BMWben Posted February 20, 2017 Report Share Posted February 20, 2017 On 2/17/2017 at 8:07 PM, TehRaydarlover said: https://minneapolis.craigslist.org/hnp/pts/5960595171.html Put it in a Geo Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted June 25, 2017 Author Report Share Posted June 25, 2017 /thread Sent from my SM-G935V using Tapatalk Bassboy3313, KaiserRolls, Jdesign and 3 others 6 Quote Link to comment Share on other sites More sharing options...
B C Posted June 25, 2017 Report Share Posted June 25, 2017 Some nice looking parts you have there! I recognize that work bench Quote Link to comment Share on other sites More sharing options...
wasnt m3 Posted June 25, 2017 Report Share Posted June 25, 2017 What cam did you go with? Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted June 25, 2017 Author Report Share Posted June 25, 2017 LMT Stage 4 Sent from my SM-G935V using Tapatalk Quote Link to comment Share on other sites More sharing options...
patsbimmer1 Posted June 26, 2017 Report Share Posted June 26, 2017 Wow, not messing around! Nice progress! Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted December 22, 2017 Author Report Share Posted December 22, 2017 Motor is back! Flywheel is on. Waiting on the wiring harness. The wheels are in motion! Sent from my SM-G935V using Tapatalk m42b32 and B C 2 Quote Link to comment Share on other sites More sharing options...
B C Posted December 22, 2017 Report Share Posted December 22, 2017 Are those quick-disconnects on the fuel lines? Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted December 22, 2017 Author Report Share Posted December 22, 2017 Are those quick-disconnects on the fuel lines? Kinda, -6AN fittings attached to a stock filter/regulator. See pic. Making new fuel lines with my new 37 degree AN flare tool! Super easy but haven't mastered my bends yet. Fuel Feed: Tank -> 4-6" of 3/8" rubber hose -> barbed fitting -> -6AN Male -> -6AN Female -> 2' of 5/16 Steel fuel line -> -6AN Female -> -6AN Male attached to input of Fuel filter/pressure regulator -> -6AN Male attached to output Fuel filter/pressure regulator -> 4' of 5/16 Steel fuel line -> -6AN Female -> -6AN Male -> braided fuel line -> -6AN fuel rail adaptor -> LS3 Fuel Rail (Needed to use to fit MSD Atomic AirForce Intake) -> DEKA 60lbs injectors Fuel Return: Tank -> 4-6" of 3/8" rubber hose -> barbed fitting -> -6AN Male -> -6AN Female -> 2' of 5/16 Steel fuel line -> -6AN Female -> -6AN Male attached to return of Fuel filter/pressure regulator Thinking about putting a pressure gauge in the engine bay for easy trouble shooting. Sent from my SM-G935V using Tapatalk Quote Link to comment Share on other sites More sharing options...
Jdesign Posted December 22, 2017 Report Share Posted December 22, 2017 4 hours ago, DrLeadFoot said: Thinking about putting a pressure gauge in the engine bay for easy trouble shooting. You should. They are cheap and will save you some guess work down the road! Glad to see you making good progress. Keep on hammering through Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted December 22, 2017 Author Report Share Posted December 22, 2017 Thinking about putting a pressure gauge in the engine bay for easy trouble shooting. You should. They are cheap and will save you some guess work down the road! Glad to see you making good progress. Keep on hammering through [emoji3] I'm trying. With a 6 month old I have 30 min here, 2 hours there. I'll pick it up! Sent from my SM-G935V using Tapatalk Daggerty 1 Quote Link to comment Share on other sites More sharing options...
KaiserRolls Posted December 22, 2017 Report Share Posted December 22, 2017 Someone change this mans thread title!! DrLeadFoot, YoungCR and Daggerty 3 Quote Link to comment Share on other sites More sharing options...
