YoungCR Posted September 20, 2013 Author Report Share Posted September 20, 2013 Parts I wanted to get on the car tonight. My nice southern trans tunnel Cleaned up the back of the block Starter guide? Whatever its called is on. This is what I forgot last night Dominic540i and I both doing pre 5er meet work Flywheel and clutch mounted. This was before aligning the clutch plate We weren't exactly sure which clutch pilot tool to use (we have a zillion at the dealer), but I used one that fit the best but something was still wrong as we couldn't get the input shaft to go into the pilot bearing. Neither Dominic or I have installed a trans before and after 45min of trying we still had no luck so I'm gonna bribe one of the techs to help me with this tomorrow. Hopefully my pilot bearing is serviceable. Quote Link to comment Share on other sites More sharing options...
B C Posted September 20, 2013 Report Share Posted September 20, 2013 Feels good to work on a rust free chassis. More time spent improving the car, less time spent loosening stuck fasteners. Keep on stabbin' that tranny. Quote Link to comment Share on other sites More sharing options...
jc43089 Posted September 20, 2013 Report Share Posted September 20, 2013 Make sure you leave it in gear, then you can turn the output flange to get the splines to mesh. Quote Link to comment Share on other sites More sharing options...
Dominic540 Posted September 20, 2013 Report Share Posted September 20, 2013 We were able to get the splines to mesh alright, just couldn't get the input shaft of the tranny into the pilot bearing on the crank. Quote Link to comment Share on other sites More sharing options...
YoungCR Posted September 20, 2013 Author Report Share Posted September 20, 2013 We were able to get the splines to mesh alright, just couldn't get the input shaft of the tranny into the pilot bearing on the crank. Apparently the trick is to do it by feel without the transmission jack, just good 'ole muscle! So me and a lucky helper will give that a go. Quote Link to comment Share on other sites More sharing options...
YoungCR Posted September 20, 2013 Author Report Share Posted September 20, 2013 I clocked out early for work cause things were super slow and was able to get some help from the techs getting my trans in. We did end up realigning the clutch disc with a homemade tool that one of the techs had around. It was actually a cut off input shaft so the fit was perfect! Thanks again for the help Dominic For those of you that haven't mated a transmission to an engine before, I guess it comes down to "the feel" when getting the input shaft into the pilot bearing. Even though we were using a heavy duty transmission jack, when it comes to that point its just there for support and you will need to wrestle the transmission around until everything slides together. We were able to get the trans pretty close but I did need to pull it tight with the bolts. Otherwise its a fairly simple procedure. Here is a pic after we got the engine/trans mated. I only have 3 bolts in so I had to leave the jack underneath overnight. Tomorrow will be a busy day! Quote Link to comment Share on other sites More sharing options...
YoungCR Posted September 24, 2013 Author Report Share Posted September 24, 2013 So this happened sometime between now and Saturday night . We are thinking that it might have been backed into by a tow truck but who knows. Dominic pointed it out to me as I was leaving work, so he was the first to notice. I hadn't been on that side of the lot so I haven't seen the car since I parked it Saturday night. This sucks cause now I'm back to square one basically although I'm still better off then the old car. Ughh! Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted September 24, 2013 Report Share Posted September 24, 2013 NOOOOOOOOOOOOOOOOOOOO!!! doesn't a classy joint like concours have security cameras? Quote Link to comment Share on other sites More sharing options...
Earl Posted September 25, 2013 Report Share Posted September 25, 2013 So they just had to fuck up the drivers side fender? Why cant they hit the passenger side that is easy to source a fender for. Quote Link to comment Share on other sites More sharing options...
Dominic540 Posted September 25, 2013 Report Share Posted September 25, 2013 I would be glad to help work on it, as always Chris. Sorry I had to be the bearer of bad news... Quote Link to comment Share on other sites More sharing options...
B C Posted September 25, 2013 Report Share Posted September 25, 2013 Sorry to hear Chris, if anyone "likes" your post, I will personally kick their ass then ban them. YoungCR 1 Quote Link to comment Share on other sites More sharing options...
