need to know values of the sensor or something odd like that. @ snap and I discussed that but I can't remember the outcome Quote Link to comment Share on other sites More sharing options...
B C Posted July 17, 2017 Report Share Posted July 17, 2017 Bosch only publishes sensor values for the newer LSU sensors. I dug deep and could not find anything for the early Bosch narrowband Quote Link to comment Share on other sites More sharing options...
Daggerty Posted July 17, 2017 Report Share Posted July 17, 2017 42 minutes ago, KaiserRolls said: Don't you need to know values of the sensor or something odd like that. @snap and I discussed that but I can't remember the outcome I think he means use the simulated narrow band to ecu you just have to set high and low point for your wideband output, not all can do this. I believe it's 1.1 volts max, otherwise you will get a cel. I can find it if that is the route you are going. Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted July 20, 2017 Author Report Share Posted July 20, 2017 Critical mission failure: On Monday going to the local radiator shop to have them toss a 90° on Also if you take the stock e36 upper hose and flip it 180° and trim off the side that originally connected to the rad, it should clear everything perfectly (obviously it will sit closer to the pulleys, couldn't get anymore bend with only one hand) Ideally the hose will sit such as this Depends how much room he needs with the TIG I'm hoping that if it is semi close to the pulleys, that the solid engine and trans mounts will keep the whole shit show from piling into one another Hoping to get some more piddly stuff finished up this week/weekend such as wiring/random hoses/dipstick drain perhaps. Also most likely won't be able to run the intake tube they provide (hits ABS pump, angle doesn't work either) so I'm probably going to hop on silicone intakes and order up some crap and figure something out, already removed the drivers side hi beam [emoji849] I suck at updates suspenceful 1 Quote Link to comment Share on other sites More sharing options...
patsbimmer1 Posted July 22, 2017 Report Share Posted July 22, 2017 Damn it Kaiser. Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted July 22, 2017 Author Report Share Posted July 22, 2017 Snapped a brake line. Removed abs Time for more room hooray Quote Link to comment Share on other sites More sharing options...
B C Posted July 22, 2017 Report Share Posted July 22, 2017 Break lines Im not chomping at the bit to do an ABS delete like many E30 guys are but I honestly dont think I have ever needed to use the ABS in my car. It has never intervened. Carry on my wayward son Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted July 22, 2017 Author Report Share Posted July 22, 2017 ABS is gone. Unfortunately snapped the stock line under where the stock proportioning valve sits - snapped when I was removing it - honestly is probably not a bad thing and it will force me to replace it. It was the last line that I hadn't replaced in the braking system so all in all I'm not too upset about it. Most likely will just buy a length of hardline that has the fittings installed and bend it to fit. I hate flaring lines. I also will be buying the ABS delete from chase bays. While it's expensive it comes with everything so it'll be convenient. Good news without ABS I can run the stock VF intake pipe with a mushroom filter (yellow one) and run it thru the low beam headlight hole. So from a distance it shouldn't look too different. Also without ABS I can run the stock e30 expansion tank, which I might try and remove the black paint from so I can see the damn coolant level Radiator goes in Monday for modification Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted July 22, 2017 Author Report Share Posted July 22, 2017 Edit: god damn double post tapatalk can eat shit Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted July 22, 2017 Author Report Share Posted July 22, 2017 suspenceful, patsbimmer1 and Rekpoint 3 Quote Link to comment Share on other sites More sharing options...
Jdesign Posted July 24, 2017 Report Share Posted July 24, 2017 Curious to see the radiator back in and plumbed! Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted July 24, 2017 Author Report Share Posted July 24, 2017 Curious to see the radiator back in and plumbed! Same here. Dropped it off today with a bunch of pictures and measurements I took. Guy said it should be done in a week or so. It's kind of neat when you go into these shops that mainly repair SUVs and other boring cars with a "special" project. I had 3 or 4 guys huddled around pictures I had taken of the engine bay (for radiator fitment) all suggesting ideas to the guy who TIG welds lol. It was great Jdesign 1 Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted July 25, 2017 Author Report Share Posted July 25, 2017 ABS delete stuff from Chase Bays ordered, as well as some new hardline for the stuff I broke. Will be ordering up a filter/silicone elbows/aluminum joiners tonight after I get some measurements. Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted July 27, 2017 Author Report Share Posted July 27, 2017 Just ordered up the silicone intake crap/t-bolt clamps/aluminum piping. I think that's the last of what I need to order (probably not) Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted July 27, 2017 Author Report Share Posted July 27, 2017 Also this guy showed up Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted August 1, 2017 Author Report Share Posted August 1, 2017 Got some wiring done, still have some left Quote Link to comment Share on other sites More sharing options...
Jdesign Posted August 1, 2017 Report Share Posted August 1, 2017 7 hours ago, KaiserRolls said: Got some wiring done, still have some left I know your not done, and not a noob, but I would suggest some edging or a grommet in that hole in the firewall. Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted August 1, 2017 Author Report Share Posted August 1, 2017 Got some wiring done, still have some left I know your not done, and not a noob, but I would suggest some edging or a grommet in that hole in the firewall. Yet to go in I'm just pulling wires thru for length measurement at this time I still have an entire harness to snake thru there lol Jdesign 1 Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted August 1, 2017 Author Report Share Posted August 1, 2017 Should be done for the aug 13 road America autox...... lol Rekpoint, inazupra and Jdesign 3 Quote Link to comment Share on other sites More sharing options...