YoungCR Posted December 22, 2017 Report Share Posted December 22, 2017 Glad to see some updates! DrLeadFoot 1 Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted December 23, 2017 Author Report Share Posted December 23, 2017 Someone change this mans thread title!! I've conformed to the LS world and lost all creativity. Suggestions? Sent from my SM-G935V using Tapatalk KaiserRolls 1 Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted January 19, 2018 Author Report Share Posted January 19, 2018 Buttoned up the fuel system! Boris3, Bassboy3313 and i_love_cars 3 Quote Link to comment Share on other sites More sharing options...
straight6pwr Posted January 19, 2018 Report Share Posted January 19, 2018 glad i'm not the only one who's frame rail looks disregarded those new lines are oh so tidy. *thumbsup Quote Link to comment Share on other sites More sharing options...
B C Posted January 19, 2018 Report Share Posted January 19, 2018 I want to weld a 1/4" thick plate to my jack points so i dont feel as bad about things Looks good man! Does the LS require larger fuel lines? I can now gladly say that i have now seen one of those 135 degree bend AN fittings in use. Are the lines aluminum? I wouldnt think steel would be uncoated. Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted January 20, 2018 Author Report Share Posted January 20, 2018 3 hours ago, straight6pwr said: glad i'm not the only one who's frame rail looks disregarded those new lines are oh so tidy. *thumbsup Thanks! This thing has been jacked up so many times... LOL a local indy shop smashed up my rockers after they were perfectly straightened out by yours truly. Those will get bent back and painted. 2 hours ago, Snap said: I want to weld a 1/4" thick plate to my jack points so i dont feel as bad about things Looks good man! Does the LS require larger fuel lines? I can now gladly say that i have now seen one of those 135 degree bend AN fittings in use. Are the lines aluminum? I wouldnt think steel would be uncoated. All the dents gives the jack something to grab onto! It doesn't require larger fuel lines. I'm running 5/16 steel fuel lines for now. Got the line in a 30' roll from napa. We will see how they hold up but they should be fine. Two 120 degree AN fittings are looking great! Behling Racing in Butler hooks it up for these things. I broke one this AM while making the hose and they only charged me $10 for a new one. Quote Link to comment Share on other sites More sharing options...
B C Posted January 20, 2018 Report Share Posted January 20, 2018 Behling is my new Go-to instead of Pegasus (fast cars, slow service) What about just spraying some clear spray paint on the lines? I am a rust-o-phobe. You dont have to humor me, I just cry at bare metal Jdesign 1 Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted January 20, 2018 Author Report Share Posted January 20, 2018 I like that idea! Quote Link to comment Share on other sites More sharing options...
i_love_cars Posted January 21, 2018 Report Share Posted January 21, 2018 This is fucking crazy. We may actually gain a net positive +2 running E30s in the group this season. m42b32, B C, Jdesign and 2 others 5 Quote Link to comment Share on other sites More sharing options...
DrLeadFoot Posted February 7, 2018 Author Report Share Posted February 7, 2018 Chipping away! Got the trans and starter bolted up Next, laying out the wiring harness, steam vents, inake manifold then headers! Gonna roll it under the car and lift it all into place. Jdesign, wasnt m3, P_Roloff and 2 others 5 Quote Link to comment Share on other sites More sharing options...
B C Posted February 7, 2018 Report Share Posted February 7, 2018 steam vents?! I installed my m52 from underneath. I think i like doing it that way better than ramming the engine hoist into the ceiling. Im guessing you are using a Sikky swap kit? Quote Link to comment Share on other sites More sharing options...
wasnt m3 Posted February 7, 2018 Report Share Posted February 7, 2018 2 hours ago, Snap said: steam vents?! It's an LS thing, you wouldn't understand. B C 1 Quote Link to comment Share on other sites More sharing options...
m42b32 Posted February 7, 2018 Report Share Posted February 7, 2018 2 hours ago, Snap said: steam vents?! Implementing a turbosteamer system for maximum tire-roasting power https://www.drivingthenation.com/bmw-heat/ B C 1 Quote Link to comment Share on other sites More sharing options...