YoungCR Posted September 25, 2013 Author Report Share Posted September 25, 2013 NOOOOOOOOOOOOOOOOOOOO!!! doesn't a classy joint like concours have security cameras? You would think! I'm gonna speak to the GM about it tomorrow. So they just had to fuck up the drivers side fender? Why cant they hit the passenger side that is easy to source a fender for. Both fenders are ruined. Not sure what my plan is yet. The core support should be able to pull out fine as the headlight buckets and where the hood got bent pushed in somethings. I won't know until I take apart the front end though. I would be glad to help work on it, as always Chris. Sorry I had to be the bearer of bad news... I'm glad you pointed it out though! I appreciate it man, maybe tomorrow I'll be motivated to look over the electrical issue. Like I said I think I wired the starter up wrong. I think for now I'm just gonna pound stuff out and call it good since its not like this car is a showpiece anyways. When the time comes to get a paint job then this can all be fixed. Quote Link to comment Share on other sites More sharing options...
mkoepp Posted September 25, 2013 Report Share Posted September 25, 2013 updates! nice! also, I spy rampelsausage. If you need someone to stand around and make wild accusations about random things. lemme know. I'm in.I can assist here if needed also. Always glad to help. Quote Link to comment Share on other sites More sharing options...
mkoepp Posted September 25, 2013 Report Share Posted September 25, 2013 So this happened sometime between now and Saturday night . We are thinking that it might have been backed into by a tow truck but who knows. Dominic pointed it out to me as I was leaving work, so he was the first to notice. I hadn't been on that side of the lot so I haven't seen the car since I parked it Saturday night. This sucks cause now I'm back to square one basically although I'm still better off then the old car. Ughh! I don't know what to say. I feel for you man... Quote Link to comment Share on other sites More sharing options...
YoungCR Posted October 16, 2013 Author Report Share Posted October 16, 2013 So I guess Geico is a horrible company to do business according to my father, still working on the insurance claim I guess. Mean while I'm gonna try to sort out the electrical issues this weekend and see if I can get some M20 valves tickking. Figured I'd post up the full damage pics too. Looks like I need a core support also, which may lead to a euro conversion Quote Link to comment Share on other sites More sharing options...
Earl Posted October 16, 2013 Report Share Posted October 16, 2013 I wonder how the hell it hit both sides Quote Link to comment Share on other sites More sharing options...
YoungCR Posted October 16, 2013 Author Report Share Posted October 16, 2013 I wonder how the hell it hit both sides We think it was the tow arms on the back of a truck, but who knows Quote Link to comment Share on other sites More sharing options...
YoungCR Posted October 19, 2013 Author Report Share Posted October 19, 2013 Did some work today and got her cranking Now I just need to figure out why I have no spark. Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted October 19, 2013 Report Share Posted October 19, 2013 Did some work today and got her cranking Now I just need to figure out why I have no spark. on my way over to stand on the parts car. Quote Link to comment Share on other sites More sharing options...
YoungCR Posted October 19, 2013 Author Report Share Posted October 19, 2013 on my way over to stand on the parts car. A little late sir, but you are welcome to come over tomorrow and destroy more of it with me. Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted October 19, 2013 Report Share Posted October 19, 2013 only if zach buys us 18 dollar burgers YoungCR 1 Quote Link to comment Share on other sites More sharing options...
RamRod E28 Posted October 20, 2013 Report Share Posted October 20, 2013 Also about the 240sx coilover setup just google it it was either a 5 or 7 series that made it work and looked titties after he was done Quote Link to comment Share on other sites More sharing options...
YoungCR Posted October 20, 2013 Author Report Share Posted October 20, 2013 Also about the 240sx coilover setup just google it it was either a 5 or 7 series that made it work and looked titties after he was done This mentions using 240sx coils. http://www.r3vlimited.com/board/showthread.php?t=232588 Quote Link to comment Share on other sites More sharing options...
B C Posted October 20, 2013 Report Share Posted October 20, 2013 need any spare eta crank position sensors to help diagnose the no-spark issue? Quote Link to comment Share on other sites More sharing options...
YoungCR Posted October 20, 2013 Author Report Share Posted October 20, 2013 need any spare eta crank position sensors to help diagnose the no-spark issue? I'll let you know, my old ones were working but I will be going over the car with a multimeter this week to pin-point the problem. Quote Link to comment Share on other sites More sharing options...
